I am trying to run Create 2022.3.3 from a remote server running Ubuntu 20.04. I connect to the server using x11 forwarding, so I am able to view Omniverse Launcher and click to launch applications. When launching Create, it does not seem to fully load. It comes up with a gray window and “Edit, Window, Rendering, and Help” options in the top left bar.
I attached the log file. Many errors indicate “Failed to startup python extension”, but I am not sure how to fix this. Is the python setup causing the problem or is there something else?
Please let me know if any other information is needed and I appreciate any help. I am new to using this software and this type of setup.
Thank you,
Allison
create-log (1.1 MB)
