Summary
On a Colorful G16 Pro (i9-14900HX + RTX 5090 Laptop GB203M, Deepin 23 / kernel 6.6.155, driver 595.99.02 proprietary), the GPU was stuck at the 95W default TGP. I fixed the nvidia-powerd setup and Dynamic Boost now works, but SBIOS only ever grants 120W under load — never more, while Windows + Colorful Control Center (turbo profile) reportedly reaches 175W on this chassis.
Questions:
- Has anyone with this or a similar OEM (Colorful / Tongfang / Clevo-based) gotten the full 175W boost budget on Linux?
- Is the boost budget purely SBIOS/NVPCF-controlled, or is there anything driver-side that can raise the cap?
- Is there a known mapping between OEM performance profiles (EC/WMI) and the NVPCF budget that nvidia-powerd negotiates?
What was wrong and what I fixed
Deepin’s NVIDIA driver package (595.99.02) ships /usr/share/doc/NVIDIA_GLX-1.0/nvidia-dbus.conf but does not install it to /etc/dbus-1/system.d/. Consequences:
- nvidia-powerd ran but could not register its bus name → Dynamic Boost dead
- GPU pinned at Default Power Limit 95W, compute loads ~800MHz, “SW Power Cap” throttle active
Fix (verified working, powerd now owns nvidia.powerd.server on the system bus):
sudo mkdir -p /etc/dbus-1/system.d
sudo cp /usr/share/doc/NVIDIA_GLX-1.0/nvidia-dbus.conf /etc/dbus-1/system.d/
sudo systemctl restart nvidia-powerd
Current state after fix
- Idle: Current Power Limit 120W (Default still 95W) — boost active
- Under sustained compute load (nvidia-smi dmon, 1s samples): power flat at 117–118W, SM clock 900–930MHz, GPU temp 47→63°C over 90s, mem clock 14001MHz
- nvidia-smi -pl → “Changing power management limit is not supported in current scope” (expected on mobile)
- powerd journal shows no errors (no “SBIOS requested to disable Dynamic Boost”, no AutoFL errors)
Things I already ruled out
- CPU power is not the bottleneck: lowering Intel RAPL PL1 from 110W → 55W → 35W does not change the GPU cap at all (still exactly 118W). Total system draw during compute is ~135W against a 330W adapter.
- AC power is connected (ADP1 online=1); battery reports “Not charging 98%” — if the OEM firmware gates boost on battery state this may be it, but I have no way to verify on Linux.
- All CPUs on performance governor; powerd’s documented schedutil/powersave interaction looks orthogonal since the cap never moves regardless of CPU limits.
- No WMI driver claims this machine: no colorful/tongfang driver in kernel 6.6, /sys/firmware/acpi/platform_profile does not exist, ~20 unclaimed WMI GUIDs in /sys/bus/wmi/devices/.
Data points
| state | power limit | SM clock | compute throughput |
| before fix (powerd dead) | 95W | 800MHz | 100% (baseline) |
| after fix | 120W (dynamic) | 930MHz | ~115% |
| Windows + Colorful Control Center turbo (reviews/other users) | up to 175W | ~2GHz+ | n/a |
System info
- Laptop: Colorful G16 Pro (DMI: COLORFUL / G16 Pro), i9-14900HX, RTX 5090 Laptop 24GB (10de:2c18)
- OS: Deepin 23 (beige), kernel 6.6.155-amd64-desktop-hwe
- Driver: 595.99.02 proprietary
- nvidia-powerd: 595.99.02, active, DBus connected, no errors
- /proc/driver/nvidia/gpus/…/power: “Notebook Dynamic Boost: Supported”
Any pointers appreciated — especially from anyone with a Colorful/Tongfang 50-series laptop. I can attach an nvidia-bug-report.log.gz if needed.
