Hi, Nvidia team,
nvidia-bug-report.log.gz (258.5 KB)
When we use RTX 5000 to do inference on Ubuntu 16.04, we got GPU crash issue. The attached is the file generated by nvidia-bug-report.sh. Please help check it.
Harry
Hi, Nvidia team,
Harry
The main reasons may be:
Solution: update the driver;
The gpu is overheated. There are several solutions to this situation:
Change the system fan speed to manual control and increase the speed
Caused by insufficient power supply, this situation can only be solved by replacing the power supply with more power
Haonan,
Thanks your prompt reply.
You mentioned some solutions:
update the driver
increase the fan’s speed
use a more powerful power supply
I want to confirm if we only update to latest driver(460.32.03), we can resolve this issue, right? Or we also need increase fan’s speed/use a more powerful supply?
Harry
Haonan,
When I used nvidia-smi daemon to monitor devices, the result is written to a file with binary format. How can I read the data from binary format?
Harry
Just found “nvidia-smi replay” can replay the daemon file.
Hi Harry,
Thanks, Haonan.
Is there any side effect to enable persistence-mode?
And what temperature will GPU shutdown itself on?
Harry
Hi Harry
A: Persistence-mode does not affect the functionality
A:
RTX 5000 GPU target temperature: 83°C
RTX 5000 GPU slowdown temperature: 93°C
RTX 5000 GPU shutdown temperature: 96°C
Haonan,
We installed 460.32.03 version, and ran test again. Just reproduced the issue, we kept monitoring the temperature, it was just about 70C. So it should not be overheated problem.
The attached is the file generated by nvidia-bug-report.sh. nvidia-bug-report_011120.log.gz (358.4 KB)
Harry
