RTX engine creation failed
Any idea what is wrong? I have 2 3090s in my system. They are from different hardware vendors if that matters? I can get it to launch with this from command line.
omni.create.singlegpu.bat --/renderer/activeGpu=0
I’m having the same issue, I just added an Aorus rtx 3080 EGPU to my system and omniverse is giving me the same error, it will work without the EGPU but, whats the point?
I want it to work on my 3080
You can probably launch it with the following on only the egpu
omni.create.singlegpu.bat --/renderer/activeGpu=1
I think the error stems from trying to use multiple GPUs
im sorry im a nooob… what exactly do I do with that line of code and where does it input? how do I use that thing u sent
You’ll need to enter this in the command line in windows.
Hello @rubberjohnny & @flyinglotus1983! Sorry to hear you are having trouble. I’ve seen this issue come up once before. (Here is the forum post: RTX engine creation failed) Our Tech support suggested testing a single GPU on startup.
I have messaged him for more help, but let me know if you are able to launch the RTX Engine with the suggestion from the earlier post!
hello @flyinglotus1983 -
The link that WendyGram posted above should show you how to start just the EGPU. If issues or unclear, please tell me.
In addition can i request some log files?
Below is an example location of the folder “Kit” that i would like to request. The user name under C:\Users\xxxx needs to be replaced with your username. Then zip up the contents of the Kit folder and post back.
Kit.zip (1.0 MB)
Here are is the kit folder. I can launch with one GPU using the command line. Launching normally with both GPU results in the RTX engine error and viewport is black.
hello @rubberjohnny -
Thanks for the files. Looks like an issue with the shadercache. Can you please try the latest version of Create (2022.1.0) This is now available on the Launcher.
Hi I have Create 2022.1.0-rc 22 installed. I just tried and get the same error. Here is the latest .kit archive. thanks
Kit.zip (1.1 MB)
Hi everyone! The development team is working on a solution to this issue and has asked me to get a bit more information from you all. Could you please let me know your Operating System, GPU(s), and the GPU Driver you are using?
Operating System: ?
GPU(s): ?
GPU Driver: ?
Operating System:
Windows 10 Home, 10.0.19044 Build 19044
GPUs: I have two…
NVIDIA GeForce RTX 3090 Founders Edition (Video Bus: PCIe v4.0 x16 (16.0 GT/s) @ x8 (16.0 GT/s)
MSI RTX 3090 AERO/VENTUS 3X OC 24G (Video Bus: PCIe v4.0 x16 (16.0 GT/s) @ x8 (2.5 GT/s)
GPU Driver: 472.47
Gonna chime in here; facing the same problem with Create 2022.1.4 when trying to start in multi-gpu mode
Specs:
Windows 10
RTX A5000 Laptop GPU
2x RTX A6000 EGPU
GPU Driver: 516.59
I have the same problem, rtx engine creation failed.
Operating System: ubuntu 20.04
GPU(s): RTX A6000
GPU Driver: 495.29.05
kit_20220901_205014.log (934.9 KB)
