Can you please tell me how to run this script inside Isaac Sim Script Editor GUI?
I had to remove SimulationApp so I don’t know what to do when we need to use it. So far, I have commented those lines.
Here’s the code:
from omni.isaac.kit import SimulationApp
import os
import glob
import shutil
import traceback
# Set rendering parameters and create an instance of kit
CONFIG = {"renderer": "RayTracedLighting", "headless": True, "width": 1024, "height": 1024, "num_frames": 10}
ENV_URL = "/Isaac/Samples/Replicator/Stage/full_warehouse_worker_and_anim_cameras.usd"
FORKLIFT_URL = "/Isaac/Props/Forklift/forklift.usd"
PALLET_URL = "/Isaac/Environments/Simple_Warehouse/Props/SM_PaletteA_01.usd"
PALLET_2_URL = "/Isaac/Environments/Simple_Warehouse/Props/SM_PaletteA_02.usd"
CARDBOX_URL = "/Isaac/Environments/Simple_Warehouse/Props/SM_CardBoxD_04.usd"
CONE_URL = "/Isaac/Environments/Simple_Warehouse/Props/S_TrafficCone.usd"
SCOPE_NAME = "/MyScope"
import carb
import random
import math
import numpy as np
from pxr import UsdGeom, Usd, Gf, UsdPhysics, PhysxSchema
import inspect
import omni.usd
from omni.isaac.core import World
from omni.isaac.core.utils import prims
from omni.isaac.core.prims import RigidPrim
from omni.isaac.core.utils.nucleus import get_assets_root_path
from omni.isaac.core.utils.stage import get_current_stage, open_stage
from omni.isaac.core.utils.rotations import euler_angles_to_quat, quat_to_euler_angles, lookat_to_quatf
from omni.isaac.core.utils.bounds import compute_combined_aabb, create_bbox_cache
from omni.isaac.core.utils.random import get_random_world_pose_in_view
from omni.replicator.isaac.scripts.writers import DOPEWriter
from omni.syntheticdata import SyntheticData
from omni.isaac.core.prims import XFormPrim
# Helper function to find the assets server
def prefix_with_isaac_asset_server(relative_path):
assets_root_path = get_assets_root_path()
if assets_root_path is None:
raise Exception("Nucleus server not found, could not access Isaac Sim assets folder")
return assets_root_path + relative_path
# Increase subframes if shadows/ghosting appears of moving objects
# See known issues: https://docs.omniverse.nvidia.com/prod_extensions/prod_extensions/ext_replicator.html#known-issues
rep.settings.carb_settings("/omni/replicator/RTSubframes", 2)
world = World()
world.reset()
# Randomize boxes materials and their location on the surface of the given prim
def register_scatter_boxes(prim):
# Calculate the bounds of the prim to create a scatter plane of its size
bb_cache = create_bbox_cache()
bbox3d_gf = bb_cache.ComputeLocalBound(prim)
prim_tf_gf = omni.usd.get_world_transform_matrix(prim)
bbox3d_gf.Transform(prim_tf_gf)
range_size = bbox3d_gf.GetRange().GetSize()
# Get the quaterion of the prim in xyzw format from usd
prim_quat_gf = prim_tf_gf.ExtractRotation().GetQuaternion()
prim_quat_xyzw = (prim_quat_gf.GetReal(), *prim_quat_gf.GetImaginary())
# Create a plane on the pallet to scatter the boxes on
plane_scale = (range_size[0] * 0.8, range_size[1] * 0.8, 1)
plane_pos_gf = prim_tf_gf.ExtractTranslation() + Gf.Vec3d(0, 0, range_size[2])
plane_rot_euler_deg = quat_to_euler_angles(np.array(prim_quat_xyzw), degrees=True)
scatter_plane = rep.create.plane(
scale=plane_scale, position=plane_pos_gf, rotation=plane_rot_euler_deg, visible=False
cardbox_mats = [
prefix_with_isaac_asset_server("/Isaac/Environments/Simple_Warehouse/Materials/MI_PaperNotes_01.mdl"),
prefix_with_isaac_asset_server("/Isaac/Environments/Simple_Warehouse/Materials/MI_CardBoxB_05.mdl"),
print("cardbox materials:", cardbox_mats)
def scatter_boxes():
cardboxes = rep.create.from_usd(
prefix_with_isaac_asset_server(CARDBOX_URL), semantics=[("class", "Cardbox")], count=30
# type of cardboxes: <class 'omni.replicator.core.scripts.utils.utils.ReplicatorItem'>
with cardboxes:
rep.randomizer.scatter_2d(scatter_plane, check_for_collisions=True)
rep.randomizer.materials(cardbox_mats)
return cardboxes.node
rep.randomizer.register(scatter_boxes)
# Randomize lights around the scene
def register_lights_placement(forklift_prim, pallet_prim):
combined_range_arr = compute_combined_aabb(bb_cache, [forklift_prim.GetPrimPath(), pallet_prim.GetPrimPath()])
pos_min = (combined_range_arr[0], combined_range_arr[1], 6)
pos_max = (combined_range_arr[3], combined_range_arr[4], 7)
def randomize_lights():
lights = rep.create.light(
light_type="Sphere",
color=rep.distribution.uniform((0.0, 0.0, 0.0), (1.0, 1.0, 1.0)),
intensity=rep.distribution.uniform(500, 3000),
position=rep.distribution.uniform(pos_min, pos_max),
scale=rep.distribution.uniform(1, 20),
count=5,
return lights.node
rep.randomizer.register(randomize_lights)
def simulate_falling_objects(prim, num_sim_steps=250, num_boxes=50):
# Create a simulation ready world
world = World(physics_dt=1.0 / 90.0, stage_units_in_meters=1.0)
# Choose a random spawn offset relative to the given prim
prim_tf = omni.usd.get_world_transform_matrix(prim)
spawn_offset_tf = Gf.Matrix4d().SetTranslate(Gf.Vec3d(random.uniform(-0.5, 0.5), random.uniform(3, 3.5), 0))
spawn_pos_gf = (spawn_offset_tf * prim_tf).ExtractTranslation()
# Spawn pallet prim
pallet_prim_name = "SimulatedPallet"
pallet_prim = prims.create_prim(
prim_path=f"{SCOPE_NAME}/{pallet_prim_name}",
usd_path=prefix_with_isaac_asset_server(PALLET_URL),
semantic_label="Pallet",
# Get the height of the pallet
curr_spawn_height = bb_cache.ComputeLocalBound(pallet_prim).GetRange().GetSize()[2] * 1.1
# Wrap the pallet prim into a rigid prim to be able to simulate it
pallet_rigid_prim = RigidPrim(
prim_path=str(pallet_prim.GetPrimPath()),
name=pallet_prim_name,
position=spawn_pos_gf + Gf.Vec3d(0, 0, curr_spawn_height),
# Make sure physics are enabled on the rigid prim
pallet_rigid_prim.enable_rigid_body_physics()
# Register rigid prim with the scene
world.scene.add(pallet_rigid_prim)
# Spawn boxes falling on the pallet
for i in range(num_boxes):
# Spawn box prim
cardbox_prim_name = f"SimulatedCardbox_{i}"
box_prim = prims.create_prim(
prim_path=f"{SCOPE_NAME}/{cardbox_prim_name}",
usd_path=prefix_with_isaac_asset_server(CARDBOX_URL),
semantic_label="Cardbox",
# Add the height of the box to the current spawn height
curr_spawn_height += bb_cache.ComputeLocalBound(box_prim).GetRange().GetSize()[2] * 1.1
# Wrap the cardbox prim into a rigid prim to be able to simulate it
box_rigid_prim = RigidPrim(
prim_path=str(box_prim.GetPrimPath()),
name=cardbox_prim_name,
position=spawn_pos_gf + Gf.Vec3d(random.uniform(-0.2, 0.2), random.uniform(-0.2, 0.2), curr_spawn_height),
orientation=euler_angles_to_quat([0, 0, random.uniform(0, math.pi)]),
box_rigid_prim.enable_rigid_body_physics()
world.scene.add(box_rigid_prim)
# Reset world after adding simulated assets for physics handles to be propagated properly
world.reset()
# Simulate the world for the given number of steps or until the highest box stops moving
last_box = world.scene.get_object(f"SimulatedCardbox_{num_boxes - 1}")
for i in range(num_sim_steps):
world.step(render=False)
if last_box and np.linalg.norm(last_box.get_linear_velocity()) < 0.001:
print(f"Simulation stopped after {i} steps")
break
# Starts replicator and waits until all data was successfully written
def run_orchestrator():
rep.orchestrator.run()
# # Wait until started
# while not rep.orchestrator.get_is_started():
# simulation_app.update()
# # Wait until stopped
# while rep.orchestrator.get_is_started():
rep.BackendDispatch.wait_until_done()
rep.orchestrator.stop()
def register_color_randomizer(prim_path):
prim = rep.get.prims(semantics=[('class', 'Forklift'), ('class', 'Pallet'), ('class', 'Cardbox')])
def randomize_color():
mats = rep.create.material_omnipbr(
metallic=rep.distribution.uniform(0.0, 1.0),
roughness=rep.distribution.uniform(0.0, 1.0),
diffuse=rep.distribution.uniform((0, 0, 0), (1, 1, 1)),
specular=rep.distribution.uniform(0.0, 1.0),
count=1000,
with prim:
rep.randomizer.materials(mats)
return prim.node
rep.randomizer.register(randomize_color)
def main():
# Open the environment in a new stage
if os.path.exists(os.getcwd() + '/dope_out_headless'):
shutil.rmtree(os.getcwd() + '/dope_out_headless', ignore_errors=False, onerror=None)
if os.path.exists(os.getcwd() + '/_output_headless'):
shutil.rmtree(os.getcwd() + '/_output_headless', ignore_errors=False, onerror=None)
print(f"Loading Stage {ENV_URL}")
open_stage(prefix_with_isaac_asset_server(ENV_URL))
# Create a custom scope for newly added prims
stage = get_current_stage()
scope = UsdGeom.Scope.Define(stage, SCOPE_NAME)
with rep.trigger.on_frame(interval=2, rt_subframes=16):
# Spawn a new forklift at a random pose
forklift_prim = prims.create_prim(
prim_path=f"{SCOPE_NAME}/Forklift",
position=(random.uniform(-20, -2), random.uniform(-1, 3), 0),
#position=(random.uniform(-50, -4), random.uniform(-1, 3), 0),
usd_path=prefix_with_isaac_asset_server(FORKLIFT_URL),
semantic_label="Forklift",
# forklift_prim type: <class 'pxr.Usd.Prim'>
# Spawn the pallet in front of the forklift with a random offset on the Y axis
forklift_tf = omni.usd.get_world_transform_matrix(forklift_prim)
pallet_offset_tf = Gf.Matrix4d().SetTranslate(Gf.Vec3d(0, random.uniform(-1.2, -2.4), 0))
pallet_pos_gf = (pallet_offset_tf * forklift_tf).ExtractTranslation()
forklift_quat_gf = forklift_tf.ExtractRotation().GetQuaternion()
forklift_quat_xyzw = (forklift_quat_gf.GetReal(), *forklift_quat_gf.GetImaginary())
prim_path=f"{SCOPE_NAME}/Pallet",
position=pallet_pos_gf,
orientation=forklift_quat_xyzw,
# Simulate dropping objects on a pile behind the forklift
simulate_falling_objects(forklift_prim)
# Register randomizers
register_scatter_boxes(pallet_prim)
register_color_randomizer(pallet_prim)
# Spawn a camera in the driver's location looking at the pallet
foklift_pos_gf = forklift_tf.ExtractTranslation()
driver_cam_pos_gf = foklift_pos_gf + Gf.Vec3d(0.0, 0.0, 1.9)
rotate_180_on_y_quat_gf = Gf.Quatf(0, 0, 1, 0)
look_at_pallet_quat_gf = lookat_to_quatf(driver_cam_pos_gf, pallet_pos_gf, (0, 0, 1)) * rotate_180_on_y_quat_gf
look_at_pallet_xyzw = (look_at_pallet_quat_gf.GetReal(), *look_at_pallet_quat_gf.GetImaginary())
driver_cam_prim = prims.create_prim(
prim_path=f"{SCOPE_NAME}/DriverCamera",
prim_type="Camera",
position=driver_cam_pos_gf,
orientation=look_at_pallet_xyzw,
attributes={"focusDistance": 400, "focalLength": 24, "clippingRange": (0.1, 10000000)},
# Camera looking at the pallet
pallet_cam = rep.create.camera()
# Top View Camera
# Camera looking at the forklift from a top view with large min clipping to see the scene through the ceiling
top_view_cam = rep.create.camera(clipping_range=(6.0, 1000000.0))
# TODO: access the current frame number
with rep.trigger.on_frame(num_frames=CONFIG["num_frames"]):
rep.randomizer.scatter_boxes()
rep.randomizer.randomize_lights()
rep.randomizer.randomize_color()
pos_min = (pallet_pos_gf[0] - 2, pallet_pos_gf[1] - 2, 2)
pos_max = (pallet_pos_gf[0] + 2, pallet_pos_gf[1] + 2, 4)
with pallet_cam:
rep.modify.pose(position=rep.distribution.uniform(pos_min, pos_max), look_at=str(pallet_prim.GetPrimPath()))
with top_view_cam:
rep.modify.pose(
(foklift_pos_gf[0], foklift_pos_gf[1], 9), (foklift_pos_gf[0], foklift_pos_gf[1], 11)
rotation=rep.distribution.uniform((0, -90, 0), (0, -90, 180)),
#Basic Writer
# Initialize and attach writer
writer = rep.WriterRegistry.get("BasicWriter")
output_directory = os.getcwd() + "/_output_headless"
print("Outputting data to ", output_directory)
writer.initialize(
output_dir=output_directory,
rgb=True,
bounding_box_2d_tight=True,
semantic_segmentation=True,
instance_segmentation=True,
distance_to_image_plane=True,
bounding_box_3d=True,
occlusion=True,
normals=True,
RESOLUTION = (CONFIG["width"], CONFIG["height"])
driver_rp = rep.create.render_product(str(driver_cam_prim.GetPrimPath()), RESOLUTION)
pallet_rp = rep.create.render_p
roduct(pallet_cam, RESOLUTION)
forklift_rp = rep.create.render_product(top_view_cam, RESOLUTION)
writer.attach([driver_rp, forklift_rp, pallet_rp])
run_orchestrator()
if __name__ == "__main__":
try:
main()
except Exception as e:
carb.log_error(f"Exception: {e}")
traceback.print_exc()
# finally:
# simulation_app.close()
I need to see how the stage that is spawned in the code and the other stuff look like as well as randomizations. I was suggested to run it inside Script Editor.
^ Since we cannot use SimulationApp inside Script Editor, I am unsure what happens to these in Isaac Sim?
Here’s the zoomed-in error:
