RTX 5080: reproducible Xid 120 GSP display task fault at fixed PC when VRR enabled (4K@240 + DSC, LG 32GS95UE, 610.57.04)
Enabling VRR reproducibly crashes the GSP display task on my RTX 5080. Three GPU resets within ~20 minutes; completely stable since disabling it. ## Fault (identical all three times, only pid varies) NVRM: Xid (PCI:0000:01:00): 120, pid=1431, name=DP-3, GSP task exception: load access page fault (cause:0xd) @ pc:0x1b9b526, partition:4#0, task:3, gfid: 0 NVRM: Xid (PCI:0000:01:00): 154, GPU recovery action changed from 0x0 (None) to 0x1 (PF FLR) The fixed fault PC across all occurrences suggests a deterministic code path rather than transient instability. ## Aftermath kwin_wayland dumps core inside libnvidia-eglcore during KWin::GLFramebuffer::blitFromFramebuffer. Session restart then fails in a loop: NVRM: GPU0 vaspaceapiConstruct_IMPL: Could not construct VA space. Status 62 nvidia-modeset: ERROR: GPU:0: Failed detecting connected display devices Recovery requires a full reboot. ## Trigger Enabled Adaptive-Sync in the monitor OSD and set KWin vrrpolicy=automatic. All three crashes occurred at 3840x2160@240 (DSC required at this mode), display scale 1.25. Disabling VRR in both places resolved it completely. VRR at the panel’s 1920x1080@480 dual mode is untested. ## System GPU: RTX 5080 (GB203) Driver: nvidia-open 610.57.04 Kernel: 6.x / linux-cachyos-nvidia-open 7.2.0-1 (CachyOS) Desktop: KDE Plasma, Wayland (KWin) Monitor: LG 32GS95UE, DisplayPort, dual-mode (4K@240 / 1080p@480) Note: kernel 7.2.0 had been stable for two days prior to enabling VRR nvidia-bug-report.log.gz attached.
nvidia-bug-report.log.gz (539.5 KB)
Hi @cengiz.mak01
Thanks for highlighting the issue, I have filed a bug 6656633 for tracking purpose.
Will try to duplicate issue in-house and will get back if required any additional information.
Second system, same fault at the same PC — RTX 5070 Ti (GB203) + ASUS PG34WCDN 3440x1440@360 DSC
I hit what looks like the identical bug on different hardware. My Xid line matches yours byte-for-byte in PC, partition and task:
NVRM: GPU0 kgspHealthCheck_TU102: ****** GSP-CrashCat Report ******
NVRM: Xid (PCI:0000:09:00): 120, pid=1895, name=DP-1, GSP task exception:
NVRM: Xid (PCI:0000:09:00): 154, GPU recovery action changed from 0x0 (None) to 0x1 (PF FLR)
System
  • RTX 5070 Ti (GB203, same silicon as OP’s 5080), driver 610.57.04 (nvidia-open)
  • Kernel 7.2.0-1-cachyos, Plasma 6.7.4 / KWin 6.7.4, Wayland
  • ASUS ROG Swift OLED PG34WCDN over DisplayPort, 3440x1440 @ 360 Hz, DSC
Five faults so far, all identical PC. Two name= variants appear: DP-1 and kwin_wayland.
Trigger — it is VRR being enabled, not the enable/disable transition. This may be worth adding to the internal bug, since it widens the repro:
  • vrrPolicy=Automatic: alt-tabbing out of a fullscreen Steam game faulted ~35 s after the game started rendering. Reproduced on separate days.
  • vrrPolicy=Always, with no policy changes during the session at all, plain desktop and browser use: faulted ~23 min into one session and ~4 min into the next. So it is not confined to the VRR_ENABLED modeset.
  • vrrPolicy=Never: zero faults, including repeatedly alt-tabbing in and out of the same game that reliably crashed under Automatic.
Downstream damage (why this costs the whole session on KDE): the GPU reset kills KWin’s GL context, and the builtin blur effect’s next GLFramebuffer::blitFromRenderTarget runs on the dead context → GL_OUT_OF_MEMORY → SIGSEGV in libnvidia-eglcore. KWin then restart-loops because eglInitialize returns EGL_NOT_INITIALIZED — about 10 crashes in 4 seconds, session gone. Disabling the blur effect removes the segfault path but obviously not the GPU reset.
Ruled out: VRAM clock ramping. Since clock transitions are a known VRR-flicker mechanism, I locked them with nvidia-smi -pm 1 && nvidia-smi -lmc 14001 and verified it applied (clocks.current.memory = 14001 MHz, versus 810 MHz at idle). The fault still occurred. Not a P-state transition issue.
Possible regression window: my package log shows nvidia-utils 610.43.03 → 610.57.04 on 2026-08-08, and the GSP firmware blob ships in that package. I have no recollection of this before that upgrade, though my journal retention doesn’t reach back far enough to prove absence.
Common factors between our two reports: GB203, DSC, high-refresh DP, KDE Wayland. Happy to attach nvidia-bug-report.log.gz or run any repro you’d like — the fullscreen-game alt-tab case reproduces in well under a minute here.
Same failure here on a desktop RTX 5080 — but with an essentially idle desktop,
no CUDA, no gaming, no video encode. That may be a useful data point, since most
reports so far involve sustained compute or Vulkan load.
Config:
GPU : RTX 5080 (GB203, 10de:2c02)
Driver : nvidia-open-dkms 610.57.04
Kernel : 7.1.9-arch1-2 (Arch Linux)
Desktop : Hyprland 0.56.2 (Wayland), single DP ultrawide 5120x1440@60, VRR off
IOMMU : AMD-Vi enabled
Uptime : ~30 h at time of failure (first extended run on this kernel)
Workload at the moment of the fault: plain desktop compositing. The compositor’s
log ends with nothing but libinput events and hardware cursor buffer imports.
Sequence:
NVRM: Xid 62, name=Hyprland
NVRM: _kgspRpcGspEventPmuHalted: Received signal from GSP that PMU has halted.
NVRM: Xid 154, GPU recovery action changed from 0x0 (None) to 0x1 (PF FLR)
GSP task watchdog timeout @ pc:0x1b6646a, partition:4#0, task:3, gfid: 0
Reported by libos partition:4#5 kernel v3.1
scause:0x8000000000000005 (supervisor timer interrupt)
0x01450900:0xbadf5100 (PRI poison read)
Then, every ~2 minutes for the next two hours (67 times):
NVRM: GPU0 kgspHealthCheck: GSP-CrashCat Report
NVRM: Xid 109, channel 0x00000002, errorString CTX SWITCH TIMEOUT, Info 0x14007
nvidia 0000:2d:00.0: AMD-Vi: Event logged [IO_PAGE_FAULT domain=0x001b
address=0xd7c76058 flags=0x0020]
The PF FLR never completed. nvidia-smi then reported “GPU requires reset” and
ERR! for fan/temp/power, with no process holding the GPU. Module refcounts were
zero. Only a full reboot recovered the card; it has been healthy since.
One detail that might help narrow down the scope: the display engine kept working
the entire time. The fbcon console on nvidia-drmdrmfb stayed fully readable and
the monitor kept scanning out normally. Only GSP and graphics-channel context
switching were dead — every EGL client failed immediately with EGL_BAD_ALLOC from
eglQueryDevicesEXT and eglInitialize “DRI2: failed to create screen”. The
compositor aborted inside its GL init, and the display manager’s greeter then
crashed the same way, so the machine was left with a black screen but a working
text console. That suggests the fault is confined to GSP plus the graphics
channels and does not reach the display path.
Hi All,
Internal testing update:
Tested on Alienware Aurora R15 (AMD Ryzen 9 7900X) with RTX 5070 Ti, NVIDIA driver 610.57.04, and LG 32GS95UE connected through DisplayPort at 3840×2160 @ 240 Hz (125% scale).
Adaptive-Sync was enabled in the monitor OSD. Under Plasma Wayland, KWin VRR was tested with both Automatic and Always policies. Crysis 3 Remastered was run for several minutes (~67% GPU utilization and ~4 GB VRAM), followed by continuous Alt+Tab switching between the game and Konsole for approximately one hour.
No Xid errors or GPU reset were observed in either VRR configuration.
I will continue to perform experiments.
Meanwhile, can anyone please share a reliable or shortest sequence that triggers the issue on your system, including the approximate time to failure? In particular, please clarify whether it also occurs during idle desktop usage or requires a game/workload and focus switching.
I think i am having a similar issue, in the last two days had two crashes pressing the ESC button with Firefox open in full screen
EDIT: Not sure, think it could be related to using “Prefer color precision” in KDE settings
Same bug here — RTX 5080 + MSI MPG 491CQPX (5120x1440@240, DSC), with a reliable repro.
System: RTX 5080, nvidia-open 615.71.09 AND 615.78.08 (both affected), CachyOS, kernel 7.2.9, KDE Plasma 6.7.5 Wayland, HDR on or off (no difference), MSI MPG 491CQPX QD-OLED over DisplayPort (monitor firmware FW.024).
Repro (crashes within a few tries): KWin Adaptive sync = Automatic → Spectacle in rectangular-region mode (Flameshot does the same) → select a region → press Copy or Save. The moment the fullscreen overlay closes, the GPU faults. Matches the “ESC out of fullscreen Firefox” report above: the trigger seems to be a fullscreen surface going away while VRR is active.
Log (615.71.09):
NVRM: Xid (PCI:0000:01:00): 120, pid=1741 (kwin_wayland), name=DP-1, GSP task exception: load access page fault (cause:0xd) @ pc:0x1bd8e88, partition:4#0, task:3, gfid: 0
NVRM: GPU0 krcRcAndNotifyAllChannels_IMPL: RC all user channels for critical error 120.
kwin_wayland: A graphics reset attributable to the current GL context occurred.
kwin_wayland: GL_OUT_OF_MEMORY error generated. Failed to allocate memory for buffer object.
kwin_wayland: segfault … in libnvidia-eglcore.so.615.71.09
On 615.78.08 the same fault was at pc:0x1bd92d8. Afterwards EDID can’t be read and “Failed to query display engine channel state” repeats every 10 s; only a reboot recovers.
Workaround: Adaptive sync = Never → no crashes for 2+ days of normal use, on both drivers.
Happy to provide an nvidia-bug-report.log.gz if it helps bug 6656633.
