Hardware: Lenovo LOQ 15IRX10, RTX 5050 Laptop GPU (GB207M, 10de:2dd8), BIOS R3CN44WW, BIOS graphics mode Dynamic (other options: UMA, Discrete)
Software: Ubuntu 26.04, kernel 7.0.0-38-generic, nvidia-driver-595-open 595.91.07 (open kernel modules), GNOME
Module options (/etc/modprobe.d): NVreg_DynamicPowerManagement=0x02, NVreg_EnableGpuFirmware=0, NVreg_PreserveVideoMemoryAllocations=1
Problem: with nvidia-powerd not running, the driver reports a 35 W power limit in every Lenovo power mode (Quiet, Balanced, Performance, Custom).
nvidia-smi -q -d POWER: Current/Requested/Default 35.00 W, Min 5.00 W, Max 100.00 W.
nvidia-smi -pl 60: “Changing power management limit is not supported”.
Under load (glmark2 --off-screen via PRIME offload): draw about 34 W, “SW Power Cap: Active”, “SW Power Capping” counter rising.
With nvidia-powerd running, the limit follows the Lenovo mode: about 35-40 W Quiet, 55-70 W Balanced, 85-100 W Performance/Custom (I saw about 60 W of actual draw).
Kernel log at every GPU initialization:
NVRM: GPU0 nvAssertOkFailedNoLog: Assertion failed: Invalid data passed [NV_ERR_INVALID_DATA] (0x00000025) returned from PlatformRequestHandler failed to get target temp from SBIOS @ platform_request_handler_ctrl.c:2174
NVRM: GPU0 nvAssertOkFailedNoLog: Assertion failed: Invalid data passed [NV_ERR_INVALID_DATA] (0x00000025) returned from PlatformRequestHandler failed to get platform power mode from SBIOS @ platform_request_handler_ctrl.c:2117
/proc/driver/nvidia/gpus/0000:01:00.1… reports “Notebook Dynamic Boost: Supported”.
Questions: Is a 35 W default expected on this platform when nvidia-powerd is not running? Can the driver read the platform limit without the daemon? Is Dynamic Boost support for this model known to be incomplete?
Side observation: the “SW Thermal Slowdown” counter shows exactly the same value as “SW Power Capping” (twice).
Not tested: older drivers, Windows, other BIOS modes. In my journal nvidia-powerd ran at nearly every boot since Sep 20, so earlier I always saw mode-dependent limits; I disabled it to reduce idle power.
Attached: nvidia-bug-report.log.gz (taken with nvidia-powerd running), power-limits-*.txt, nvidia-kernel-messages.txt, modprobe-options.txt
