After doing this, it has another error:
2022-02-17 03:02:17,746 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Serial augmentation enabled = False
2022-02-17 03:02:17,746 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Pseudo sharding enabled = False
2022-02-17 03:02:17,746 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: Max Image Dimensions (all sources): (0, 0)
2022-02-17 03:02:17,746 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: number of cpus: 48, io threads: 96, compute threads: 48, buffered batches: 4
2022-02-17 03:02:17,746 [INFO] modulus.blocks.data_loaders.multi_source_loader.data_loader: total dataset size 7, number of sources: 1, batch size per gpu: 4, steps: 2
WARNING:tensorflow:From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
2022-02-17 03:02:17,804 [WARNING] tensorflow: From /usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/converters/directives.py:119: The name tf.set_random_seed is deprecated. Please use tf.compat.v1.set_random_seed instead.
WARNING:tensorflow:Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f8c6b932438>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f8c6b932438>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
2022-02-17 03:02:17,866 [WARNING] tensorflow: Entity <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f8c6b932438>> could not be transformed and will be executed as-is. Please report this to the AutoGraph team. When filing the bug, set the verbosity to 10 (on Linux, `export AUTOGRAPH_VERBOSITY=10`) and attach the full output. Cause: Unable to locate the source code of <bound method DriveNetTFRecordsParser.__call__ of <iva.detectnet_v2.dataloader.drivenet_dataloader.DriveNetTFRecordsParser object at 0x7f8c6b932438>>. Note that functions defined in certain environments, like the interactive Python shell do not expose their source code. If that is the case, you should to define them in a .py source file. If you are certain the code is graph-compatible, wrap the call using @tf.autograph.do_not_convert. Original error: could not get source code
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 849, in <module>
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 838, in <module>
File "<decorator-gen-2>", line 2, in main
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/utilities/timer.py", line 46, in wrapped_fn
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 827, in main
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 708, in run_experiment
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 619, in train_gridbox
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/scripts/train.py", line 447, in build_training_graph
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/drivenet_dataloader.py", line 694, in get_dataset_tensors
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/blocks/trainers/multi_task_trainer/data_loader_interface.py", line 77, in __call__
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/core/build_wheel.runfiles/ai_infra/moduluspy/modulus/blocks/data_loaders/multi_source_loader/data_loader.py", line 396, in call
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py", line 2081, in apply
return DatasetV1Adapter(super(DatasetV1, self).apply(transformation_func))
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py", line 1422, in apply
dataset = transformation_func(self)
File "/opt/tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/drivenet_dataloader.py", line 405, in <lambda>
File "/opt/nvidia/third_party/keras/tensorflow_backend.py", line 356, in new_map
self, _map_func_set_random_wrapper, num_parallel_calls=num_parallel_calls
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py", line 2000, in map
MapDataset(self, map_func, preserve_cardinality=False))
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py", line 3531, in __init__
use_legacy_function=use_legacy_function)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py", line 2810, in __init__
self._function = wrapper_fn._get_concrete_function_internal()
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/eager/function.py", line 1853, in _get_concrete_function_internal
*args, **kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/eager/function.py", line 1847, in _get_concrete_function_internal_garbage_collected
graph_function, _, _ = self._maybe_define_function(args, kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/eager/function.py", line 2147, in _maybe_define_function
graph_function = self._create_graph_function(args, kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/eager/function.py", line 2038, in _create_graph_function
capture_by_value=self._capture_by_value),
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/framework/func_graph.py", line 915, in func_graph_from_py_func
func_outputs = python_func(*func_args, **func_kwargs)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py", line 2804, in wrapper_fn
ret = _wrapper_helper(*args)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/data/ops/dataset_ops.py", line 2749, in _wrapper_helper
ret = autograph.tf_convert(func, ag_ctx)(*nested_args)
File "/usr/local/lib/python3.6/dist-packages/tensorflow_core/python/autograph/impl/api.py", line 237, in wrapper
raise e.ag_error_metadata.to_exception(e)
StopIteration: in converted code:
relative to /opt:
nvidia/third_party/keras/tensorflow_backend.py:353 _map_func_set_random_wrapper *
return map_func(*args, **kwargs)
tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/drivenet_dataloader.py:144 __call__
tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/drivenet_dataloader.py:112 _get_parse_example
tlt/.cache/dazel/_dazel_tlt/75913d2aee35770fa76c4a63d877f3aa/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/iva/build_wheel.runfiles/ai_infra/iva/detectnet_v2/dataloader/utilities.py:217 extract_tfrecords_features
StopIteration:
2022-02-17 11:02:20,468 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
