Run TAO training probelm
The machine has ubuntu22.04, right? But the log shows18.04 in $distribution . Could you double check?
The OS of this machine is ubuntu 22.04. I don’t know why there shows 18.04 there.
Can you share the result of
$cat /etc/lsb-release
Can you run below and share the result?
local-morganh@a4u8g-0088:~$ distribution=$(. /etc/os-release;echo $ID$VERSION_ID)
local-morganh@a4u8g-0088:~$ echo $distribution
So, please run below again and share the result.
$ curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey | \
sudo apt-key add -
$ curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list | \
sudo tee /etc/apt/sources.list.d/nvidia-docker.list
$ sudo apt-get update
$ sudo apt-get install -y nvidia-docker2
$ sudo pkill -SIGHUP dockerd
$ sudo systemctl restart docker.service
I use a new ubuntu22.04 machine but can not reproduce the error.
Attach log.
20240429_forum_290400_nvidia_docker.txt (18.8 KB)
The log you shared seems that there are some errors when run $sudo apt-get update.
Can you check it why it is failed? You can search the solution via network as well.
