Hi
I am working on a Robotics project which deals with Deep Reinforcement Learning. So I am planning to buy a Workstation that supports Isaac Simulator. I have the plan to go with i9 11900k (8 core) with RTX3080 or RTX A4000 GPU, Which GPU is better for my application RTX3080 or RTX A4000?.. …
Workstation spec:
Intel Core i9-11900K 3.5GHz, 8 Core) Processor
64GB DDR4 3200Mhz (2x32GB) Memory
1TB NVMe SSD Storage
1TB SATA 7200rpm HDD
Nvidia RTX 3080 10GB Graphics or RTX A4000 16GB Graphics
Hi. Those specifications looks good. You should be fine with either GPU. The RTX 3080 have slightly better performance with faster VRAM but the A4000 has more VRAM and uses less power. This depends on your data too. More VRAM will be useful to process larger datasets.
Thanks for your suggestions.I have ordered with the following spec.
Workstation spec:
Nvidia RTX A4000 16GB Graphics
