I tried to run VehicleMakeNet on my NVIDIA Jetson Nano but encountered several issues.
Device: NVIDIA Jetson Nano
JetPack: 4.6.1
DeepStream: 6.0.1
I have changed the execution script as follows to support DeepStream 6.0 because the original command is for DeepStream 5.1:
sudo docker run --gpus all -it --rm -v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY=$DISPLAY -v $HOME:/opt/nvidia/deepstream/deepstream-6.0/samples/models/tlt_pretrained_models -w /opt/nvidia/deepstream/deepstream-6.0/samples/configs/tlt_pretrained_models nvcr.io/nvidia/deepstream-l4t:6.0-samples deepstream-app -c deepstream_app_source1_dashcamnet_vehiclemakenet_vehicletypenet.txt
Error Log:
docker: Error response from daemon: could not select device driver “” with capabilities: [[GPU]].
Could this a problem about my DeepStream version along with my JetPack? I can reinstall JetPack 4.5.1 which contains DeepStream 5.1, however, before that it is better if there is a solution.
Thank you.
