RTX 5090 (GB202): Flip event timeout and sync FD semaphore failure under GPU load — 590.48.01
I’m running into an intermittent crash happening mostly under heavy load, but occasionally not. journalctl -b 1 -p err shows
Feb 26 09:34:03 cygnus kernel: [drm:__nv_drm_semsurf_wait_fence_work_cb [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to register auto-value-update on pre-wait value for sync FD semaphore surface
Feb 26 09:34:13 cygnus kernel: [drm:nv_drm_atomic_commit [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Flip event timeout on head 0
Here’s the complete log, along with the usual bug report:
err.log (137.4 KB)
nvidia-bug-report.log.gz (889.3 KB)
Here’s my system info:
  • GPU: NVIDIA GB202 [GeForce RTX 5090]
  • Driver: nvidia-open-dkms 590.48.01-4
  • Kernel: Linux 6.12.74-1-lts x86_64
  • Compositor: Hyprland
Can anyone tell me if this is a hardware issue, or a problem with drivers?
I have same issue with the same this messsage, if you using Hyprland with hybrid GPU this might be fixing it. To fix just setting environment AQ_DRM_DEVICES to use iGPU, then dGPU on hyprland.conf or any your environment set or just delete the AQ_DRM_DEVICES so hyprland will pick automatically
Hi All,
I have filed a bug 5981743 internally for tracking purpose.
Team will try to duplicate issue in house and will get back if required any additional information.
Can you please share Nvidia-bug-report from your system as well?
Hello, As dmidecode o/p is not available in report, can you confirm if its hybrid desktop system? Which application you are running to generate load? What is frequency of repro state? Any specific action resulting into this?
Here’s my log:
nvidia-bug-report.log.gz (2.3 MB)
Can you please confirm this on latest 610 driver and share an update here?
@vrachatte Confirming: Still reproducible on 610 drivers (open kernel modules)
System:
  • RTX 5090 (Desktop)
  • Driver 610.43.03 (Arch nvidia-open-dkms 610.43.03-3)
  • Kernel 7.1.3-arch2-2
  • Wayland (Hyprland 0.55.4, hyprlock 0.9.5), cmdline nvidia_drm.modeset=1 nvidia_drm.fbdev=1, modprobe options nvidia NVreg_UseKernelSuspendNotifiers=1
My trigger is S3 (deep) suspend/resume rather than the OP’s GPU-load path, but it produces the same error signature on the same silicon. If a Wayland session-lock client (hyprlock - holds sync-FD semaphore surfaces) stays alive across the suspend/resume cycle, the driver fails to restore its semaphore surface on resume. It usually takes 2-3 cycles for the error to occur but happened on the first cycle on the newest driver.
Jul 18 17:03:25 kernel: PM: suspend entry (deep)
Jul 18 17:04:05 kernel: [drm:__nv_drm_semsurf_wait_fence_work_cb [nvidia_drm]] *ERROR* [nvidia-drm] [GPU ID 0x00000100] Failed to register auto-value-update on pre-wait value for sync FD semaphore surface
Jul 18 17:04:07 kernel: PM: suspend exit
The client is unusable afterwards (this time it aborted ~27 s after resume. The coredump is available on request). Happy to test debug builds.
Here’s my log:
nvidia-bug-report.log.gz (873.8 KB)
