RTX 4000 usb-c to dvi
Hello all. I have an RTX 4000 that i need to drive a projector with 4 DVI inputs using MOSAIC. The 3 standard display ports are working great with a DP to DVI adapter. The usb-c is giving me problems. I purchased an active usb-c to DP adapter (startech brand i think) and from there i used a DP to DVI. That gives me a signal, but it is very noisy. I am hoping its just the adapter i purchased. Any suggestions for a different adapter that is known to work?
Hi Bowdendr,
What resolution are you trying to set? NVIDIA doesn’t have any recommended connectors to go from ubs-c to DVI and we don’t test mixing adaptors.
Having said that I came across this as a usb-c to DVI adaptor - USB-C to DVI-D Adapter | Accell (accellww.com) . I don’t have any personal experience of this adaptor - so this is not an endorsement, but hopefully, a single adaptor should give a better experience than chaining adaptors together.
D
