I’m posting this as a candidate workaround, not a solution. I would like others hitting the same thing to test it and report back, and I would welcome input from NVIDIA on what could cause it.
My GPU hard-locks at random while path tracing is enabled. Since limiting the maximum core clock to 2100 MHz with nvidia-smi I have not had a single hard freeze in about 10 sessions / 15+ hours of the same game at the same settings. Before that, freezes came anywhere from a few minutes to about 4 hours apart.
My rig:
- MSI Raider GE78 HX 13V, Core i9-13980HX
- GeForce RTX 4090 Laptop GPU (AD103), 16 GB GDDR6, 150 W TGP + Dynamic Boost (175 W total)
- VBIOS 95.03.2A.00.2A
- CachyOS (Arch-based), NVIDIA driver 615.71.09 (an previous 610.57.04)
- Root port reports PCIe 4.0 x8 in LnkCap — that is how this machine is wired, not a degraded link. ASPM is not supported on the port, so the ASPM workarounds discussed in other “fallen off the bus” threads do not apply here.
- Game: Cyberpunk 2077 via Heroic Games Launcher / Proton, max settings with path tracing, DLSS DLLs at 310.9.1
What happens:
- Display freezes on the last rendered frame, audio stops, the machine is unresponsive.
- The keyboard’s graphics-mode LED changes from orange to white.
- Magic SysRq is enabled but does not respond. Only a hard power-off works.
- I managed to capture the kernel log entry once: Xid 79, “GPU has fallen off the bus”. Most other occurrences were never logged, because the hard reset lost the tail of the journal.
- I found no AER or PCIe error entries in the logs I was able to check.
- No obvious trigger. It hit during heavy combat as readily as while standing still reading in-game text about a minute into a session.
What I’ve found out
- Not thermal in any obvious way. The GPU tops out at 86-88 C under path tracing and throttles normally to a median of about 1750 MHz. One freeze happened in a light scene at roughly 41% GPU load, 67 W, 76 C.
- Not VRAM exhaustion. Peak usage was 14.1 GB of 16 GB.
- It happens in both MSHybrid and discrete/MUX mode.
- I did not see this on the 580-series driver branch, but I have not played enough hours on those to call that conclusive.
- I also had a crash in Alan Wake 2 on Windows, but that was while forcing neural rendering (not supported on this GPU) through the OptiScaler mod, with a +100 MHz MSI Center offset active. I do not count it as a reproduction.
My workaround (so far effective):
sudo nvidia-smi -lgc 210,2100 # cap the max core clock at 2100 MHz
sudo nvidia-smi -rgc # revert
The lock does not survive a reboot, and nvidia-smi does not report whether a lock is set, so verify it by watching the clock. Uncapped, this GPU boosts to about 2325-2340 MHz in menus and light scenes; capped, it sits at exactly 2100 MHz. A MangoHud CSV log makes this trivial to check: look at the maximum of gpu_core_clock.
Cost: essentially none for this workload. Under path tracing the median core clock on this card is around 1750 MHz and it exceeds 2100 MHz in roughly 1% of samples, so the cap only binds in menus and dialogue where the frame rate is 200+ anyway. Average FPS across comparable sessions was unchanged (62 vs 64).
The limitations of my investigation:
- About 10 sessions and 15+ hours with the cap, no hard freeze. Against the previous failure intervals that is roughly three times the mean time between failures, so I believe it is more than luck. It is still one person’s data.
- I have not yet run the control: removing the cap and confirming the freeze comes back. Until someone does that, this is a correlation and nothing more.
- One softer event since the cap: the game itself hung, but the driver survived. I alt-tabbed out, killed the process and relaunched. I do not know yet whether that is related or just a game bug.
- On Linux, only Cyberpunk 2077 has ever done this to me; other titles have been stable. I cannot tell yet whether that points at the engine or simply at path tracing being the only workload here that reaches the relevant clock and voltage states.
If someone with a similar issue want to test this:
Please count hours, not sessions. My freezes were minutes to hours apart, so three good evenings prove nothing. I had three clean sessions in a row before I changed anything. As a rough rule: if your freezes average one per X hours, you want about 3x hours clean before the result means much.
When reporting, please include your GPU model, VBIOS version, driver version, and roughly how many hours you played with and without the cap.
A question to nVidia developers:
If this holds up, the pattern would point at the top of the boost curve rather than at load as such: the freezes happened in light scenes, where the card boosts highest, not under sustained path-tracing load, where it throttles to about 1750 MHz. Is there anything in the driver’s clock, voltage or power-state handling on AD103 laptop parts that would fit that shape?
