I am seeing invalid NVML / nvidia-smi power telemetry on an NVIDIA RTX 5000 Ada Generation Laptop GPU in a Dell Precision 7780.
System
- System: Dell Precision 7780
- GPU: NVIDIA RTX 5000 Ada Generation Laptop GPU
- PCI ID:
10de:2730 - Subsystem ID:
1028:0c42 - VBIOS:
95.03.2A.00.49 - System BIOS: Dell
1.29.0 - Distribution: Debian 13
- Kernel:
6.12.100+deb13-amd64 - NVIDIA driver:
550.163.01 - CUDA version reported by
nvidia-smi:12.4
The installed driver is the Debian-packaged NVIDIA driver, not a Dell-supplied graphics driver.
Problem
When the GPU is in PCI Runtime D3 suspend, Linux reports:
$ cat /sys/bus/pci/devices/0000:01:00.0/power/runtime_status
suspended
However, NVML / nvidia-smi reports physically impossible power values:
$ nvidia-smi --query-gpu=persistence_mode,power.draw,pstate,utilization.gpu --format=csv
persistence_mode, power.draw [W], pstate, utilization.gpu [%]
Disabled, 593.51 W, P0, 0 %
Other observed invalid values include approximately:
588.21 W
593.51 W
The reported power limits are:
Current Power Limit: 115.00 W
Default Power Limit: 115.00 W
Minimum Power Limit: 5.00 W
Maximum Power Limit: 145.00 W
The reported power draw is therefore far above the GPU’s configured maximum.
State during the invalid reading
- GPU utilization:
0 % - memory utilization:
0 % - no CUDA or graphics processes
- no process has
/dev/nvidia*open - Display Active:
Disabled - Display Mode:
Disabled - PCI runtime status:
suspended - no NVRM Xid errors
- no PCIe errors
The clocks and P-state also appear stale or invalid while suspended:
Performance State: P0
Graphics Clock: 1920 MHz
Memory Clock: 9000 MHz
Power Draw: 593.51 W
When the GPU is temporarily awake, plausible values such as approximately 9–37 W are reported. After it returns to Runtime D3 suspend, the invalid 588–593 W readings appear again.
Enabling persistence mode briefly produced plausible values, but the invalid readings returned later, so persistence mode is not a reliable workaround.
Reproduction
nvidia-smi \
--query-gpu=power.draw,power.draw.instant,pstate,utilization.gpu \
--format=csv
Typical result:
suspended
power.draw [W], power.draw.instant [W], pstate, utilization.gpu [%]
593.51 W, 593.51 W, P0, 0 %
Expected behavior
nvidia-bug-report_magister-primus_2026-08-01.log.gz (2.1 MB)
If power telemetry is unavailable while the GPU is in Runtime D3 suspend, NVML / nvidia-smi should return something such as:
N/A
Suspended
Not Available
It should not return an apparently valid numeric value above the GPU’s maximum power limit.
Possible improvements would be:
- return
N/Afor unavailable telemetry during Runtime D3 - mark power, clock, and P-state values as stale while suspended
- expose Runtime D3 state through NVML
- reject power values exceeding the reported maximum power limit
The current behavior can cause false monitoring alarms, invalid Prometheus or Grafana metrics, incorrect energy calculations, and confusion during diagnostics.
I understand that Runtime D3 behavior may also depend on OEM BIOS, ACPI, embedded-controller, or GPU-VBIOS implementation. If this is caused by Dell platform firmware rather than NVML, please advise which component should be reported to Dell.
I have generated an nvidia-bug-report.log.gz and can attach it if required.
