Run multiple threads on a single pipeline
• DeepStream Version
• TensorRT Version
GPU
deepstream 6.4
TRT 8.6.1.6
Driver 545.29.06
Hi I have 2 GPU’s, I am trying to create 2 pipeline threads to run on each GPU.
so thread_1 will run on GPU0, and thread_2 will run on GPU1.
The problem I am facing is two threads are being created, but only thread_1 is being executed, the thread_2 does not execute…
I think the problem is with the
self.pipeline.set_state(Gst.State.READY)
self.pipeline.set_state(Gst.State.PLAYING)
loop = GObject.MainLoop()
try:
loop.run()
except Exception as e:
self.pipeline.set_state(Gst.State.NULL)
malloc()
pass
I think the loop.run in thread_1 is blocking the thread_2.
Could you attach your source code? If you want to run two pipelines separately, why not just run two programs?
will share it personally to you.
Could you just run your demo twice like below?
Teminal 1:
CUDA_VISIBLE_DEVICES=0 demo(1st camera source)
Teminal 2:
CUDA_VISIBLE_DEVICES=1 demo(2nd camera source)
You can’t run two Mainloop in one program.
