Run Google DeepMind’s Gemma 3n on NVIDIA Jetson and RTX
As of today, NVIDIA now supports the general availability of Gemma 3n on NVIDIA RTX and Jetson. Gemma, previewed by Google DeepMind at Google I/O last month, includes two new models optimized for multi-modal on-device deployment.
Gemma now includes audio in addition to the text and vision capabilities introduced in version 3.5. Each component integrates trusted research models: Universal Speech Model for audio, MobileNet v4 for vision, and MatFormer for text.
The biggest usage advancement is an innovation called Per-Lay Embeddings. It allows for significant reduction in RAM usage for parameters. The Gemma 3n E4B model has a raw parameter count of 8B parameters but can operate using a dynamic memory footprint that’s comparable to a 4B model. This enables developers to use a higher quality model within a resource-constrained environment.
Model nameRaw ParametersInput Context LengthOutput Context LengthSize on DiskE2B5B32K32K subtracting request input1.55GBE4B8B32K32K subtracting request input2.82BB
Model name Raw Parameters Input Context Length Output Context Length Size on Disk
E2B 5B 32K 32K subtracting request input 1.55GB
E4B 8B 32K 32K subtracting request input 2.82BB
Table 1: Gemma 3n model components for both the E2B and E4B model
Powering robotics and edge AI with Jetson
The Gemma family of models works well on NVIDIA Jetson devices that are geared at powering edge applications, such as next-generation robotics. The lightweight architecture and, now, dynamic memory usage fit in resource-constrained environments.
Jetson developers can participate in the Gemma 3n Impact Challenge hosted on Kaggle. The aim is to use this technology to create meaningful, positive change in the world in areas such as accessibility, education, healthcare, environmental sustainability, and crisis response. Several cash prizes, which start at $10,000, are available for submissions for overall placement and for using different technologies suited for on-device deployment, such as Jetson.
To get started, check out the live text and image demo from the Gemma 3 Developer Day in April and the GitHub repository for deploying Gemma locally using Ollama.
NVIDIA RTX for Windows developers and AI enthusiasts
With NVIDIA RTX AI PCs, developers can easily deploy Gemma 3n models using Ollama. AI enthusiasts can use Gemma 3n models with RTX accelerations in their favorite apps like AnythingLLM and LM Studio.
Developers can deploy Gemma 3n locally to both RTX and Jetson devices with a few simple instructions using the Ollama CLI:
  1. Download and install Ollama for Windows
  2. Open a terminal window and complete the following commands:
ollama pull gemma3n:e4b ollama run gemma3n:e4b “Summarize Shakespeare’s Hamlet”
NVIDIA collaborates with Ollama to provide performance optimizations for NVIDIA RTX GPUs, accelerating the latest models like Gemma 3n. For this model, Ollama leverages the Ollama engine in the backend, which builds upon the GGML library. Learn more about NVIDIA’s contributions to the GGML library for maximum performance on NVIDIA RTX GPUs.
Customize Gemma for your data with the open NVIDIA NeMo Framework
Developers can use the Gemma 3n models from Hugging Face with the open source NVIDIA NeMo Framework. It provides a comprehensive framework for post-training Llama models to achieve higher accuracy, specifically through fine-tuning with enterprise-specific data. The workflow within NeMo is designed to be end-to-end, covering data preparation, efficient fine-tuning, and model evaluation.
Figure 1. NeMo Framework provides end-to-end support for large language models and multimodal models.
The workflow includes:
  • Data curation (NeMo Curator): Curator prepares high-quality datasets for either pretraining or fine-tuning by offering tools to extract, filter, and deduplicate large volumes of structured and unstructured data. It ensures the quality of the input data for the model.
  • Fine-tuning (NeMo): Once the data is curated, NeMo enables efficient fine-tuning of Llama models. It supports various techniques to optimize this process, including LoRA (Low-Rank Adaptation), PEFT (Parameter-Efficient Fine-Tuning), and full parameter tuning for comprehensive customization.
  • Model evaluation (NeMo Evaluator): After fine-tuning, NeMo Evaluator is used to assess the performance of the adapted models using custom tests and benchmarking.
Advancing community models and collaboration
NVIDIA is an active contributor to the open-source ecosystem and has released several hundred projects under open-source licenses. NVIDIA is committed to open models such as Gemma that promote AI transparency and let users broadly share work in AI safety and resilience.
Get started today
Bring your data and try out Gemma 3n E4B on the NVIDIA accelerated platform in the NVIDIA API catalog.
