RTX 5090 on Ubuntu 24.04 GSP initialization fails
System
  • Ubuntu 24.04
  • NVIDIA driver: 595.71.05 open kernel module
  • GPU: ASUS RTX 5090, PCI ID 10de:2b85, subsystem 1043:89e3
  • VBIOS: 98.02.2E.40.E1
  • CPU: AMD Ryzen 9 9950X3D
  • Motherboard: ASUS ROG CROSSHAIR X870E DARK HERO
  • BIOS: 1002
  • Display connected to the AMD iGPU; RTX 5090 is used for compute
Problem
I installed NVIDIA driver 595.71.05 and initially the RTX 5090 was detected and working normally.
After running a Python/CUDA workload, the GPU failed. The kernel started reporting an FSP/GSP initialization error, including:
Xid 143, Error status 0x65 while polling for FSP boot complete
RmInitAdapter: Cannot initialize GSP firmware RM
RmInitAdapter failed! (0x62:0x65:2168)
GSP-related register reads also repeatedly return:
0xbadf4100
Since then, the card is still visible on PCIe:
01:00.0 NVIDIA Corporation Device [10de:2b85]
Kernel driver in use: nvidia
but:
$ nvidia-smi
No devices were found
The same FSP/GSP initialization failure repeats after reboot.
There were also a few occasions where the GPU temporarily came back after the machine had been completely powered off and disconnected from AC power for several hours or overnight. However, after the failure occurred again, normal rebooting or short power cycles did not reliably recover the card.
What I have tried
  • Updated motherboard BIOS from 0606 to 1002.
  • Tested both Performance and Quiet BIOS positions on the RTX 5090.
  • Tried Windows as a cross-check, but the GPU still did not return to a normal working state.
  • Tested PCIe Gen5, Gen4 and Gen3.
  • At Gen4 and Gen3, the PCIe link is clean with LaneErrStat: 0 and no reported CorrErr, NonFatalErr, FatalErr, or UnsupReq, but the exact same Xid 143 / FSP boot timeout remains.
  • Tried full AC power-off / power-disconnect cycles. On some occasions, leaving the machine fully unpowered for several hours or overnight appeared to temporarily recover the GPU, but the issue returned again later.
I have attached nvidia-bug-report.log.gz.
nvidia-bug-report.log.gz (985.8 KB)
Has anyone seen this Xid 143 / FSP boot timeout 0x65 / RmInitAdapter failure on an RTX 5090 under Ubuntu 24.04?
