hi
i have a trouble in running deepstream_test1_app
after i run ./deepstream-test1-app …/…/…/samples/streams/sample_720p.h264
program stuck in g_main_loop_run (loop);
test@lb-ubnt:~/qin/DeepStream_Release/sources/apps/deepstream-test1$ make
cc -I…/…/includes pkg-config --cflags gstreamer-1.0
-c -o deepstream_test1_app.o deepstream_test1_app.c
cc -o deepstream-test1-app deepstream_test1_app.o pkg-config --libs gstreamer-1.0
test@lb-ubnt:~/qin/DeepStream_Release/sources/apps/deepstream-test1$ ls
deepstream-test1-app deepstream_test1_app.c deepstream_test1_app.o dstest1_pgie_config.txt Makefile README
test@lb-ubnt:~/qin/DeepStream_Release/sources/apps/deepstream-test1$ ./deepstream-test1-app …/…/…/samples/streams/sample_720p.h264
Failed to connect to Mir: Failed to connect to server socket: No such file or directory
Unable to init server: Could not connect: Connection refused
(gst-plugin-scanner:27506): Clutter-CRITICAL **: Unable to initialize Clutter: Could not initialize Gdk
(gst-plugin-scanner:27506): Clutter-Gst-CRITICAL **: Unable to initialize Clutter
Now playing: …/…/…/samples/streams/sample_720p.h264
Running…
