Recently installed a new RTX5060 Ti card on Arch Linux, and at the same time, upgraded driver to the latest 590.48. Getting regular freezes (sometimes after tens of minutes, sometimes a few hours) of my X session (XFCE) that require a reboot by pressing the power button on my PC. This often happens while the machine is idle (I turn my monitor off, walk away, and come back to find it no longer has a DP signal) though it has also happened while actively using the machine (though not under high load - just internet browsing).
Seems that this generally starts with something like the following (most recent entry at the top):
Jan 02 19:07:55 alpha kernel: NVRM: Xid (PCI:0000:01:00): 154, GPU recovery action changed from 0x0 (None) to 0x1 (GPU Reset Required)
Jan 02 19:07:55 alpha kernel: NVRM: Xid (PCI:0000:01:00): 62, 32344000 0000b670 00000000 206a7a8a 206a6c4a 206a6db8 206a52ae 206a5aca
Jan 02 19:07:55 alpha kernel: NVRM: GPU Board Serial Number: 0
Jan 02 19:07:55 alpha kernel: NVRM: GPU at PCI:0000:01:00: GPU-18919e58-bcb4-e2a2-d94a-e6b161282bc7
Have double checked board connections and tried re-seating the card to no avail. Since this issue requires a reboot I can only run the bug report in a new session.
nvidia-bug-report.log.gz (467.0 KB)
