I have an RTX A6000 graphics card. According to the Power Guidelines for Workstation Products, the A6000 uses an 8-pin CPU power connector (EPS-12V). However, when I tested it with a multimeter (short circuit), I found that some grounds are isolated from each other. Can I connect pins 1, 2, 3, and 4 to the same ground? Additionally, can I use the same 12V power line for pins 5, 6, 7, and 8? I lost the 8-pin CPU standard adapter cable that Nvidia includes with the product.
Hi, pls understand we can only recommend our certified cable/adapter solutions, we cannot guide you to connect power in any different way. Pls source a new adapter from whatever your PSU delivers as connectors for PCIe gfx, to an ATX 8pin CPU connecot on the GPU side…
