The RTX4000 card suggests that it should be used in a PCIe3.0 x16 slot. The size of the card means the slot size should be x16 but can anyone suggest or do you have experience with what happens if the slot size is x16 and the slot runs at x8 speed?
Depending on slot configuration in motherboards PCIe slot speed rates can often move down when there are multiple PCIe slots populated so I am trying to understand if having this in a x16 physical size slot but x8 speed slot is likely to impact performance of the card.
Ps. Understood it would remove any doubt to have it in a x16 speed slot but just trying understand possibilities here.
Any feedback welcome.
