Various API function names were changed slightly from when the sample code was written to when the doc was published. These changes can be deduced by studying the documentation for corresponding function names, and the cusolverRf.h header file for a few other items. Apologies for the confusion.
The following code WHILE NOT COMPLETE, should demonstrate how to fix all the compile errors in the published code. It is not complete because the original sample code does not purport to provide all the necessary data (matrices and vectors) to run a sample solve test. However I’m providing this to help with the compiler errors that you mention:
$ cat t734.cu
#include <stdio.h>
#include <stdlib.h>
#include <cuda_runtime.h>
#include "cusolverRf.h"
#define TEST_PASSED 0
#define TEST_FAILED 1
int main (void){
/* matrix A */
int n;
int nnzA;
int *Ap=NULL;
int *Ai=NULL;
double *Ax=NULL;
int *d_Ap=NULL;
int *d_Ai=NULL;
double *d_rAx=NULL;
/* matrices L and U */
int nnzL, nnzU;
int *Lp=NULL;
int *Li=NULL;
double* Lx=NULL;
int *Up=NULL;
int *Ui=NULL;
double* Ux=NULL;
/* reordering matrices */
int *P=NULL;
int *Q=NULL;
int * d_P=NULL;
int * d_Q=NULL;
/* solution and rhs */
int nrhs; //# of rhs for each system (currently only =1 is supported)
double *d_X=NULL;
double *d_T=NULL;
/* cuda */
cudaError_t cudaStatus;
/* cuolverRf */
cusolverRfHandle_t gH=NULL;
cusolverStatus_t status;
/* host sparse direct solver */
/* other variables */
int tnnzL, tnnzU;
int *tLp=NULL;
int *tLi=NULL;
double *tLx=NULL;
int *tUp=NULL;
int *tUi=NULL;
double *tUx=NULL;
clock_t t1, t2;
/* ASSUMPTION: recall that we are solving a set of linear systems
A_{i} x_{i} = f_{i} for i=0,...,k-1
where the sparsity pattern of the coefficient matrices A_{i}
as well as the reordering to minimize fill-in and the pivoting
used during the LU factorization remain the same. */
/* Step 1: solve the first linear system (i=0) on the host,
using host sparse direct solver, which involves
full LU factorization and solve. */
/* Step 2: interface to the library by extracting the following
information from the first solve:
a) triangular factors L and U
b) pivoting and reordering permutations P and Q
c) also, allocate all the necessary memory */
/* Step 3: use the library to solve subsequent (i=1,...,k-1) linear systems
a) the library setup (called only once) */
//create handle
status = cusolverRfCreate(&gH);
if (status != CUSOLVER_STATUS_SUCCESS){
printf ("[cusolverRf status %d]\n",status);
return TEST_FAILED;
//set fast mode
status = cusolverRfSetResetValuesFastMode(gH,CUSOLVERRF_RESET_VALUES_FAST_MODE_ON);
return TEST_FAILED;
//assemble internal data structures (you should use the coeffcient matrix A
//corresponding to the second (i=1) linear system in this call)
t1 = clock();
status = cusolverRfSetupHost(n, nnzA, Ap, Ai, Ax,
nnzL, Lp, Li, Lx, nnzU, Up, Ui, Ux, P, Q, gH);
cudaStatus = cudaDeviceSynchronize();
t2 = clock();
if ((status != CUSOLVER_STATUS_SUCCESS) || (cudaStatus != cudaSuccess)) {
return TEST_FAILED;
printf("cusolverRfSetupHost time = %f (s)\n", (t2-t1)/(float)CLOCKS_PER_SEC);
//analyze available parallelism
t1 = clock();
status = cusolverRfAnalyze(gH);
t2 = clock();
return TEST_FAILED;
printf("cusolverRfAnalyze time = %f (s)\n", (t2-t1)/(float)CLOCKS_PER_SEC);
/* b) The library subsequent (i=1,...,k-1) LU re-factorization
and solve (called multiple times). */
int k = 2;
for (int i=1; i<k; i++){
//LU re-factorization
t1 = clock();
status = cusolverRfRefactor(gH);
t2 = clock();
printf ("[cusolverRF status %d]\n",status);
return TEST_FAILED;
printf("cuSolverReRefactor time = %f (s)\n", (t2-t1)/(float)CLOCKS_PER_SEC);
//forward and backward solve
t1 = clock();
status = cusolverRfSolve(gH, d_P, d_Q, nrhs, d_T, n, d_X, n);
t2 = clock();
return TEST_FAILED;
printf("cusolverRfSolve time = %f (s)\n", (t2-t1)/(float)CLOCKS_PER_SEC);
// extract the factors (if needed)
status = cusolverRfExtractSplitFactorsHost(gH, &tnnzL, &tLp, &tLi, &tLx,
&tnnzU, &tUp, &tUi, &tUx);
if(status != CUSOLVER_STATUS_SUCCESS){
return TEST_FAILED;
//print
int row, j;
printf("printing L\n");
for (row=0; row<n; row++){
for (j=tLp[row]; j<tLp[row+1]; j++){
printf("\%d,\%d,\%f\n",row,tLi[j],tLx[j]);
printf("printing U\n");
for (j=tUp[row]; j<tUp[row+1]; j++){
printf("\%d,\%d,\%f\n",row,tUi[j],tUx[j]);
/* perform any other operations based on the solution */
/* check if done */
/* proceed to solve the next linear system */
// update the coefficient matrix using reset values
// (assuming that the new linear system, in other words,
// new values are already on the GPU in the array d_rAx)
t1 = clock();
status = cusolverRfResetValues(n,nnzA,d_Ap,d_Ai,d_rAx,d_P,d_Q,gH);
t2 = clock();
return TEST_FAILED;
printf("cusolverRf_reset_values time = %f (s)\n", (t2-t1)/(float)CLOCKS_PER_SEC);
/* free memory and exit */
return TEST_PASSED;
$ nvcc -o t734 t734.cu -lcusolver
t734.cu(96): warning: variable "n" is used before its value is set
t734.cu(96): warning: variable "nnzA" is used before its value is set
t734.cu(97): warning: variable "nnzL" is used before its value is set
t734.cu(97): warning: variable "nnzU" is used before its value is set
There are many values not provided for as I indicated. Furthermore, I have provided sample i and k values, but the k value needs to be modified for your actual case. The warnings above stem from variables that need to be supplied (along with many others) to make a complete test case.
