I want to run gui application automatcally when orin wake up
I use orin version 36.4
How do I do that?
I tried to use .xsessionrc on /home/ubuntu but i it does not run
Hi alalieli,
Are you using the devkit or custom board for Orin Nano?
R36.4.0 or R36.4.3?
You can run cat /etc/nv_tegra_release
on your board to check.
Which GUI application you want to run?
May I know what’s your exact use case?
My version is 36.4.0
I am using devkit
Which GUI application you want to use?
Maybe you can simply create a custom service to handle this.
