Hey guys,
I’m trying to run depthnet and detectnet (jetson-inference/docs/images at master · dusty-nv/jetson-inference · GitHub) at the same time on the same camera. I’m hoping to have detectnet designate people, and then using depth from depth net at that centroid coordinate, output the image feed, as well as the distance to the person. I’ve gotten both running independently, just not sure how to go about using deepstream to run them together. Any help would be appreciated!
System:
Jeston Orin Nano Dev
Ubuntu 20.04.6
Deepstream-6.1
Thank you, I will look into that. Do you have any suggestions on how I could transfer over the mobilenetV2 and the depthnet to a model that Deepstream can use? Thank you!
