I have attached the nvidia-bug-report log captured after a failure.
I am seeing repeated GPU failures on a Linux workstation where the GPU falls off the PCIe bus during CUDA workloads.
System:
- Machine: HP OMEN by HP 45L Gaming Desktop GT22-3xxx
- Baseboard: HP 8D2C
- BIOS: F.13, release date 09/10/2025
- OS: Ubuntu 24.04.4 LTS
- Kernel: 6.8.0-110-generic
- GPU: NVIDIA GeForce RTX 5090 (GB202-A)
- GPU UUID: GPU-dc4edb7d-05af-273a-4343-bd26a089db16
- VBIOS: 98.02.79.00.09
- NVIDIA driver: 580.126.09
- CUDA version reported by nvidia-smi: 13.0
Problem:
During sustained CUDA workloads, the GPU becomes unavailable. After failure, nvidia-smi reports:
Unable to determine the device handle for GPU0: 0000:02:00.0: Unknown Error
No devices were found
The attached nvidia-bug-report log shows repeated Xid 79 events where the GPU falls off the bus. This has happened multiple times:
- 2026-07-19: Xid 79, GPU has fallen off the bus
- 2026-07-21: Xid 79, GPU has fallen off the bus
- 2026-07-22: Xid 79, GPU has fallen off the bus
For the 2026-07-22 failure, the log shows a PCIe physical-layer AER error shortly before the Xid 79:
pcieport 0000:00:06.0: AER: Multiple Correctable error message received from 0000:00:06.0
pcieport 0000:00:06.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
pcieport 0000:00:06.0: [ 0] RxErr
NVRM: Xid (PCI:0000:02:00): 79, GPU has fallen off the bus.
NVRM: Xid (PCI:0000:02:00): 154, GPU recovery action changed from 0x0 (None) to 0x2 (Node Reboot Required)
After the failure, the GPU PCI config space appears unreadable in the bug report, with “Unknown header type 7f” and all ff bytes.
The system is in a warm room, so overheating is possible, but I do not see explicit overtemperature or thermal shutdown messages in the logs. I would like to know whether this looks like a known issue with
RTX 5090 / driver 580.126.09 / Linux 6.8, or whether it should be treated primarily as PCIe/power/hardware instability.
Questions:
- Are there known issues with RTX 5090 on Linux driver 580.126.09 that can produce Xid 79 / Xid 154 under CUDA load?
- Do you recommend a different driver version for this GPU/kernel combination?
- Are there recommended kernel parameters, GSP firmware settings, PCIe ASPM settings, or BIOS PCIe generation settings to test?
- Does the PCIe AER RxErr immediately before Xid 79 suggest physical PCIe link instability rather than a software/driver issue?
