Hi, @AastaLLL Thanks for the anwser.
After tried some debugging, i narrow it down to one suspicious part.
For Model A(YoLo) i write a custom plugin for space to depth function and compile it to shared library (follow “uff_custom_plugin” example).
For Model B i also write a custom plugin for absolute value and compile it to shared library.
Below is part of my program and just run YoLo model only. the data flow like
[CPU image] -> [GPU image] -> (A = YoLo) -> [GPU bbox] -> [CPU bbox]
and there are two cases when i run this program to detect object in the video.
Case 1. If i comment out all abs_plugin parts(as below) the YoLo prediction is good, For example most car and license plate in the video can be detected
Case 2. If i uncomment the commented parts below, the prediction of YoLo is really worse, For car object, the detection rate is almost same as Case 1 but the accuracy of bounding box is worse thane Case 1. For license plate object, the detection rate is more less than Case 1 and the accuracy of bounding box is more worse than Case 1.
#include "trt_plugin/space_to_depth.h"
// #include "trt_plugin/abs_plugin.h"
#include "trt_model/trt_yolo.h"
// Static class fields initialization
nvinfer1::PluginFieldCollection SpaceToDepthCreator::mFC{};
std::vector<nvinfer1::PluginField> SpaceToDepthCreator::mPluginAttributes;
// nvinfer1::PluginFieldCollection AbsPluginCreator::mFC{};
// std::vector<nvinfer1::PluginField> AbsPluginCreator::mPluginAttributes;
I have checked abs_plugin but maybe there is something wrong that i don’t know, i post my code here for your reference if you could check it for me, Thanks
abs_plugin.h
#ifndef _ABS_PLUGIN_H_
#define _ABS_PLUGIN_H_
#include "NvInferPlugin.h"
#include <string>
#include <vector>
#include "abs_kernel.h"
ABSPlugin
class AbsPlugin: public nvinfer1::IPluginV2
public:
// Ctor
AbsPlugin();
// Override IPluginV2 public function
const char *getPluginType () const override;
const char *getPluginVersion () const override;
int getNbOutputs () const override;
nvinfer1::Dims getOutputDimensions (int index, const nvinfer1::Dims *inputs, int nbInputDims) override;
void configureWithFormat(const nvinfer1::Dims* inputDims, int nbInputs, const nvinfer1::Dims* outputDims, int nbOutputs, nvinfer1::DataType type, nvinfer1::PluginFormat format, int maxBatchSize) override;
bool supportsFormat (nvinfer1::DataType type, nvinfer1::PluginFormat format) const override;
int initialize () override;
void terminate () override;
size_t getWorkspaceSize (int maxBatchSize) const override;
int enqueue (int batchSize, const void *const *inputs, void **outputs, void *workspace, cudaStream_t stream) override;
size_t getSerializationSize () const override;
void serialize (void *buffer) const override;
void destroy () override;
nvinfer1::IPluginV2* clone () const override;
void setPluginNamespace (const char *pluginNamespace) override;
const char* getPluginNamespace () const override;
private:
size_t mInputVolume;
int mSrcDepth;
int mSrcRow;
int mSrcCol;
std::string mNamespace;
AbsPluginCreator
class AbsPluginCreator: public nvinfer1::IPluginCreator
public:
AbsPluginCreator();
const char* getPluginName() const override;
const char* getPluginVersion() const override;
const nvinfer1::PluginFieldCollection* getFieldNames() override;
nvinfer1::IPluginV2* createPlugin(const char* name, const nvinfer1::PluginFieldCollection* fc) override;
nvinfer1::IPluginV2* deserializePlugin(const char* name, const void* serialData, size_t serialLength) override;
void setPluginNamespace(const char* pluginNamespace) override;
const char* getPluginNamespace() const override;
private:
static nvinfer1::PluginFieldCollection mFC;
static std::vector<nvinfer1::PluginField> mPluginAttributes;
REGISTER_TENSORRT_PLUGIN(AbsPluginCreator);
#endif // _ABS_PLUGIN_H_
abs_plugin.cpp
#include "abs_plugin.h"
#include "NvInfer.h"
#include <cuda_runtime.h>
#include <cassert>
#include <cstring>
// absolute value plugin specific constants
namespace
const char* ABS_PLUGIN_NAME{"CM_ABS_TRT"};
const char* ABS_PLUGIN_VERSION{"1"};
} // namespace
AbsPlugin
// Ctor
AbsPlugin::AbsPlugin()
// IPluginV2 public function
const char* AbsPlugin::getPluginType() const { return ABS_PLUGIN_NAME; }
const char* AbsPlugin::getPluginVersion() const { return ABS_PLUGIN_VERSION; }
int AbsPlugin::getNbOutputs() const { return 1; }
nvinfer1::Dims AbsPlugin::getOutputDimensions(int index, const nvinfer1::Dims *inputs, int nbInputDims)
// printf("##### %s\n", __func__);
assert(nbInputDims == 1);
assert(index == 0);
assert(inputs[index].nbDims == 3);
int in_depth = inputs[0].d[0];
int in_height = inputs[0].d[1];
int in_width = inputs[0].d[2];
return nvinfer1::DimsCHW(in_depth, in_height, in_width);
void AbsPlugin::configureWithFormat(const nvinfer1::Dims* inputDims, int nbInputs, const nvinfer1::Dims* outputDims, int nbOutputs, nvinfer1::DataType type, nvinfer1::PluginFormat format, int maxBatchSize)
assert(nbInputs == 1);
assert(nbOutputs == 1);
assert(type == nvinfer1::DataType::kFLOAT);
assert(format == nvinfer1::PluginFormat::kNCHW);
mInputVolume = inputDims[0].d[0] * inputDims[0].d[1] * inputDims[0].d[2];
bool AbsPlugin::supportsFormat(nvinfer1::DataType type, nvinfer1::PluginFormat format) const
if(type == nvinfer1::DataType::kFLOAT && format == nvinfer1::PluginFormat::kNCHW) {
return true;
else {
return false;
int AbsPlugin::initialize() { return 0; }
void AbsPlugin::terminate()
// if something was initialized in "initialize()"
// it must be terminated here
size_t AbsPlugin::getWorkspaceSize(int maxBatchSize) const { return 0; }
int AbsPlugin::enqueue(int batchSize, const void *const *inputs, void **outputs, void *workspace, cudaStream_t stream)
int status = -1;
status = absInference(stream, inputs[0], outputs[0], mInputVolume);
return status;
size_t AbsPlugin::getSerializationSize() const
return 0;
void AbsPlugin::serialize(void *buffer) const
void AbsPlugin::destroy()
delete this;
nvinfer1::IPluginV2* AbsPlugin::clone() const
return new AbsPlugin();
void AbsPlugin::setPluginNamespace(const char *pluginNamespace)
mNamespace = pluginNamespace;
const char* AbsPlugin::getPluginNamespace() const
return mNamespace.c_str();
AbsPluginCreator
AbsPluginCreator::AbsPluginCreator()
// AbsPluginCreator::~AbsPluginCreator() {}
const char* AbsPluginCreator::getPluginName() const { return ABS_PLUGIN_NAME; }
const char* AbsPluginCreator::getPluginVersion() const { return ABS_PLUGIN_VERSION; }
const nvinfer1::PluginFieldCollection* AbsPluginCreator::getFieldNames() { return &mFC; }
nvinfer1::IPluginV2* AbsPluginCreator::createPlugin(const char* name, const nvinfer1::PluginFieldCollection* fc)
nvinfer1::IPluginV2* AbsPluginCreator::deserializePlugin(const char* name, const void* serialData, size_t serialLength)
// This object will be deleted when the network is destroyed, which will
// call AbsPlugin::destroy()
void AbsPluginCreator::setPluginNamespace(const char* pluginNamespace) { mNamespace = pluginNamespace; }
const char* AbsPluginCreator::getPluginNamespace() const { return mNamespace.c_str(); }
abs_kernel.h
#ifndef _ABS_KERNEL_H_
#define _ABS_KERNEL_H_
int absInference(
cudaStream_t stream,
const void* src,
void* dst,
const int nElem
#endif // _ABS_KERNEL_H_
abs_kernel.cu
#include <abs_kernel.h>
template <typename T>
__global__ void abskernel(const T* src, T* dst, const int nElem)
int d = blockIdx.x * blockDim.x + threadIdx.x;
if(d < nElem) {
if(src[d] < 0) {
dst[d] = -src[d];
else {
dst[d] = src[d];
int absInference(cudaStream_t stream, const void* src, void* dst, const int nElem)
const int blockSize_k = 512;
const int gridSize = (nElem+blockSize_k -1) / blockSize_k;
abskernel<float><<<gridSize, blockSize_k, 0, stream>>>(
static_cast<const float*>(src),
static_cast<float*>(dst),
nElem
return 0;
i don’t understand just include AbsPlugin.h and instantiate AbsPlugin class member will effect model inference.
