run “camera_recording” is errors at TX1 r28.2
the error is below:
nvidia@tegra-ubuntu:~/tegra_multimedia_api/samples/10_camera_recording$ ./camera_recording
Set governor to performance before enabling profiler
NvPclHwGetModuleList: No module data found
OFParserGetVirtualDevice: NVIDIA Camera virtual enumerator not found in proc device-tree
LoadOverridesFile: looking for override file [/Calib/camera_override.isp]
1/16LoadOverridesFile: looking for override file [/data/nvcam/settings/camera_overrides.isp]
2/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/camera_overrides.isp]
3/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/camera_overrides.isp]
4/16LoadOverridesFile: looking for override file [/data/nvcam/camera_overrides.isp]
5/16LoadOverridesFile: looking for override file [/data/nvcam/settings/e3322_bottom_A815P2.isp]
6/16LoadOverridesFile: looking for override file [/opt/nvidia/nvcam/settings/e3322_bottom_A815P2.isp]
7/16LoadOverridesFile: looking for override file [/var/nvidia/nvcam/settings/e3322_bottom_A815P2.isp]
8/16---- imager: No override file found. ----
ISP Config file did not load from cache, quering deviceNvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 170: Error: Invalid isp config attribute element: "flash.TorchLevel[0]=100.00"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 171: Error: Invalid isp config attribute element: "flash.FlashLevel[0]=180.00"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 180: Error: Invalid isp config attribute: "nr.v1.luma.Enable=TRUE"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 181: Error: Invalid isp config attribute: "nr.v1.luma.IsoThreshold=100"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 182: Error: Invalid isp config attribute: "nr.v1.luma.Slope=0.01"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 183: Error: Invalid isp config attribute: "nr.v1.luma.Threshold=0.015"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 184: Error: Invalid isp config attribute: "nr.v1.chroma.Enable=TRUE"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 185: Error: Invalid isp config attribute: "nr.v1.chroma.IsoThreshold=100"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 186: Error: Invalid isp config attribute: "nr.v1.chroma.Slope=0.40"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 187: Error: Invalid isp config attribute: "nr.v1.chroma.Threshold=0.08"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 188: Error: Invalid isp config attribute: "nr.v2.chroma.Enable=FALSE"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 189: Error: Invalid isp config attribute: "nr.v2.chroma.IsoThreshold=100"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 190: Error: Invalid isp config attribute: "nr.v2.chroma.Slope=1.0"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 191: Error: Invalid isp config attribute: "nr.v2.chroma.Threshold=0.0"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 192: Error: Invalid isp config attribute: "nr.v2.chroma.PredefinedGainResponse={0,0,0,0,0,0,1,2,3,4,4,4,4,4,4,4}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 193: Error: Invalid isp config attribute element: "ae.noiseReduction.Preview[0]={0,0,1,2,2,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 194: Error: Invalid isp config attribute element: "ae.noiseReduction.Preview[1]={0,1,1,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 195: Error: Invalid isp config attribute element: "ae.noiseReduction.Preview[2]={1,1,2,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 196: Error: Invalid isp config attribute element: "ae.noiseReduction.Preview[3]={2,2,2,3,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 197: Error: Invalid isp config attribute element: "ae.noiseReduction.Still[0]={0,0,1,2,2,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 198: Error: Invalid isp config attribute element: "ae.noiseReduction.Still[1]={0,1,1,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 199: Error: Invalid isp config attribute element: "ae.noiseReduction.Still[2]={1,1,2,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 200: Error: Invalid isp config attribute element: "ae.noiseReduction.Still[3]={2,2,2,3,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 201: Error: Invalid isp config attribute element: "ae.noiseReduction.Video[0]={0,0,1,2,2,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 202: Error: Invalid isp config attribute element: "ae.noiseReduction.Video[1]={0,1,1,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 203: Error: Invalid isp config attribute element: "ae.noiseReduction.Video[2]={1,1,2,2,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 204: Error: Invalid isp config attribute element: "ae.noiseReduction.Video[3]={2,2,2,3,3,3,3}"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 205: Error: Invalid isp config attribute: "edgeEnhance.strength.Preview=0.113"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 206: Error: Invalid isp config attribute: "edgeEnhance.strength.Still=0.113"
NvCameraIspConfigFileLoad: Config file "sensor.cfg" Line 207: Error: Invalid isp config attribute: "edgeEnhance.strength.Video=0.113"
LSC: LSC surface is not based on full res!
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
Failed to query video capabilities: Inappropriate ioctl for device
NvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
875967048
842091865
create video encoder return true
CONSUMER: Waiting until producer is connected...
PRODUCER: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
SCF: Error InvalidState: NonFatal ISO BW requested not set. Requested = 2147483647 Set = 750000 (in src/services/power/PowerServiceCore.cpp, function setCameraBw(), line 653)
CONSUMER: Got EOS, exiting...
CONSUMER: Done.
PRODUCER: Done -- exiting.
Total Profiling Time = 0 sec
