I’ve reinstalled drivers 1000x times, I have updated to every possible version of windows 10. Device shows up in nvidia-smi however every single test fails. nbody, deviceQuery, all deep learning frameworks fail. Nothing can select the device. WSL2 dose not work, running the applications natively dose not work. Clean driver installation dose not fix. I could keep going on but just assume if google would yield the result, I’ve tried it. I’m 4 solid days into trying to fix this with absolutely no luck.
OS: Windows 10 - 21292.1010
Driver Version: 465.21
cuda 11.2
