I want to make python script running at boot on my Jetson Nano 2G.
My script has display open by openCV and running on TensorRT machine.
What code of service file I need to write?
You need to add a file to /etc/systemd/system
For more details, please check following topic:
I’m trying run a TensorRT object detector at boot using the systemd method but I keep running into errors. My Jetson Nano 2GB is configured to auto-login to LXDE so I don’t have to input the password.
Build info. Jetpack 4.4.1
head -n 1 /etc/nv_tegra_release
#R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t210ref, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
Here are the steps I took.
Created startup_detection_script.py
import os
os.system("cd /home/ag72/tensorrt_demos && pyt…
I solved already
Thank you very much
