I pulled source code from git: GitHub - NVIDIA-AI-IOT/deepstream_360_d_smart_parking_application: Describes the full end to end smart parking application that is available with DeepStream 5.0
Then, I pulled docker in perception_docker:
DOCKERURL=nvcr.io/nvidia/deepstream_360d:5.0-20.08
xhost +
docker pull $DOCKERURL
docker run --gpus all -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -w /root nvcr.io/nvidia/deepstream_360d:5.0-20.08
But when i run deepstream-360d-app in this docker, i got error:
(gst-plugin-scanner:1750): GStreamer-WARNING **: 09:02:28.063: Failed to load plugin ‘/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so’: libtrtserver.so: cannot open shared object file: No such file or directory
** ERROR: main:650: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink2: Could not configure supporting library.
Debug info: gstnvmsgbroker.c(388): legacy_gst_nvmsgbroker_start (): /GstPipeline:pipeline/GstBin:sink_sub_bin2/GstNvMsgBroker:sink_sub_bin_sink2:
unable to connect to broker library
ERROR from sink_sub_bin_sink2: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5265): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:sink_sub_bin2/GstNvMsgBroker:sink_sub_bin_sink2:
Failed to start
App run failed
File libtrtserver.so is not existed in system. Is this mistake from docker? Pls help!
