run "nvgstcapture-1.0" have some erros at jetson TX1 R28.2
run “nvgstcapture-1.0” have some erros at jetson TX1 R28.2
How can fix this question?
nvidia@tegra-ubuntu:~$ nvgstcapture-1.0
Encoder null, cannot set bitrate!
Encoder Profile = High
Supported resolutions in case of ARGUS Camera
  (2) : 640x480
  (3) : 1280x720
  (4) : 1920x1080
  (5) : 2104x1560
  (6) : 2592x1944
  (7) : 2616x1472
  (8) : 3840x2160
  (9) : 3896x2192
  (10): 4208x3120
  (11): 5632x3168
  (12): 5632x4224
Runtime ARGUS Camera Commands:
  Help : 'h'
  Quit : 'q'
  Set Capture Mode:
      mo:<val>
          (1): image
          (2): video
  Get Capture Mode:
      gmo
  Set sensor orientation:
      so:<val>
          (0): none
          (1): Rotate counter-clockwise 90 degrees
          (2): Rotate 180 degrees
          (3): Rotate clockwise 90 degrees
  Get sensor orientation:
      gso
  Set Whitebalance Mode:
      wb:<val>
          (0): off
          (1): auto
          (2): incandescent
          (3): fluorescent
          (4): warm-fluorescent
          (5): daylight
          (6): cloudy-daylight
          (7): twilight
          (8): shade
          (9): manual
  Get Whitebalance Mode:
      gwb
  Set Saturation (0 to 2):
      st:<val> e.g., st:1.25
  Get Saturation:
      gst
  Capture: enter 'j' OR
           followed by a timer (e.g., jx5000, capture after 5 seconds) OR
           followed by multishot count (e.g., j:6, capture 6 images)
           timer/multihot values are optional, capture defaults to single shot with timer=0s
  Start Recording : enter '1'
  Stop Recording  : enter '0'
  Video snapshot  : enter '2' (While recording video)
  Get Preview Resolution:
      gpcr
  Get Image Capture Resolution:
      gicr
  Get Video Capture Resolution:
      gvcr
Runtime encoder configuration options:
  Set Encoding Bit-rate(in bytes):
      br:<val> e.g., br:4000000
  Get Encoding Bit-rate(in bytes):
      gbr
  Set Encoding Profile(only for H.264):
      ep:<val> e.g., ep:1
          (0): Baseline
          (1): Main
          (2): High
  Get Encoding Profile(only for H.264):
      gep
  Force IDR Frame on video Encoder(only for H.264):
      Enter 'f'
bitrate = 4000000
** Message: <main:5684> iterating capture loop ....
GST_ARGUS: Running with following settings:
   Camera index = 0
   Camera mode  = 0
   Output Stream W = 640 H = 480
   seconds to Run    = 0
Framerate set to : 30 at NvxVideoEncoderSetParameterNvMMLiteOpen : Block : BlockType = 4
===== MSENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
Error generated. /dvs/git/dirty/git-master_linux/multimedia/nvgstreamer/gst-nvarguscamera/gstnvarguscamerasrc.cpp, execute:364 No cameras available
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 214)
(Argus) Error EndOfFile: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 289)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 306)
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 317)
(Argus) Error EndOfFile: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 149)
(Argus) Error EndOfFile:  (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 101)
I use the “dmesg > klog.txt”
the klog.txt disp is below:
[ 1089.415759] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 5908
[ 1089.422944] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5909
[ 1089.508842] video4linux video0: frame start syncpt timeout!0
[ 1089.514784] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5912
[ 1089.522932] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5913
[ 1089.530294] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5914
[ 1089.538513] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5915
[ 1089.546586] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5916
[ 1089.554173] vi 54080000.vi: tegra_channel_error_status:error 22 frame 5917
[ 1089.561610] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5918
[ 1089.569361] vi 54080000.vi: tegra_channel_error_status:error 22 frame 5919
[ 1089.576311] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 5920
[ 1089.583510] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5921
[ 1089.590716] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5922
[ 1089.597912] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5923
[ 1089.605104] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5924
[ 1089.612301] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5925
[ 1089.619494] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5926
[ 1089.626687] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5927
[ 1089.633880] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5928
[ 1089.641072] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5929
[ 1089.648263] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5930
[ 1089.655458] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5931
[ 1089.662651] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5932
[ 1089.673780] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5933
[ 1089.680979] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5934
[ 1089.688171] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5935
[ 1089.695365] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5936
[ 1089.702558] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5937
[ 1089.709752] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5938
[ 1089.716946] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5939
[ 1089.724139] vi 54080000.vi: tegra_channel_error_status:error 22 frame 5940
[ 1089.731074] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5941
[ 1089.738267] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5942
[ 1089.745457] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5943
[ 1089.752652] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5944
[ 1089.759847] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5945
[ 1089.767042] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 5946
[ 1089.778173] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5947
[ 1089.785363] vi 54080000.vi: tegra_channel_error_status:error 22 frame 5948
[ 1089.792294] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5949
[ 1089.799488] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5950
[ 1089.806682] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 5951
[ 1089.813874] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5952
[ 1089.821067] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5953
[ 1089.828259] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5954
[ 1089.835451] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5955
[ 1089.842646] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5956
[ 1089.849836] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5957
[ 1089.857028] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5958
[ 1089.864243] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5959
[ 1089.871436] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5960
[ 1089.882559] vi 54080000.vi: tegra_channel_error_status:error 22 frame 5961
[ 1089.889491] vi 54080000.vi: tegra_channel_error_status:error 22 frame 5962
[ 1089.896423] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5963
[ 1089.903617] vi 54080000.vi: tegra_channel_error_status:error 22 frame 5964
[ 1089.910548] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5965
[ 1089.917739] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5966
[ 1089.924937] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5967
[ 1089.932128] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5968
[ 1089.939319] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5969
[ 1089.946514] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5970
[ 1089.953735] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5971
[ 1089.960935] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5972
[ 1089.968143] vi 54080000.vi: tegra_channel_error_status:error 24002 frame 5973
[ 1089.975338] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5974
[ 1089.986468] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5975
[ 1089.993660] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5976
[ 1090.000852] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5977
[ 1090.008052] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5978
[ 1090.015246] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5979
[ 1090.022441] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5980
[ 1090.029635] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5981
[ 1090.036826] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5982
[ 1090.044017] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5983
[ 1090.051210] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5984
[ 1090.058403] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5985
[ 1090.065595] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5986
[ 1090.072798] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5987
[ 1090.079989] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5988
[ 1090.091109] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5989
[ 1090.098302] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5990
[ 1090.105494] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5991
[ 1090.112687] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5992
[ 1090.119882] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5993
[ 1090.127073] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5994
[ 1090.134264] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5995
[ 1090.141458] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5996
[ 1090.148649] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5997
[ 1090.155841] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 5998
[ 1090.163038] vi 54080000.vi: tegra_channel_error_status:error 22 frame 5999
[ 1090.169968] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6000
[ 1090.177160] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6001
[ 1090.184355] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6002
[ 1090.195476] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6003
[ 1090.202416] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6004
[ 1090.289698] video4linux video0: frame start syncpt timeout!0
[ 1090.295689] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6007
[ 1090.303031] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6008
[ 1090.311401] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6009
[ 1090.318601] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6010
[ 1090.325806] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6011
[ 1090.333432] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6012
[ 1090.340616] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6013
[ 1090.347804] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6014
[ 1090.354994] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6015
[ 1090.362176] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6016
[ 1090.369359] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6017
[ 1090.376553] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6018
[ 1090.383735] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6019
[ 1090.390916] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6020
[ 1090.398100] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6021
[ 1090.405282] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6022
[ 1090.412470] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6023
[ 1090.419656] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6024
[ 1090.426837] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6025
[ 1090.437960] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6026
[ 1090.445142] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6027
[ 1090.452324] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6028
[ 1090.459510] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6029
[ 1090.466699] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6030
[ 1090.473882] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6031
[ 1090.481066] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6032
[ 1090.488252] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6033
[ 1090.495440] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6034
[ 1090.502624] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6035
[ 1090.509812] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6036
[ 1090.516994] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6037
[ 1090.524178] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6038
[ 1090.531361] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6039
[ 1090.542477] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6040
[ 1090.549660] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6041
[ 1090.556854] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6042
[ 1090.564038] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6043
[ 1090.571226] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6044
[ 1090.578407] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6045
[ 1090.585591] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6046
[ 1090.592778] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6047
[ 1090.599958] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6048
[ 1090.607143] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6049
[ 1090.614329] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6050
[ 1090.621250] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6051
[ 1090.628434] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6052
[ 1090.635621] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6053
[ 1090.646741] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6054
[ 1090.653921] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6055
[ 1090.661103] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6056
[ 1090.668286] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6057
[ 1090.675468] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6058
[ 1090.682649] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6059
[ 1090.689833] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6060
[ 1090.697015] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6061
[ 1090.704195] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6062
[ 1090.711378] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6063
[ 1090.718560] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6064
[ 1090.725741] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6065
[ 1090.732930] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6066
[ 1090.739851] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6067
[ 1090.750972] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6068
[ 1090.758164] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6069
[ 1090.765358] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6070
[ 1090.772552] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6071
[ 1090.779742] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6072
[ 1090.786924] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6073
[ 1090.794114] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6074
[ 1090.801299] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6075
[ 1090.808486] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6076
[ 1090.815672] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6077
[ 1090.822856] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6078
[ 1090.830038] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6079
[ 1090.837220] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6080
[ 1090.844404] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6081
[ 1090.855258] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6082
[ 1090.862202] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6083
[ 1090.869384] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6084
[ 1090.876566] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6085
[ 1090.883749] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6086
[ 1090.890930] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6087
[ 1090.898111] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6088
[ 1090.905295] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6089
[ 1090.912484] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6090
[ 1090.919663] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6091
[ 1090.926846] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6092
[ 1090.934033] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6093
[ 1090.941216] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6094
[ 1090.948138] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6095
[ 1090.959251] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6096
[ 1090.966437] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6097
[ 1090.973617] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6098
[ 1090.980797] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6099
[ 1090.987983] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6100
[ 1090.995164] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6101
[ 1091.002344] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6102
[ 1091.009529] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6103
[ 1091.016710] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6104
[ 1091.023891] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6105
[ 1091.031082] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6106
[ 1091.038264] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6107
[ 1091.045445] vi 54080000.vi: tegra_channel_error_status:error 24002 frame 6108
[ 1091.052634] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6109
[ 1091.063750] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6110
[ 1091.070931] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6111
[ 1091.078116] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6112
[ 1091.085296] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6113
[ 1091.092491] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6114
[ 1091.099416] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6115
[ 1091.106598] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6116
[ 1091.113784] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6117
[ 1091.120967] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6118
[ 1091.128147] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6119
[ 1091.135334] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6120
[ 1091.142517] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6121
[ 1091.149708] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6122
[ 1091.156907] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6123
[ 1091.168030] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6124
[ 1091.174961] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6125
[ 1091.182150] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6126
[ 1091.189338] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6127
[ 1091.196522] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6128
[ 1091.203715] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6129
[ 1091.210909] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6130
[ 1091.218094] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6131
[ 1091.270474] vi 54080000.vi: tegra_channel_error_status:error 24022 frame 6133
[ 1091.278977] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6134
[ 1091.289544] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6135
[ 1091.297288] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6136
[ 1091.304537] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6137
[ 1091.311759] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6138
[ 1091.318983] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6139
[ 1091.326210] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6140
[ 1091.333411] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6141
[ 1091.340609] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6142
[ 1091.347553] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6143
[ 1091.354754] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6144
[ 1091.361955] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6145
[ 1091.369158] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6146
[ 1091.376362] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6147
[ 1091.383565] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6148
[ 1091.390767] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6149
[ 1091.397966] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6150
[ 1091.405165] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6151
[ 1091.412367] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6152
[ 1091.419310] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6153
[ 1091.426516] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6154
[ 1091.433717] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6155
[ 1091.440916] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6156
[ 1091.448116] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6157
[ 1091.455318] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6158
[ 1091.462518] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6159
[ 1091.469458] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6160
[ 1091.476661] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6161
[ 1091.483860] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6162
[ 1091.491060] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6163
[ 1091.498263] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6164
[ 1091.505460] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6165
[ 1091.512410] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6166
[ 1091.519592] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6167
[ 1091.526802] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6168
[ 1091.534002] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6169
[ 1091.541215] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6170
[ 1091.548414] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6171
[ 1091.555596] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6172
[ 1091.562819] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6173
[ 1091.570019] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6174
[ 1091.577220] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6175
[ 1091.584437] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6176
[ 1091.591617] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6177
[ 1091.598822] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6178
[ 1091.606025] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6179
[ 1091.613224] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6180
[ 1091.620439] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6181
[ 1091.627626] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6182
[ 1091.634831] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6183
[ 1091.642031] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6184
[ 1091.649233] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6185
[ 1091.656443] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6186
[ 1091.663650] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6187
[ 1091.670868] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6188
[ 1091.678072] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6189
[ 1091.685275] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6190
[ 1091.692478] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6191
[ 1091.699688] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6192
[ 1091.706893] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6193
[ 1091.713839] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6194
[ 1091.721042] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6195
[ 1091.728247] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6196
[ 1091.735450] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6197
[ 1091.742650] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6198
[ 1091.749852] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6199
[ 1091.757056] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6200
[ 1091.763995] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6201
[ 1091.771197] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6202
[ 1091.778400] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6203
[ 1091.785602] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6204
[ 1091.792804] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6205
[ 1091.800006] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6206
[ 1091.807216] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6207
[ 1091.814416] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6208
[ 1091.821620] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6209
[ 1091.828820] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6210
[ 1091.836019] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6211
[ 1091.843222] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6212
[ 1091.850423] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6213
[ 1091.857625] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6214
[ 1091.864830] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6215
[ 1091.872031] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6216
[ 1091.879233] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6217
[ 1091.964715] video4linux video0: frame start syncpt timeout!0
[ 1091.975763] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6220
[ 1091.983700] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6221
[ 1091.992972] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6222
[ 1092.000794] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6223
[ 1092.007743] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6224
[ 1092.015052] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6225
[ 1092.022240] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6226
[ 1092.029492] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6227
[ 1092.036687] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6228
[ 1092.043871] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6229
[ 1092.051052] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6230
[ 1092.058285] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6231
[ 1092.065469] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6232
[ 1092.072666] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6233
[ 1092.079860] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6234
[ 1092.087098] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6235
[ 1092.094281] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6236
[ 1092.101465] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6237
[ 1092.108389] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6238
[ 1092.115602] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6239
[ 1092.201492] video4linux video0: frame start syncpt timeout!0
[ 1092.208160] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6242
[ 1092.216056] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6243
[ 1092.224043] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6244
[ 1092.231298] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6245
[ 1092.238232] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6246
[ 1092.245433] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6247
[ 1092.252661] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6248
[ 1092.259846] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6249
[ 1092.267031] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6250
[ 1092.274213] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6251
[ 1092.281430] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6252
[ 1092.288615] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6253
[ 1092.295797] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6254
[ 1092.302977] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6255
[ 1092.310162] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6256
[ 1092.317385] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6257
[ 1092.324566] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6258
[ 1092.331751] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6259
[ 1092.338933] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6260
[ 1092.346149] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6261
[ 1092.353332] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6262
[ 1092.360695] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6263
[ 1092.368005] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6264
[ 1092.375329] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6265
[ 1092.460557] video4linux video0: frame start syncpt timeout!0
[ 1092.466550] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6268
[ 1092.474009] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6269
[ 1092.481376] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6270
[ 1092.488592] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6271
[ 1092.495909] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6272
[ 1092.503147] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6273
[ 1092.510331] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6274
[ 1092.517513] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6275
[ 1092.524698] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6276
[ 1092.531881] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6277
[ 1092.539090] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6278
[ 1092.546275] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6279
[ 1092.553472] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6280
[ 1092.560655] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6281
[ 1092.567885] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6282
[ 1092.575068] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6283
[ 1092.582249] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6284
[ 1092.589443] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6285
[ 1092.596624] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6286
[ 1092.603835] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6287
[ 1092.611019] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6288
[ 1092.618215] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6289
[ 1092.625136] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6290
[ 1092.632348] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6291
[ 1092.639530] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6292
[ 1092.646710] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6293
[ 1092.653894] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6294
[ 1092.660816] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6295
[ 1092.668023] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6296
[ 1092.675220] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6297
[ 1092.682402] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6298
[ 1092.768551] video4linux video0: frame start syncpt timeout!0
[ 1092.774510] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6301
[ 1092.781908] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6302
[ 1092.789326] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6303
[ 1092.797505] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6304
[ 1092.804705] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6305
[ 1092.811900] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6306
[ 1092.819097] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6307
[ 1092.826316] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6308
[ 1092.833497] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6309
[ 1092.840682] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6310
[ 1092.847863] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6311
[ 1092.932915] video4linux video0: frame start syncpt timeout!0
[ 1092.939570] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6314
[ 1092.947208] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6315
[ 1092.955182] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6316
[ 1092.963199] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6317
[ 1092.970458] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6318
[ 1092.977512] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6319
[ 1092.984771] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6320
[ 1092.991965] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6321
[ 1092.999169] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6322
[ 1093.006365] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6323
[ 1093.013555] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6324
[ 1093.020778] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6325
[ 1093.027972] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6326
[ 1093.035177] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6327
[ 1093.042368] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6328
[ 1093.049589] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6329
[ 1093.056780] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6330
[ 1093.063972] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6331
[ 1093.071167] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6332
[ 1093.078358] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6333
[ 1093.085583] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6334
[ 1093.092791] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6335
[ 1093.099992] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6336
[ 1093.107184] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6337
[ 1093.114406] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6338
[ 1093.121598] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6339
[ 1093.128789] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6340
[ 1093.135984] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6341
[ 1093.142946] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6342
[ 1093.150140] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6343
[ 1093.157526] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6344
[ 1093.164803] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6345
[ 1093.172108] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6346
[ 1093.180340] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6347
[ 1093.187569] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6348
[ 1093.194767] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6349
[ 1093.201954] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6350
[ 1093.288254] video4linux video0: frame start syncpt timeout!0
[ 1093.294088] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6353
[ 1093.301339] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6354
[ 1093.308606] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6355
[ 1093.315812] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6356
[ 1093.323007] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6357
[ 1093.330207] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6358
[ 1093.337393] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6359
[ 1093.344576] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6360
[ 1093.351763] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6361
[ 1093.358945] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6362
[ 1093.366129] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6363
[ 1093.373314] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6364
[ 1093.380243] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6365
[ 1093.387424] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6366
[ 1093.394641] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6367
[ 1093.401846] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6368
[ 1093.409050] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6369
[ 1093.416268] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6370
[ 1093.423448] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6371
[ 1093.430659] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6372
[ 1093.437603] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6373
[ 1093.444803] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6374
[ 1093.452004] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6375
[ 1093.459209] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6376
[ 1093.466410] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6377
[ 1093.473610] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6378
[ 1093.480814] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6379
[ 1093.488014] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6380
[ 1093.495216] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6381
[ 1093.502417] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6382
[ 1093.509617] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6383
[ 1093.516816] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6384
[ 1093.524019] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6385
[ 1093.531224] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6386
[ 1093.538423] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6387
[ 1093.545637] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6388
[ 1093.552838] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6389
[ 1093.560188] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6390
[ 1093.567457] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6391
[ 1093.574694] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6392
[ 1093.581877] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6393
[ 1093.588804] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6394
[ 1093.595987] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6395
[ 1093.603170] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6396
[ 1093.610356] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6397
[ 1093.617539] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6398
[ 1093.624461] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6399
[ 1093.631651] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6400
[ 1093.638573] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6401
[ 1093.645754] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6402
[ 1093.652940] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6403
[ 1093.660121] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6404
[ 1093.667302] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6405
[ 1093.674488] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6406
[ 1093.760345] video4linux video0: frame start syncpt timeout!0
[ 1093.766169] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6409
[ 1093.773406] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6410
[ 1093.780652] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6411
[ 1093.787855] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6412
[ 1093.794789] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6413
[ 1093.801989] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6414
[ 1093.809174] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6415
[ 1093.816355] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6416
[ 1093.900328] video4linux video0: frame start syncpt timeout!0
[ 1093.906551] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6419
[ 1093.914186] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6420
[ 1093.921869] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6421
[ 1093.929068] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6422
[ 1093.936261] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6423
[ 1093.943461] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6424
[ 1093.950645] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6425
[ 1093.957830] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6426
[ 1093.964758] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6427
[ 1093.971941] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6428
[ 1093.979125] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6429
[ 1093.986310] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6430
[ 1093.993491] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6431
[ 1094.000673] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6432
[ 1094.007861] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6433
[ 1094.015042] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6434
[ 1094.022224] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6435
[ 1094.029409] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6436
[ 1094.036590] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6437
[ 1094.043778] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6438
[ 1094.050963] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6439
[ 1094.058145] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6440
[ 1094.065326] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6441
[ 1094.072512] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6442
[ 1094.079718] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6443
[ 1094.086649] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6444
[ 1094.093837] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6445
[ 1094.101020] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6446
[ 1094.108203] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6447
[ 1094.115387] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6448
[ 1094.122568] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6449
[ 1094.129752] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6450
[ 1094.136936] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6451
[ 1094.144118] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6452
[ 1094.151300] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6453
[ 1094.158488] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6454
[ 1094.165670] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6455
[ 1094.172850] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6456
[ 1094.180035] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6457
[ 1094.187218] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6458
[ 1094.194399] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6459
[ 1094.201584] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6460
[ 1094.208766] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6461
[ 1094.215948] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6462
[ 1094.223131] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6463
[ 1094.230313] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6464
[ 1094.237496] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6465
[ 1094.244681] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6466
[ 1094.251609] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6467
[ 1094.258792] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6468
[ 1094.265976] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6469
[ 1094.273157] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6470
[ 1094.280339] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6471
[ 1094.287524] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6472
[ 1094.294706] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6473
[ 1094.301888] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6474
[ 1094.309073] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6475
[ 1094.316255] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6476
[ 1094.323437] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6477
[ 1094.330623] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6478
[ 1094.337806] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6479
[ 1094.344988] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6480
[ 1094.352190] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6481
[ 1094.359375] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6482
[ 1094.444330] video4linux video0: frame start syncpt timeout!0
[ 1094.450756] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6485
[ 1094.458711] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6486
[ 1094.466718] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6487
[ 1094.473990] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6488
[ 1094.481548] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6489
[ 1094.488970] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6490
[ 1094.496390] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6491
[ 1094.503585] vi 54080000.vi: tegra_channel_error_status:error 24002 frame 6492
[ 1094.511168] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6493
[ 1094.518577] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6494
[ 1094.525981] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6495
[ 1094.533389] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6496
[ 1094.540790] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6497
[ 1094.548203] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6498
[ 1094.555402] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6499
[ 1094.562968] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6500
[ 1094.570377] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6501
[ 1094.577779] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6502
[ 1094.585174] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6503
[ 1094.592585] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6504
[ 1094.599987] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6505
[ 1094.607393] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6506
[ 1094.614796] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6507
[ 1094.622195] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6508
[ 1094.629593] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6509
[ 1094.636987] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6510
[ 1094.644382] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6511
[ 1094.651775] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6512
[ 1094.659173] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6513
[ 1094.666574] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6514
[ 1094.673973] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6515
[ 1094.681367] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6516
[ 1094.688764] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6517
[ 1094.696184] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6518
[ 1094.703385] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6519
[ 1094.710958] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6520
[ 1094.718363] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6521
[ 1094.725757] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6522
[ 1094.733175] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6523
[ 1094.740569] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6524
[ 1094.747962] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6525
[ 1094.755370] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6526
[ 1094.762698] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6527
[ 1094.769968] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6528
[ 1094.777222] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6529
[ 1094.784420] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6530
[ 1094.791614] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6531
[ 1094.798550] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6532
[ 1094.805746] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6533
[ 1094.812939] vi 54080000.vi: tegra_channel_error_status:error 24002 frame 6534
[ 1094.820146] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6535
[ 1094.827338] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6536
[ 1094.834530] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6537
[ 1094.841726] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6538
[ 1094.848917] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6539
[ 1094.856109] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6540
[ 1094.863302] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6541
[ 1094.870496] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6542
[ 1094.877429] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6543
[ 1094.884361] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6544
[ 1094.891556] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6545
[ 1094.898747] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6546
[ 1094.905950] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6547
[ 1094.913142] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6548
[ 1094.920334] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6549
[ 1094.927529] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6550
[ 1094.934722] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6551
[ 1094.941913] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6552
[ 1094.949108] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6553
[ 1094.956299] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6554
[ 1094.963494] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6555
[ 1094.970688] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6556
[ 1094.977621] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6557
[ 1094.984555] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6558
[ 1094.991750] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6559
[ 1094.998943] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6560
[ 1095.006136] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6561
[ 1095.013069] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6562
[ 1095.020262] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6563
[ 1095.027454] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6564
[ 1095.034649] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6565
[ 1095.041841] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6566
[ 1095.049033] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6567
[ 1095.056226] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6568
[ 1095.063417] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6569
[ 1095.070608] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6570
[ 1095.077544] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6571
[ 1095.084735] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6572
[ 1095.091670] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6573
[ 1095.176246] video4linux video0: frame start syncpt timeout!0
[ 1095.182321] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6576
[ 1095.190111] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6577
[ 1095.197989] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6578
[ 1095.205272] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6579
[ 1095.212544] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6580
[ 1095.219813] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6581
[ 1095.227053] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6582
[ 1095.234287] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6583
[ 1095.241496] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6584
[ 1095.248699] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6585
[ 1095.255901] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6586
[ 1095.263105] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6587
[ 1095.270308] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6588
[ 1095.277511] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6589
[ 1095.284727] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6590
[ 1095.291920] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6591
[ 1095.299104] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6592
[ 1095.306290] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6593
[ 1095.313473] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6594
[ 1095.320655] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6595
[ 1095.327847] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6596
[ 1095.334769] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6597
[ 1095.341950] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6598
[ 1095.349134] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6599
[ 1095.356315] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6600
[ 1095.363497] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6601
[ 1095.370683] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6602
[ 1095.377865] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6603
[ 1095.384786] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6604
[ 1095.391969] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6605
[ 1095.399151] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6606
[ 1095.406332] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6607
[ 1095.413516] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6608
[ 1095.420697] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6609
[ 1095.427880] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6610
[ 1095.435065] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6611
[ 1095.442247] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6612
[ 1095.449428] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6613
[ 1095.456613] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6614
[ 1095.463795] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6615
[ 1095.470977] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6616
[ 1095.478159] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6617
[ 1095.485342] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6618
[ 1095.492523] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6619
[ 1095.499706] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6620
[ 1095.506886] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6621
[ 1095.513807] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6622
[ 1095.520991] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6623
[ 1095.528179] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6624
[ 1095.535361] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6625
[ 1095.542558] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6626
[ 1095.549740] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6627
[ 1095.556662] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6628
[ 1095.563855] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6629
[ 1095.648221] video4linux video0: frame start syncpt timeout!0
[ 1095.654073] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6632
[ 1095.661369] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6633
[ 1095.668704] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6634
[ 1095.676003] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6635
[ 1095.683307] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6636
[ 1095.690589] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6637
[ 1095.697843] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6638
[ 1095.705094] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6639
[ 1095.712344] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6640
[ 1095.719590] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6641
[ 1095.726836] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6642
[ 1095.734086] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6643
[ 1095.741337] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6644
[ 1095.748586] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6645
[ 1095.755856] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6646
[ 1095.763116] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6647
[ 1095.770365] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6648
[ 1095.777612] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6649
[ 1095.784859] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6650
[ 1095.792117] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6651
[ 1095.799327] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6652
[ 1095.806583] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6653
[ 1095.813835] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6654
[ 1095.821084] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6655
[ 1095.828335] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6656
[ 1095.835582] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6657
[ 1095.842830] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6658
[ 1095.850078] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6659
[ 1095.857326] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6660
[ 1095.864574] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6661
[ 1095.871824] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6662
[ 1095.879072] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6663
[ 1095.886321] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6664
[ 1095.893568] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6665
[ 1095.900816] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6666
[ 1095.908085] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6667
[ 1095.915290] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6668
[ 1095.922539] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6669
[ 1095.929787] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6670
[ 1095.937035] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6671
[ 1095.944281] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6672
[ 1095.951526] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6673
[ 1095.958770] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6674
[ 1095.965956] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6675
[ 1095.973224] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6676
[ 1095.980428] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6677
[ 1095.987629] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6678
[ 1095.994837] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6679
[ 1096.002039] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6680
[ 1096.009241] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6681
[ 1096.016447] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6682
[ 1096.023648] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6683
[ 1096.030847] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6684
[ 1096.038049] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6685
[ 1096.045249] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6686
[ 1096.052186] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6687
[ 1096.059387] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6688
[ 1096.066585] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6689
[ 1096.073524] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6690
[ 1096.080727] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6691
[ 1096.087925] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6692
[ 1096.095126] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6693
[ 1096.102329] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6694
[ 1096.109526] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6695
[ 1096.116724] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6696
[ 1096.123923] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6697
[ 1096.131121] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6698
[ 1096.216181] video4linux video0: frame start syncpt timeout!0
[ 1096.222083] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6701
[ 1096.230891] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6702
[ 1096.238534] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6703
[ 1096.246051] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6704
[ 1096.253562] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6705
[ 1096.260975] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6706
[ 1096.268370] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6707
[ 1096.275765] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6708
[ 1096.283163] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6709
[ 1096.290572] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6710
[ 1096.297973] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6711
[ 1096.305375] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6712
[ 1096.312770] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6713
[ 1096.320198] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6714
[ 1096.327396] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6715
[ 1096.334979] vi 54080000.vi: tegra_channel_error_status:error 20002 frame 6716
[ 1096.342374] vi 54080000.vi: tegra_channel_error_status:error 22 frame 6717
[ 1096.349515] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6718
[ 1096.356908] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6719
[ 1096.364326] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6720
[ 1096.371732] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6721
[ 1096.379134] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6722
[ 1096.386529] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6723
[ 1096.393934] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6724
[ 1096.401329] vi 54080000.vi: tegra_channel_error_status:error 20022 frame 6725
hello sensor_test,
please also refer to https://elinux.org/Jetson_TX2/28.1_Camera_BringUp for more debug tips.
thanks
