RTX 5090 / AMD X870E: recurring Xid 79 + 154 at load and idle, with per-pin telemetry
I am reporting recurring RTX 5090 Xid 79 / Xid 154 failures on an AMD X870E system, with preserved kernel logs, connector telemetry and a review of the matching driver source. A potentially related report is open-gpu-kernel-modules issue #1495, but I have not established that these have the same underlying cause.
The preserved logs contain at least 10 distinct Xid 79 episodes over several days, after deduplicating mirrored logs, startup replay and repeated messages from the same incident. Failures have occurred during GPU training, a standalone PyTorch matrix-multiplication test, and an idle/rest period. The latest incident was captured with continuous telemetry mirrored to a second machine, including individual GPU connector power-pin readings.
The evidence establishes abrupt GPU/device accessibility loss. It does not yet distinguish a card-side power/reset fault, a PCIe/platform problem, or a shared NVIDIA driver/firmware interaction. There is no confirmed root cause or confirmed fix.
Hardware and software
Component Recorded configuration
GPU ASUS ROG Astral GeForce RTX 5090 OC, 32 GB, GB202
PCI hardware identifiers NVIDIA 10de:2b85; ASUS subsystem 1043:89e3; revision a1
CPU AMD Ryzen 9 9950X3D
Motherboard Gigabyte X870E AORUS ELITE WIFI7
BIOS F11
RAM 64 GB, 2 × 32 GB Corsair CMK64GX5M2B6400C32; part number does not establish the active memory speed
PSU Seasonic PRIME 1300 W; owner identifies the upgraded model with a native 16-pin GPU socket. Exact model suffix is not independently recorded
Kernel at the detailed incident 7.0.0-38-generic
Loaded NVIDIA module at that incident NVIDIA UNIX Open Kernel Module 595.99.02
Workload categories PyTorch/CUDA machine-learning training with GPU simulation; separate ordinary FP16 GEMM; desktop/idle periods
The history also contains failures with the 615 driver branch loaded. Earlier 580-series reports have less comparable evidence and are not being presented as equivalent controlled tests. One historical failure occurred after another driver version had been staged on disk but before it was loaded; the running-module version, not the installed package alone, was used for attribution.
There is no controlled open-versus-proprietary module comparison here, and I am not claiming that an open-module-only defect has been demonstrated. This is also a different CPU/platform and a different latest driver version from the linked issue report.
What was captured
The detailed capture used approximately 5 Hz reads of six connector power-pin voltage/current channels, approximately 1 Hz NVML and additional thermal readings, continuous kernel journal and kernel UDP logging, and periodic host/PCIe runtime-PM/AER/health snapshots. The per-pin controller’s original bytes were retained alongside decoded values. GPU telemetry performs real driver-mediated reads; it is not a passive electrical measurement.
At the first GPU fault, the recorder preserved the event and intentionally stopped its GPU-reading processes. CPU, kernel and transport capture continued. Consequently, the GPU-reader exits after the fault are intentional capture behavior, not three additional hardware failures.
The exact resumed workload interval before the latest Xid was about 119.84 seconds. It contains 599 connector frames, 120 NVML samples and 120 thermal samples. Whole-session extrema are kept separate from this incident interval below.
Latest failure sequence
T=0 is the kernel journal’s Xid 79 realtime timestamp. Values below use the source machine’s relevant recorded realtime fields; timestamp precision is not a measurement of the physical failure edge.
Time relative to Xid 79 Observation
T−194.682 ms Last successful six-pin voltage/current frame
T−166.330 ms Most recent completed display-control RPC in the driver’s saved history
T−0.032 ms Start timestamp of the active I2C transaction in that history
T Xid 79: GPU has fallen off the bus
T+2.441 ms Connector telemetry read reports OSError 5 / Input/output error
T+2.693 ms Xid 154 changes the recovery action to Node Reboot Required
T+8.993 ms Capture hold record written; GPU-reading processes are stopped
By approximately T+211 ms All three GPU readers have exited intentionally
T+320.487 ms Buffered Xid 79 journal record reaches the recorder
Approximately T+22.75 s Last preserved CPU/platform record from that boot
Selected recorded messages, with machine/process identifiers and sequence numbers replaced by placeholders:
NVRM: Xid (PCI:<GPU>): 79, pid=<telemetry-reader>, name=python3, GPU has fallen off the bus.
NVRM: Xid (PCI:<GPU>): 154, GPU recovery action changed from 0x0 (None) to 0x2 (Node Reboot Required)
NVRM: GPU0 _issueRpcAndWait: rpcSendMessage failed with status 0x0000000f for fn 78 sequence <redacted>!
NVRM: GPU0 RmLogGpuCrash: RmLogGpuCrash: failed to save GPU crash data
CPU/platform logging continuing for about 22.75 seconds rules out an instantaneous whole-host power loss at the first GPU fault. It does not rule out a GPU-only power, slot, card or reset event. The later host shutdown/reset cause is not established by these records. Xid 154 describes the requested recovery class; it does not prove that the driver itself rebooted the host. See NVIDIA’s Xid documentation.
Connector voltage, current sharing and power
These are the six power-channel indices used by the community decoder. Physical pin orientation and sensor calibration were not independently established. They are not measurements of the ground-return contacts.
Channel Last current, A Peak current, A Last voltage, V Minimum voltage, V Mean current, A
1 2.38 3.56 12.048 12.032 1.719
2 2.36 3.56 12.048 12.024 1.711
3 2.46 3.70 12.048 12.032 1.782
4 2.60 3.90 12.032 12.016 1.876
5 2.56 3.90 12.032 12.016 1.874
6 2.50 3.78 12.040 12.016 1.819
All six peak currents occurred about 29.6 seconds before the fault, at a measured connector total of 22.4 A / 269.30 W. The final frame totals 14.86 A / 178.93 W. The final few seconds were approximately 177–180 W at the connector.
The largest observed channel-to-group-mean ratio, restricting the group mean to at least 1 A, was 1.153. That frame’s highest channel was 1.86 A with a 0.50 A spread. The final 10 seconds had a 0.20–0.24 A spread. No recorded channel went to zero or crossed the recorder’s configured 9.2 A / 10.8 V alarm thresholds. Those thresholds are software alarm settings, not a complete connector safety specification.
The largest sample gap in this interval was 0.202969 seconds. An independent decode of all 5,852 pin frames in the containing segment reproduced the recorded values from raw controller bytes with zero disagreements. That validates the decoding consistency, not sensor calibration or the absence of faster electrical events.
This does not show one pin carrying most of the load, a sustained sampled undervoltage, or a sampled overcurrent event. It cannot exclude an intermittent contact, a ground-return problem, a very short supply disturbance, a hot contact, slot power trouble or an on-card fault.
Two auxiliary electrical channels remain physically unidentified. One often resembles half the six-channel total and reached 10.98 A; it must not be reported as a seventh pin carrying that current. Eight auxiliary temperature channels also have unverified physical locations. Candidate state/time counters were not established to be hardware-error counters; their lack of a reset in the final interval is not proof against a hardware event.
Thermals, VRAM and operating state during the same interval
Measurement Observed value
NVML board power Peak 311.935 W; last 182.069 W
NVML GPU temperature Maximum 59 °C
Community-decoded internal GPU temperature maximum Peak 63.5625 °C; last 60.625 °C
Hottest reported memory channel Peak 70 °C; last 66 °C
Device memory used Maximum 27.543579 GiB
Device memory free Minimum 4.299194 GiB; approximately 4.301 GiB at the last sample
Performance state P1 in 119 of 120 samples; first sample P8; all final-minute samples P1
Final NVML utilization/clocks 90% GPU utilization; 2947 MHz graphics; 13801 MHz memory
Final-minute clock-throttle reason mask No bits set in the recorded samples
Board power and the connector-derived power are different measurements with different timing and coverage; they should not be equated sample for sample.
The internal temperature readings are community-decoded driver data, not an independently calibrated factory hotspot measurement. The reported memory slots include aliases of 16 physical packages; they are not 32 separate chips. Only 12 internal die-sensor entries were valid. Unsupported/null entries were not treated as zero temperatures.
The driver’s cached core/memory thermal values were roughly 1.4 seconds old at read time. Polling them once per second does not make them instantaneous. There was no sampled thermal runaway, recorded low-memory emergency or logged application OOM before this loss. That does not rule out a VRAM defect or unobserved driver/firmware/allocator failure.
Earlier in the same capture session, a separate disposable test reached approximately 135.44 MiB sampled free VRAM. That was more than two hours earlier; substituting that whole-session minimum for the later fault interval would be misleading. No causal link between that earlier pressure and this bus loss has been established.
Host, PCIe and display observations
GPU and root-port runtime-PM bookkeeping remained active with zero runtime-suspended time around the fault. These software fields do not measure internal clock gating, physical reset lines or continuous electrical connectivity. The detailed current capture did not measure instantaneous PCIe speed/width at the failure edge.
Sampled GPU AER counters stayed at zero. Root-port AER counters were unavailable in this capture. Unlike the linked issue report, I cannot demonstrate a corresponding RxErr burst on this system. Zero endpoint counters do not rule out masked reporting, an unsampled final error or an endpoint disappearing before reporting.
Host available memory stayed above approximately 37.67 GiB; HardwareCorrupted was zero. Memory and I/O pressure avg10 were zero in the interval. CPU temperature peaked at 77.25 °C and was 55.875 °C at the final sample. Both NVMe devices continued to report zero critical warnings, media errors and error-log entries, including after the GPU fault. Storage had hundreds of GiB free. No host-memory or disk-exhaustion trigger was identified.
The captured RAS trace buffers showed no errors or reported overruns around this incident. That statement applies to the covered tracepoints, not to every possible hardware failure path. Display snapshots showed no connector/EDID change in the workload interval; a desktop browser GPU process already existed beforehand, without a newly identified coincident hotplug event.
What the matching driver source establishes
The analysis used official tag 595.99.02, commit e394a404108a9ce5bba988c1dddf694dabbd4a43. Selected downloaded source files were verified against the official Git blob identities. This was source inspection, not a custom driver build or replacement.
Status 0x0000000f is NV_ERR_GPU_IS_LOST. The recorded stack includes rm_i2c_transfer, an SMBus ioctl, RM control and GSP RPC. The Linux SMBus read wrapper can return -EIO when the underlying RM operation fails, so the connector reader’s I/O error can be a consequence of device loss rather than an independent physical SMBus failure. Sources: status definitions, NVIDIA I2C implementation (kernel-open/nvidia/nv-i2c.c at the same revision).
The active control 0x402c0105 is NV402C_CTRL_CMD_I2C_TRANSACTION. The recently completed control 0xc3700104 is display GET_CHANNEL_INFO. Sources: I2C control definition (src/common/sdk/nvidia/inc/ctrl/ctrl402c.h at the same revision), display control definition (src/common/sdk/nvidia/inc/ctrl/ctrlc370/ctrlc370chnc.h at the same revision).
The recorded RPC error follows the _kgspRpcSanityCheck failure branch before ordinary RPC wait-timeout classification. Heartbeat/history diagnostics also run on that failure path. Post-loss CurrentTimeMs=0 and heartbeat=0xffffffff therefore do not independently prove a preceding firmware stall. The recent completed display RPC and active I2C start support a rapid transition in observed accessibility; they do not measure the physical failure duration. Failed crash-dump calls precede the displayed function-78 buffer, so that buffer is not evidence of an unrelated original operation causing the fault. Relevant implementation: kernel_gsp.c.
The PID named by the Xid belongs to the telemetry reader that detected the loss. That does not prove the reader caused it. Conversely, the logs cannot exclude an observer-related driver/firmware interaction. Earlier bus-loss incidents surfaced through nvidia-smi, nvidia-settings, nvidia-modeset and watchdog paths, so this particular connector reader is not necessary for the historical failure pattern.
Historical PCIe/configuration evidence
Three earlier incidents have preserved post-fault PCI configuration snapshots. Nine complete 4096-byte images were independently reconstructed from the original compressed reports. In all three cases, the upstream root port remained configured with Command=0x0407, while both the GPU function and its audio function had Command=0 and cleared BAR base addresses. Some BAR attribute bits remained; saying every BAR dword was zero would be inaccurate. The recorded GPU BAR dwords were [0, 12, 0, 12, 0, 1].
This is a shared endpoint/configuration-loss signature affecting more than a single CUDA context. However, these are post-fault snapshots: driver cleanup can also change PCI configuration. They do not, by themselves, prove a spontaneous physical reset or identify its cause. An equivalent new PCI configuration probe was not performed after the latest fault, so this remains historical corroboration.
In an earlier standalone 8192×8192 FP16 torch.mm failure, captured root-port link events changed among Gen3/Gen4/Gen5 ×16 with link-training set and Data Link Layer Active clear before native Xid 79. The last such event preceded Xid 79 by approximately 706 ms. Healthy comparison events retained Data Link Layer Active. Covered reset/runtime-suspend hooks did not fire first. Uninstrumented firmware or physical reset paths remain possible, and varying historical lane-error bits do not identify a particular bad lane.
That standalone GEMM observation matters because the training application, simulation framework, custom kernels and torch.compile were not necessary to reproduce the failure class. It is not a deterministic reproducer or proof that all incidents share one initiating mechanism.
Another failure occurred after the GPU/power connector had been reseated, on 595.99.02, approximately 47.24 seconds after the last query while a test was in a rest period. It surfaced in nvidia-modeset. The last query showed 41 °C, P8, 12.20 W, Gen1 ×16 and no replay count. Those values precede the fault by about 47 seconds; they are not instantaneous readings at the failure edge. They nevertheless show that the history is not confined to sustained high-load operation.
Failures have also been observed under persistence/D0 conditions. This does not prove that all power-management paths were disabled, nor that ASPM or internal GPU gating has been conclusively ruled out.
Logging as a possible observer effect
It is plausible that repeated telemetry changes scheduling, driver-lock contention, GSP serialization or power-state residency. Low sampled CPU overhead would not rule those effects out.
But detailed logging did not eliminate the failure: the latest Xid occurred with all readers active. While that logging was active before the workload resumed, the GPU still visited P5 and P8. The final minute before the fault was P1, with no observed runtime suspension. This does not support a simple claim that logging permanently keeps the GPU awake, or that failure only happens when the GPU is idle. A narrower transition/race hypothesis remains possible. There is no controlled logging-on/logging-off comparison isolating these effects from driver, workload, boot and physical handling changes.
Whole-history sensor checks and misleading extrema
The primary raw history contains 1,017,550 six-pin frames across 13 recorder sessions. The largest sampled individual-channel current was 4.02 A. No primary pin frame crossed the configured overcurrent/undervoltage thresholds, and no zero-current channel was observed. These are statements about recorded samples, not bounds on unsampled transients.
Fourteen isolated voltage anomalies were found: eight readings of 11.776 V and six of 12.280 V. Every anomaly was verified against the original raw bytes and its neighboring frames. Each was a one-frame excursion between adjacent normal values of 12.024 V and 12.032 V:
Adjacent normal words: 0x2ef8 and 0x2f00
Anomalous words:       0x2e00 or 0x2ff8
Every anomalous word exactly combines the high/low bytes of its neighbors in the corresponding transition direction. That strongly suggests a non-atomic sensor update/read, but it is an inference rather than proof of the controller’s implementation. The readings were retained, not filtered away. The latest anomaly was more than four hours before the bus loss, with none in the fault segment. Reporting the whole-history 11.776 V minimum as a pre-crash voltage sag would therefore be misleading.
The latest recorder session spans approximately 16.38 hours and 592,417 records, including 294,549 pin frames, 58,925 NVML samples and 58,926 thermal samples. Its whole-session peaks were 317.303 W NVML power, 62 °C NVML core, 68.5 °C decoded internal maximum and 70 °C hottest memory channel. These are distinct from the exact incident-interval values above.
Clock, capture and integrity limitations
A roughly 2.516-second difference between journal source-monotonic time and receipt/CLOCK_MONOTONIC initially resembled a stall. Earlier ordinary messages showed the offset already changing smoothly; a fit of 11 preceding messages predicted the fault-time difference to within about 0.16 ms, with approximately 13.8 ppm drift. There is no evidence here for a newly introduced 2.5-second stall. Upstream printk (Linux v7.0, kernel/printk/printk.c) and journald (systemd v255, src/journal/journald-kmsg.c) use distinguishable source/receipt clock paths; exact distribution patches were not independently reconstructed.
The second machine’s UDP arrival timestamps belong to another host clock. Their numerical ordering against the source machine’s timestamps was not treated as physical causal ordering.
All 13 primary recorder sequence ranges are contiguous. The latest fault segment contains 12,947 records with no sequence gap or parse error. There are 1,145 preserved kernel records after the Xid, mostly describing consequences of the lost GPU. Contiguous recorder records do not prove that every upstream kernel event was emitted or received.
UDP sequence gaps exist in the failure burst. The journal recovers many messages missing from UDP, but a perfect all-message reconstruction is not claimed. Historical audit suppression also means process-execution attribution is incomplete.
After reboot, the source machine’s retained final file was 4,385 bytes shorter than the second machine’s copy. The entire shorter file hash matched the corresponding prefix of the longer copy. The second machine had preserved one additional complete platform record. This was an identified local-tail persistence difference, not evidence that the retained off-machine log was corrupt; neither copy was overwritten to hide the mismatch.
The broader review scanned approximately 11 million text/log lines, verified 216 archived raw-log members against original sizes/hashes, and checked selected nested log/status evidence. Duplicate mirrors were not counted as independent incidents. Older incomplete/null tails, deliberately clipped mid-record excerpts and synthetic malformed-file test fixtures were identified separately. Source/build binaries were inventoried and hashed, not claimed to have all been semantically audited or executed.
The internal GPU crash-data save failed. There is no complete internal GSP/GPU dump available from this incident. The capture also lacks PSU-internal telemetry, AC waveforms, physical reset signals, calibrated slot-rail transient measurements, ground-return currents, per-contact temperatures and some motherboard/DIMM channels. A 5 Hz software sensor cannot resolve the final microseconds.
A separately reproduced application indexing assertion produced Xid 43 earlier. That event is not included in the 10 Xid 79 episodes. Other application validation failures and capture-management problems were likewise not counted as evidence of GPU bus loss.
What remains unresolved
The leading unresolved possibilities are a card-side power/reset/internal availability fault, a PCIe/slot/root-complex/board fault, or a shared NVIDIA driver/GSP/power-state interaction. The observations do not justify assigning a confident ordering or percentage probability to them.
There is less support for sustained single-pin overload, sampled thermal runaway, ordinary host-memory exhaustion or a training-application-specific exception as the explanation for this repeated device-wide loss. These narrower findings do not clear the PSU, cable, GPU or motherboard, and failure across driver branches does not prove a hardware-only cause.
I would appreciate guidance on whether the sanity-check GPU-lost path, the earlier link-training/DLL-active changes and the shared GPU/audio configuration loss match a known GB202 failure mechanism. In particular, what supported evidence would distinguish an initiating firmware failure from a physical card/link/reset event when the GPU is already inaccessible and RmLogGpuCrash cannot save its internal state?
The underlying logs have been retained. This report intentionally includes selected sanitized findings rather than raw diagnostic archives, which contain machine and environment identifiers.
RTX 5090 on AMD B850: Xid 79/154 across three drivers and two models
My RTX 5090 repeatedly becomes inaccessible during CUDA workloads on Ubuntu. The kernel reports Xid 79, followed by Xid 154 and a required reboot.
The failures occurred with drivers 580, 595 and 615, and with two different models. They also occurred at Gen5 and at Gen4. One failure occurred during a standalone PyTorch matrix test, before any model loaded. I do not know the cause.
Power cabling
The GPU adapter has four 8-pin inputs. Two cables run from the PSU, and each cable supplies two plugs. All four adapter inputs are connected.
I previously described this as four cables. That description counted the plugs, rather than the separate cables from the PSU. All tests used this arrangement. I did not test four independent cables or a replacement PSU.
Component Configuration
GPU MSI GeForce RTX 5090 32G GAMING TRIO OC, 32 GB, GB202. MSI model G5090-32GTC
PCI IDs NVIDIA 10de:2b85. MSI subsystem 1462:5303
CPU AMD Ryzen 9 9950X, 16 cores / 32 threads
Motherboard Gigabyte B850M AORUS ELITE WIFI6E ICE
PCB revision Not physically checked. DMI reports x.x
BIOS F3, March 12, 2025
RAM KLEVV CRAS V RGB 64 GB, 2×32 GB. KD5BGUA80-60A300J
RAM rating DDR5-6000 CL30, 1.35 V. Active speed and EXPO setting not independently checked
PSU Reported EVGA 1000 GQ, 1000 W. Supplied purchase link identifies 210-GQ-1000-V1. Label and age not yet checked
GPU power Supplied GPU adapter and PSU cables. Four adapter inputs fed by two branched PSU cable runs
GPU installation Directly in motherboard slot. No riser
Overclocking No user-applied overclocking reported. Factory OC settings retained
OS Ubuntu 26.04.1 LTS
Kernel 7.0.0-38-generic
Current driver Ubuntu-packaged 615.71.09 open kernel module
PyTorch 2.9.1+cu128
Transformers 5.21.0 in an isolated runtime
GPU power limits Default 575 W. Reported supported range 400–600 W
Current BIOS slot setting Gen4. 16 GT/s ×16 observed on GPU and upstream root port during a diagnostic
The PyTorch CUDA suffix identifies its build, not a separately installed toolkit version.
MSI specifies 575 W GPU power and recommends a 1000 W PSU with ATX 3.1 support. NVIDIA specifies four independent dedicated cables for its reference RTX 5090 adapter. My arrangement differs from that guidance. Please advise on the requirements for the supplied MSI adapter before I run more stress tests.
Symptoms and recovery
A healthy boot can detect the GPU and pass short CUDA checks. Subsequent inference can still cause abrupt device loss. A representative failure is:
NVRM: Xid (PCI:0000:01:00): 79, GPU has fallen off the bus.
NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
NVRM: Xid (PCI:0000:01:00): 154, GPU recovery action changed from 0x0 (None) to 0x2 (OS Reboot)
Python typically reports AcceleratorError: CUDA error: unspecified launch failure. CUDA errors can appear after the operation that caused them. The Python traceback therefore does not identify the cause by itself.
A software reboot does not always restore GPU access. A full shutdown, followed by disconnecting and reconnecting power, restored access on later boots. The failures then returned.
On one intervening boot, no NVIDIA device appeared anywhere in lspci, while AMD integrated graphics remained visible. Kernel logs repeatedly said NVRM: No NVIDIA GPU found. The installed driver module existed for the running kernel, but no NVIDIA module remained loaded. A subsequent boot detected the 5090 again. No model or CUDA test ran during the missing-device boot.
Driver versions and attempted remedies
Configuration/test Recorded outcome
580.178.04 server-open Repeated Xid 79/154 during original inference/evaluation workloads
595.99.02 open Repeated failures, including standalone CUDA and model inference
615.71.09 open Repeated failures, including Gen4 and alternate-model tests
Full shutdown/power cycle Restored access on later boots. Did not prevent recurrence
595: reduce GPU limit from 575 W to 400 W Short checks passed. Inference failed before its first batch completed
595: retain 400 W and request graphics clocks 2200,2200 MHz Lock command succeeded. Approximately 2197 MHz observed before load. Inference still failed
595: cold start with default 575 W and experimental profiles disabled One inference batch completed before failure during the next
615: default 575 W One run completed 113 batches over approximately 323.5 seconds. A fresh-boot retry completed no batches
615: BIOS Gen4, default 575 W Both short checks passed. Observed 16 GT/s ×16 on GPU/root port. Inference failed before its first batch completed
615: second model, after Gen4 was selected 299 batches over approximately 224.55 seconds, then Xid 79/154
The GPU rejected the initial 300 W request because its minimum supported limit is 400 W. No test used a 300 W limit.
The clock-lock command succeeded. The observed graphics clock before load was about 2197 MHz. I did not measure its exact frequency at failure. The clock experiment changed neither memory clocks nor voltage offsets.
The power and clock experiments preceded the separate Gen4 test. The Gen4 test used 575 W, with both experimental startup services disabled.
For the later driver tests, I checked the loaded module version after restart. The driver comparisons used different workloads, so the results are not matched benchmarks.
I did not test a replacement PSU, a replacement GPU or four independent cables. The lower power limit did not prevent failure. This result does not exclude a cable fault or a brief power disturbance.
Workloads
I was using PyTorch for model training and inference. Separate diagnostics used saved inputs.
Standalone CUDA failure
On driver 595.99.02, the following standalone workload coincided with Xid 79/154:
import torch
with torch.inference_mode():
    a = torch.randn(2048, 2048, device="cuda", dtype=torch.bfloat16)
    for _ in range(20):
        assert torch.isfinite(a @ a.T).all().item()
    torch.cuda.synchronize()
No model was loaded. The failing iteration was not recorded. This short test passed on other boots, so it does not fail every time.
Short checks often pass before subsequent failure
On several boots, a CUDA Driver API test created a context and allocated memory. It copied 8 MiB to the GPU and back. The returned bytes matched the original bytes. Twenty BF16 matrix iterations then passed, but later inference still failed.
Different pretrained model also failed
A second pretrained model also failed. This test used BF16, batch size two, and greedy generation with a 384-token limit. It used saved inputs and completed 299 batches before device loss.
The two models differ in size and GPU operations. Both failed, but this comparison does not identify the cause.
Other observations
  • Earlier accessible endpoint AER counters were zero. Reviewed logs did not identify an AER precursor. This does not rule out a PCIe or electrical fault.
  • Earlier GPU/root-port runtime-PM snapshots reported active state and zero suspended time. These observations do not rule out internal power-state transitions.
  • I have no electrical measurements of the connector pins, power rails, brief power disturbances or reset signals. The related thread describes another machine.
  • I did not compare open and proprietary modules under the same conditions.
  • BIOS remained at F3 throughout these tests.
  • After some abrupt shutdowns, several local Git objects or files were empty. Copies from the remote repository restored them. No storage fault was diagnosed.
  • GPU workloads stop after device loss. I will not run more stress tests until the cable arrangement is corrected or approved.
Evidence available
I retained kernel excerpts, boot IDs, loaded driver versions, source hashes, progress records and separate reports for interrupted tests. Installation photos are also available.
Two older NVIDIA bug reports are available locally:
  • nvidia-bug-report.log.gz: earlier driver-580 incident.
  • driver595-failed.log.gz: earlier driver-595 incident.
These reports predate the driver-615 failures. I can send them privately and collect a fresh report with your instructions. They contain machine details, so I did not post them publicly.
Questions
  1. Does the supplied MSI adapter require four independent cables from this PSU?
  2. If the original EVGA GQ cables are unavailable, which replacement PSU or cable arrangement do you recommend?
  3. Does this failure pattern, including a missing PCI device after reboot, match a known GB202 problem?
  4. Which driver or firmware version do you recommend for the next test?
  5. Which diagnostic can distinguish a driver/GSP failure from a GPU power/reset fault or a PCIe fault?
  6. Which logs do you need after failure, before I disconnect power? Is a full power cycle expected in this state?
  7. After I correct the cabling and repeat the test, what result warrants hardware inspection or an RMA?
