RTX 5060 (Blackwell): ~25% higher GPU load with DXVK 3.x, not reproducible on Ada (Enigma of Fear, 615.78.08)
GPU: RTX 5060 8 GB (Blackwell), driver 615.78.08, CachyOS, kernel 7.2.9-2-cachyos,
Ryzen 7 5700X, PCIe 3.0 x8.
Enigma of Fear (Unity, D3D11 via DXVK) with fog enabled is much more GPU-bound
with newer DXVK versions. Same Wine (GE-Proton9-27), only DXVK DLLs swapped,
same spot, 90 FPS cap, 60 s MangoHud captures:
DXVK v2.7.1: 89.0 FPS, 74% GPU load
DXVK v3.1.1: 76.1 FPS, 99% GPU load
DXVK v3.1.1 with legacy binding model forced: 82-86 FPS, 97-98% GPU load
The DXVK developer tested the same case on an RTX 4070 (Ada) and saw no
meaningful difference between DXVK versions with the legacy binding model,
and labeled it as an NVIDIA driver issue:
So the slowdown seems specific to Blackwell / this driver, likely in how it
handles the newer DXVK binding model and shader code.
Apitrace (D3D11, recorded in the affected area, replayable with any DXVK
version): https://drive.google.com/file/d/1lGznvM12R2CwVOn0CFtqa4KaWmzV3Yy9/view?usp=sharing
DXVK logs and MangoHud CSVs are attached to the GitHub issue above.
nvidia-bug-report.log.gz attached.
Repro: run Enigma of Fear (Steam AppID 1507580) via Proton with DXVK 3.x,
enable fog, compare GPU load / FPS against DXVK 2.7.1.
English is not my first language, I used an AI assistant to help translate
and format the data. All measurements are my own.
nvidia-bug-report.log.gz (961.9 KB)
