| Item | Failing | Working 1 | Working 2 |
| GPU | RTX 5070 | RTX 2070 SUPER | Quadro T2000 Max-Q (4 GB) |
| Architecture | Blackwell | Turing | Turing |
| Driver | 616.92.0 | 610.88.0 | |
| Vulkan | 1.4.351 | 1.4.341 | 1.4.341 |
| OS | Windows 8 (6.2) | Windows 8 (6.2) | Windows 8 (6.2) |
| DXC | 1.9 | 1.9 | 1.9 |
| API path | Vulkan | same | same |
RTX 5070 / Driver 616.92.0: VK_ERROR_DEVICE_LOST (instruction-pointer fault) when a pixel shader samples a depth texture via a combined image-sampler (OpImageSample*). Same depth texture works via OpImageFetch (.Load). **Works on Turing (RTX 2070 SUPER, Quadro T2000 Max-Q).
Not OS-dependent** — reproduces on Windows 8 (6.2), same as on Windows 11. Not DXC-dependent — DXC 1.9 on all systems.
Validation: VK_LAYER_KHRONOS_validation is enabled on all systems and reports no errors before the fault on the RTX 5070. The command stream is spec-legal.
On RTX 5070 / 616.92.0, a pixel shader that samples a depth texture through a combined image-sampler (OpImageSample*) faults with VK_ERROR_DEVICE_LOST and an instruction-pointer fault at a driver-internal address (0x2000_...). The same image, layout, view, and pipeline read via texel fetch (OpImageFetch / .Load) works.
Fault does not occur on RTX 2070 SUPER / 610.88.0 or Quadro T2000 Max-Q / [version]. Not resource aliasing, not DSV, not MRT, not a missing barrier. The only variable is sampled read vs fetch read, and the fault is Blackwell-specific.
Vulkan validation layers are enabled and silent — the fault is at the driver/hardware level, not an API misuse.
Minimal Reproduction
hlsl
// Bound: depth texture as SRV, one color RT, no DSV.
// FAULTS on RTX 5070 / 616.92.0:
float fDepth = DepthTexture.SampleLevel(DepthSampler, uv, 0).r;
// WORKS on RTX 5070 / 616.92.0, same image, same layout:
float fDepth = DepthTexture.Load(int3(int2(uv), 0), 0).r;
Same VkImage, same layout, same VkImageView. Only the SPIR-V op differs: OpImageSample* vs OpImageFetch.
Error Output
text
<ERROR>: DxvkDevice: waitForIdle: Operation failed: -4
-> GPU fault description:
-> Fault address 0: 35184372088832 (0x200000000000)
-> Type: VK_DEVICE_FAULT_ADDRESS_TYPE_INSTRUCTION_POINTER_UNKNOWN_EXT
-> Precision: 16
-> Fault address 1: 35184390134192 (0x20000013F2B0)
-> Precision: 16
-4 = VK_ERROR_DEVICE_LOST. Fault addresses are in the driver-internal 0x2000_... range (not application-allocated memory). Fault type is instruction fetch, consistent with pipeline/state desync.
Steps to Reproduce
Depth texture + depth
VkImageView. -
VkSampler(no compare, nearest, clamp). -
Pipeline: fragment shader samples depth via combined image-sampler (
texture()/OpImageSample*). -
Bind one color render target (no DSV).
Draw full-screen quad.
Fault +
VK_ERROR_DEVICE_LOSTon RTX 5070.GPU Arch Driver Result RTX 5070 Blackwell 616.92.0 Fault RTX 2070 SUPER Turing 610.88.0 Works Quadro T2000 Max-Q Turing [version] Works Blackwell-specific. Not OS- or DXC-dependent. Validation-clean.
Notes
Deterministic, 100% reproducible.
Blackwell-specific: two Turing systems (desktop + mobile Quadro) unaffected.
Validation layers enabled and silent on all systems — the fault is not an API misuse.
Reproduces in multiple independent shaders in the same application.
Sampling depth is a common operation; failing only on Blackwell suggests a driver regression or stricter check introduced for the new architecture.
