RTX 3080 LHR constantly freezing
Hello, I have Windows and Linux with dual boot and some time ago I started to suffer a lot of freezes in both Windows and Linux. The strange thing is that the audio continues to play when this happens.
These are my specifications:
Hardware Information:
  • Hardware Model: ASUS ROG STRIX B550-F GAMING WIFI II (latest update btw)
  • Memory: 32,0 GiB Corsair Vegeance (ddr 4)
  • Processor: AMD Ryzen™ 9 5900X × 24
  • Graphics: NVIDIA GeForce RTX™ 3080
  • Disk Capacity: 2,0 TB Samsung SSD 970 EVO Plus
In windows I have the latest update 576.40.
In Ubuntu currently I have the drivers 550.163.01 (but I also tried installing the latest 570.144 but didnt work)
Linux (ubuntu 22 & 24 LTS)
Before it always happen to me at any time regardless of what I was doing, but now that I’ve updated to Ubuntu 24, it only freezes for about 10 minutes after I boot into Linux, and it usually only happens twice a day.
Windows 11
It also tends to freeze sometimes when booting, just like in Linux, but here it happens more as soon as I open a game or close it, after a few minutes my pc just freezes but audio still works.
Here are the last logs when my pc freezes on linux:
journalctl -b -1 | tail -n 100
may 16 07:23:59 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
may 16 07:23:59 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
may 16 07:23:59 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
may 16 07:23:59 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
may 16 07:23:59 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
may 16 07:24:01 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=650000
may 16 07:24:04 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=585000
may 16 07:24:07 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=87800
may 16 07:24:10 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-40 noise=9999 txrate=97600
may 16 07:24:13 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-40 noise=9999 txrate=97600
may 16 07:24:16 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-40 noise=9999 txrate=97600
may 16 07:24:19 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-40 noise=9999 txrate=87800
may 16 07:24:22 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=585000
may 16 07:24:25 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=585000
may 16 07:24:28 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=87800
may 16 07:24:31 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=702000
may 16 07:24:34 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=585000
may 16 07:24:37 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-37 noise=9999 txrate=87800
may 16 07:24:40 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=702000
may 16 07:24:43 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=87800
may 16 07:24:46 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=702000
may 16 07:24:49 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=585000
may 16 07:24:52 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=87800
may 16 07:24:55 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-40 noise=9999 txrate=87800
may 16 07:24:57 Violet spotify.desktop[9678]: *** stack smashing detected ***: terminated
may 16 07:24:58 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=780000
may 16 07:25:01 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=585000
may 16 07:25:01 Violet CRON[9731]: pam_unix(cron:session): session opened for user root(uid=0) by root(uid=0)
may 16 07:25:01 Violet CRON[9732]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
may 16 07:25:01 Violet CRON[9731]: pam_unix(cron:session): session closed for user root
may 16 07:25:04 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=87800
may 16 07:25:07 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=87800
may 16 07:25:10 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-37 noise=9999 txrate=780000
may 16 07:25:13 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-32 noise=9999 txrate=87800
may 16 07:25:16 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=87800
may 16 07:25:19 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-32 noise=9999 txrate=585000
may 16 07:25:22 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=780000
may 16 07:25:25 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-40 noise=9999 txrate=780000
may 16 07:25:28 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=585000
may 16 07:25:31 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=780000
may 16 07:25:34 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=87800
may 16 07:25:37 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=585000
may 16 07:25:40 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=780000
may 16 07:25:43 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=866700
may 16 07:25:43 Violet tracker-miner-fs-3[9822]: (tracker-extract-3:9822): GLib-GIO-WARNING **: 07:25:43.577: Error creating IO channel for /proc/self/mountinfo: Invalid argument (g-io-error-quark, 13)
may 16 07:25:44 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 34 with keysym 34 (keycode d).
may 16 07:25:44 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 35 with keysym 35 (keycode e).
may 16 07:25:44 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 33 with keysym 33 (keycode c).
may 16 07:25:44 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 32 with keysym 32 (keycode b).
may 16 07:25:44 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 36 with keysym 36 (keycode f).
may 16 07:25:44 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 37 with keysym 37 (keycode 10).
may 16 07:25:44 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 39 with keysym 39 (keycode 12).
may 16 07:25:44 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 38 with keysym 38 (keycode 11).
may 16 07:25:44 Violet gnome-shell[3148]: Window manager warning: Overwriting existing binding of keysym 31 with keysym 31 (keycode a).
may 16 07:25:46 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-40 noise=9999 txrate=780000
may 16 07:25:49 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=780000
may 16 07:25:52 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=866700
may 16 07:25:55 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=866700
may 16 07:25:58 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=780000
may 16 07:26:01 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=87800
may 16 07:26:04 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-40 noise=9999 txrate=585000
may 16 07:26:07 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=866700
may 16 07:26:10 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=866700
may 16 07:26:13 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-40 noise=9999 txrate=866700
may 16 07:26:14 Violet code.desktop[5343]: [5343:0516/072614.599847:ERROR:atom_cache.cc(229)] Add _NET_RESTACK_WINDOW to kAtomsToCache
may 16 07:26:16 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=866700
may 16 07:26:19 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=866700
may 16 07:26:22 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=866700
may 16 07:26:25 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-33 noise=9999 txrate=650000
may 16 07:26:26 Violet kernel: NVRM: GPU at PCI:0000:08:00: GPU-71f9ad3e-88d9-525c-4650-1714860c8863
may 16 07:26:26 Violet kernel: NVRM: Xid (PCI:0000:08:00): 79, pid=‘’, name=, GPU has fallen off the bus.
may 16 07:26:26 Violet kernel: NVRM: GPU 0000:08:00.0: GPU has fallen off the bus.
may 16 07:26:26 Violet kernel: NVRM: A GPU crash dump has been created. If possible, please run
NVRM: nvidia-bug-report.sh as root to collect this data before
NVRM: the NVIDIA kernel module is unloaded.
may 16 07:26:28 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=866700
may 16 07:26:31 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=87800
may 16 07:26:34 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-38 noise=9999 txrate=866700
may 16 07:26:37 Violet google-chrome.desktop[3922]: [3964:3964:0516/072637.065925:ERROR:gpu/command_buffer/service/shared_context_state.cc:1325] SharedContextState context lost via ARB/EXT_robustness. Reset status = GL_GUILTY_CONTEXT_RESET_KHR
may 16 07:26:37 Violet google-chrome.desktop[3922]: [3964:3964:0516/072637.066124:ERROR:components/viz/service/gl/gpu_service_impl.cc:1173] Exiting GPU process because some drivers can’t recover from errors. GPU process will restart shortly.
may 16 07:26:37 Violet kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:6:0:0x0000000f
may 16 07:26:37 Violet kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:4:0:0x0000000f
may 16 07:26:37 Violet kernel: nvidia-modeset: ERROR: GPU:0: Failed to query display engine channel state: 0x0000c67e:2:0:0x0000000f
may 16 07:26:37 Violet google-chrome.desktop[3922]: [3915:3915:0516/072637.084434:ERROR:content/browser/gpu/gpu_process_host.cc:956] GPU process exited unexpectedly: exit_code=8704
may 16 07:26:37 Violet wpa_supplicant[1276]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-39 noise=9999 txrate=866700
may 16 07:26:39 Violet kernel: sysrq: This sysrq operation is disabled.
may 16 07:26:40 Violet kernel: sysrq: Emergency Sync
