RTX 4060 Laptop — Xid 62 / Xid 120 GSP crashes in idle, reproducible on both open and proprietary driver (610.43.02 / 610.43.03)
Hardware:
  • GPU: NVIDIA GeForce RTX 4060 Laptop GPU
  • Laptop: Acer Predator PHN16-71
  • OS: Arch Linux, kernel 7.1.3-arch1-2
  • Driver tested: nvidia-open-dkms 610.43.02, and nvidia-dkms (proprietary) 610.43.03
  • Kernel params: nvidia-drm.modeset=1 pcie_aspm=off processor.max_cstate=1 usbcore.autosuspend=-1 nvidia_drm.fbdev=1
Problem description:
System randomly hard-crashes (black screen, GPU-dependent desktop session dies) while the machine is idle — not under gaming/rendering load. Confirmed on two separate driver stacks:
  1. nvidia-open-dkms 610.43.02: NVRM: Xid 62 (GSP PMU halted) → Xid 154 (GPU recovery: PF FLR) → cascading Xid 45 across all GPU-channel processes (compositor, browser, IDE).
  2. nvidia-dkms 610.43.03 (proprietary): NVRM: Xid 120 (GSP task exception: instruction access page fault) → Xid 154 (PF FLR) → cascade of nvAssertFailedNoLog / NV_ERR_RESET_REQUIRED (0x62) across rs_client/rs_server, ending in complete GPU death requiring hard reboot.
Both crashes occurred with zero preceding load — background processes only (browser, IDE, messaging apps), no games/compute running. This matches other reports of RTX 4060 Laptop GSP instability tied to power-management state transitions.
Attempted workaround: NVreg_EnableGpuFirmware=0 via modprobe.d — need to confirm whether this is even a valid path for this GPU generation, since /sys/module/nvidia/parameters/EnableGpuFirmware doesn’t appear to exist after applying it, suggesting GSP may not be optional on this hardware/driver combination.
Logs attached: nvidia-bug-report.log.gz
Question: Is this a known GSP firmware issue for RTX 4060 Laptop specifically? Is there a supported way to keep the GPU out of the power state that triggers this, short of disabling GSP entirely (which may not be supported on this GPU)?
nvidia-bug-report.log.gz (696.7 KB)
Greetings.
I have updated my Asus G16 (RTX 4080, Fedora 7.1.3-201) laptop Nvidia proprietary driver to 610 recently too and encountered a similar issue.
For me it was in the NVIDIA 610.43.03’s kernel notifier suspend path.
To workaround it I had to add this options nvidia NVreg_UseKernelSuspendNotifiers=0 to a new config file: /etc/modprobe.d/nvidia-suspend.conf
Then rebuilt the initramfs sudo dracut --force /boot/initramfs-$(uname -r).img $(uname -r) and reboot.
Spent several hours troubleshooting it and for now this workaround seems to be stable.
Hope this helps you, OP or someone else who like me stumbled upon this thread
Thanks a lot for sharing this, really appreciate it!
Small difference in my case though — my crashes happened during plain idle (no suspend/sleep involved), so the trigger might not be identical to your suspend notifier path. But since both likely tie into the same GSP power-management logic, it’s worth testing.
I’ll apply the same workaround (adapted for Arch/mkinitcpio instead of dracut) and run it through daily use for a few days before drawing conclusions. Will report back here with results either way — whether it holds up or the Xid crashes return.
I may be experiencing a closely related issue on another RTX 4060 Laptop system, although my trigger and logs differ because no Xid was recorded before the journal stopped.
Hardware/software:
  • Laptop: MSI Raider GE68HX 13VF (MS-15M2)
  • GPU: NVIDIA GeForce RTX 4060 Laptop GPU (AD107M, PCI ID 10de:28a0)
  • Fedora Linux 44, GNOME/Wayland, hybrid Intel/NVIDIA graphics
  • NVIDIA open kernel module 610.43.03
  • Kernel at the time of the freeze: 7.1.4-204.fc44.x86_64
  • BIOS: E15M2IMS.113
  • EC firmware: 15M2IMS1.114
The second hard freeze occurred during minimal PyTorch CUDA initialization:
x = torch.ones(1, device="cuda")
torch.cuda.synchronize()
The call blocked inside torch.cuda.synchronize(). A 30-second userspace timeout could not recover it, the desktop and system became unresponsive, and a forced power-button reboot was required. No
stress test or matrix multiplication had started.
The affected boot's journal ended abruptly. Before it ended, there was no Xid, PCIe AER error, OOM, overtemperature event, or “GPU has fallen off the bus” message. After reboot, the GPU is detected
normally and nvidia-smi works at idle.
The driver has also logged SBIOS query failures on this MSI laptop:
- failed to get target temp from SBIOS
- failed to get platform power mode from SBIOS
- NV_ERR_INVALID_DATA (0x00000025)
Current NVIDIA parameters include:
UseKernelSuspendNotifiers: 1
DynamicPowerManagement: 3
EnableGpuFirmware: 18
This freeze was not triggered by suspend/resume; it occurred during CUDA initialization. Could this share the same GSP/power-management root cause despite the absence of an Xid?
nvidia-bug-report-msi-rtx4060-2026-07-26-redacted.log.gz (99.8 KB)
diagnostic or mitigation for Ada Laptop GPUs?
I am attaching a safe-mode nvidia-bug-report.log.gz.
