I am using two gpu's GTX460 and GT240.
I have to run CUDA C program using the gpu GTX460 and I need the monitor display by using GT240.
I tried to connect monitor display to GT240 through monitor cable,but monitor doesnot work.
How can I do my above requirement ?
Will you help me ?
Please state if you are using Windows or Linux. I will assume Windows here:
Use Windows display settings control panel. Extend the desktop to the GT 240. Afterwards make it the primary display and (at your discretion) disable the display on the GTX460.
Then you could apply a registry hack to disable the watchdog timer on the GTX 460, allowing you to run kernels significantly longer than the timeout of 2-3 seconds.
