Hello
I recently tested DeepSeek-V4-Flash-0731 on a single node equipped with 4xNVIDIA H100 80GB HBM3 GPUs, using SGLang with tensor parallelism.
I created a Python 3.12 environment using uv:
uv venv .sglang --python 3.12
source .sglang/bin/activate
uv pip install "sglang[all]"
uv pip install --prerelease=allow --index-strategy unsafe-best-match --extra-index-url https://docs.sglang.ai/whl/cu130/ sglang
The server was launched with TP=4 and the FlashInfer MXFP4 MoE backend:
sglang serve \
--trust-remote-code \
--model-path deepseek-ai/DeepSeek-V4-Flash-0731 \
--tp 4 \
--moe-runner-backend flashinfer_mxfp4 \
--speculative-algorithm DSPARK \
--mem-fraction-static 0.85 \
--chunked-prefill-size 4096 \
--reasoning-parser auto \
--tool-call-parser auto \
--swa-full-tokens-ratio 0.1
output log
[2026-09-26 23:05:16] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:16] Hybrid SWA model detected. architectures=['DeepseekV4ForCausalLM']
[2026-09-26 23:05:16] Breakable CUDA graph is incompatible with DeepSeek-V4 (heavy capture-pool memory pressure); disabling prefill CUDA graph.
[2026-09-26 23:05:16] Use dsv4 attention backend for DeepseekV4ForCausalLM, setting page_size to 256.
[2026-09-26 23:05:16] Setting KV cache dtype to fp8_e4m3 for DeepseekV4ForCausalLM.
[2026-09-26 23:05:16] Setting max_running_requests to 256 for DeepseekV4ForCausalLM.
[2026-09-26 23:05:16] Auto-enabling FlashInfer AllReduce Fusion on SM90/SM10X for DeepseekV4ForCausalLM
[2026-09-26 23:05:17] DSpark draft weights are bundled in the target checkpoint; defaulting --speculative-draft-model-path to --model-path (deepseek-ai/DeepSeek-V4-Flash-0731).
[2026-09-26 23:05:19] Compiled-kernel caches now live under SGLANG_CACHE_DIR (/shared/home/shakhizat.nurgaliyev/.cache/sglang). These older directories are no longer used by sglang, but may still be used by other frameworks on this machine, so they were left alone: /shared/home/shakhizat.nurgaliyev/.triton. Remove them yourself if nothing else needs them.
[2026-09-26 23:05:19] server_args={'model_path': 'deepseek-ai/DeepSeek-V4-Flash-0731', 'tokenizer_path': 'deepseek-ai/DeepSeek-V4-Flash-0731', 'tokenizer_mode': 'auto', 'tokenizer_backend': 'huggingface', 'tokenizer_worker_num': 1, 'detokenizer_worker_num': 1, 'skip_tokenizer_init': False, 'load_format': 'auto', 'model_loader_extra_config': '{}', 'trust_remote_code': True, 'context_length': None, 'is_embedding': False, 'enable_multimodal': None, 'revision': None, 'model_impl': 'auto', 'model_config_parser': 'auto', 'json_model_override_args': '{}', 'dtype': 'auto', 'quantization': None, 'quantization_param_path': None, 'kv_cache_dtype': 'fp8_e4m3', 'enable_fp32_lm_head': False, 'modelopt_quant': None, 'modelopt_checkpoint_restore_path': None, 'modelopt_checkpoint_save_path': None, 'modelopt_export_path': None, 'quantize_and_serve': False, 'rl_quant_profile': None, 'enable_tf32_matmul': False, 'mem_fraction_static': 0.84, 'max_running_requests': 256, 'max_queued_requests': None, 'max_total_tokens': None, 'chunked_prefill_size': 4096, 'prefill_decode_interval': 0, 'enable_dynamic_chunking': False, 'max_prefill_tokens': 16384, 'prefill_max_requests': None, 'schedule_policy': 'fcfs', 'enable_priority_scheduling': False, 'disable_priority_preemption': False, 'default_priority_value': None, 'abort_on_priority_when_disabled': False, 'schedule_low_priority_values_first': False, 'priority_scheduling_preemption_threshold': 10, 'retraction_policy': 'length', 'schedule_conservativeness': 1.0, 'page_size': 256, 'c128_page_size': 16, 'swa_full_tokens_ratio': 0.1, 'disable_hybrid_swa_memory': False, 'radix_eviction_policy': 'lru', 'radix_eviction_policy_config': None, 'prefill_only_disable_kv_cache': False, 'disable_radix_cache': False, 'enable_page_major_kv_layout': False, 'enable_unified_memory': False, 'disable_chunked_prefix_cache': False, 'disable_overlap_schedule': False, 'num_continuous_decode_steps': 1, 'scheduler_recv_interval': 1, 'enable_mixed_chunk': False, 'nccl_port': None, 'dist_timeout': None, 'dist_init_addr': None, 'gated_launch_port': None, 'nnodes': 1, 'node_rank': 0, 'tp_size': 4, 'dcp_size': 1, 'pp_size': 1, 'pp_max_micro_batch_size': None, 'pp_async_batch_depth': 0, 'dp_size': 1, 'load_balance_method': 'round_robin', 'attn_cp_size': 1, 'moe_dp_size': 1, 'dwdp_size': 1, 'dcp_comm_backend': 'ag_rs', 'dcp_replicate_q_proj': None, 'enable_prefill_cp': False, 'cp_strategy': None, 'enable_dsa_cache_layer_split': False, 'enable_cp_decode_attn_tp': False, 'enable_dp_attention': False, 'enable_dp_attention_local_control_broadcast': False, 'enable_dp_lm_head': False, 'enable_tp_lm_head_all_to_all': False, 'enable_attn_tp_input_scattered': False, 'enable_shared_experts_attn_tp': False, 'enable_dense_mlp_attn_tp': False, 'enable_layernorm_sp': False, 'disable_attn_tp_gather': False, 'enable_p2p_check': False, 'device': 'cuda', 'base_gpu_id': 0, 'gpu_id_step': 1, 'random_seed': 315061678, 'mlx_enable_sampling': False, 'watchdog_timeout': 300, 'soft_watchdog_timeout': None, 'sleep_on_idle': False, 'use_ray': False, 'custom_sigquit_handler': None, 'numa_node': None, 'gc_threshold': None, 'host': '127.0.0.1', 'port': 30000, 'fastapi_root_path': '', 'smg_grpc_mode': False, 'grpc_mode': False, 'grpc_port': None, 'grpc_worker_threads': 4, 'sidecar': None, 'sidecar_args': None, 'skip_server_warmup': False, 'warmups': None, 'enable_http2': False, 'http2_max_concurrent_streams': 200, 'http2_initial_connection_window_size': 1048576, 'ssl_keyfile': None, 'ssl_certfile': None, 'ssl_ca_certs': None, 'ssl_keyfile_password': None, 'enable_ssl_refresh': False, 'api_key': None, 'admin_api_key': None, 'served_model_name': 'deepseek-ai/DeepSeek-V4-Flash-0731', 'weight_version': 'default', 'chat_template': None, 'hf_chat_template_name': None, 'completion_template': None, 'file_storage_path': 'sglang_storage', 'enable_cache_report': False, 'return_input_ids': False, 'return_output_ids': False, 'reasoning_parser': None, 'default_chat_template_kwargs': None, 'strip_thinking_cache': False, 'enable_strict_thinking': False, 'tool_call_parser': None, 'tool_server': None, 'sampling_defaults': 'model', 'asr_max_buffer_seconds': 60, 'asr_max_concurrent_sessions': 32, 'preferred_sampling_params': None, 'allow_auto_truncate': False, 'stream_interval': 1, 'batch_notify_size': 16, 'stream_response_default_include_usage': False, 'incremental_streaming_output': False, 'enable_streaming_session': False, 'enable_session_radix_cache': False, 'log_level': 'info', 'log_level_http': None, 'log_requests': False, 'log_requests_level': 2, 'log_requests_format': 'text', 'log_requests_target': None, 'uvicorn_access_log_exclude_prefixes': [], 'crash_dump_folder': None, 'show_time_cost': False, 'enable_metrics': False, 'smg_http_sidecar_port': None, 'enable_mfu_metrics': False, 'enable_metrics_for_all_schedulers': False, 'load_snapshot_publish_interval': 15, 'tokenizer_metrics_custom_labels_header': 'x-custom-labels', 'tokenizer_metrics_allowed_custom_labels': None, 'extra_metric_labels': None, 'bucket_time_to_first_token': None, 'bucket_inter_token_latency': None, 'bucket_e2e_request_latency': None, 'prompt_tokens_buckets': None, 'generation_tokens_buckets': None, 'gc_warning_threshold_secs': 0.0, 'decode_log_interval': 40, 'enable_request_time_stats_logging': False, 'kv_events_config': None, 'load_publish_endpoint': None, 'enable_forward_pass_metrics': False, 'forward_pass_metrics_worker_id': '', 'forward_pass_metrics_ipc_name': None, 'enable_trace': False, 'trace_modules': 'request', 'otlp_traces_endpoint': 'localhost:4317', 'export_metrics_to_file': False, 'export_metrics_to_file_dir': None, 'stat_loggers': None, 'constrained_json_whitespace_pattern': None, 'constrained_json_disable_any_whitespace': False, 'attention_backend': 'dsv4', 'decode_attention_backend': None, 'enable_lean_attention': None, 'prefill_attention_backend': None, 'sampling_backend': 'flashinfer', 'grammar_backend': 'xgrammar', 'radix_cache_backend': None, 'mm_attention_backend': None, 'fp8_gemm_runner_backend': 'auto', 'fp4_gemm_runner_backend': 'auto', 'bf16_gemm_backend': 'auto', 'dsa_prefill_backend': None, 'dsv4_prefill_backend': 'auto', 'dsa_decode_backend': None, 'dsa_paged_mqa_logits_backend': 'auto', 'dsa_topk_backend': 'sgl-kernel', 'disable_flashinfer_autotune': False, 'flashinfer_autotune_skip_ops': None, 'mamba_backend': 'triton', 'cuda_graph_config': {'decode': {'backend': 'full', 'max_bs': 512, 'bs': [1, 2, 3, 4, 5, 6, 7, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 40, 44, 48, 52, 56, 60, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256, 272, 288, 304, 320, 336, 352, 368, 384, 400, 416, 432, 448, 464, 480, 496, 512], 'tc_compiler': 'eager', 'full_prefill_max_req': None, 'full_prefill_prefix_chunk_tokens': None}, 'prefill': {'backend': 'disabled', 'max_bs': 4096, 'bs': [4, 8, 12, 16, 20, 24, 28, 32, 48, 64, 80, 96, 112, 128, 144, 160, 176, 192, 208, 224, 240, 256, 288, 320, 352, 384, 416, 448, 480, 512, 576, 640, 704, 768, 832, 896, 960, 1024, 1280, 1536, 1792, 2048, 2304, 2560, 2816, 3072, 3328, 3584, 3840, 4096], 'tc_compiler': 'eager', 'full_prefill_max_req': None, 'full_prefill_prefix_chunk_tokens': None}}, 'cuda_graph_backend_decode': None, 'cuda_graph_backend_prefill': None, 'cuda_graph_max_bs_decode': None, 'cuda_graph_max_bs_prefill': None, 'cuda_graph_bs_decode': None, 'cuda_graph_bs_prefill': None, 'cuda_graph_tc_compiler': None, 'disable_prefill_cuda_graph': False, 'disable_decode_cuda_graph': False, 'disable_cuda_graph': False, 'disable_cuda_graph_padding': False, 'enable_profile_cuda_graph': False, 'enable_cudagraph_gc': False, 'debug_cuda_graph': False, 'enable_layerwise_nvtx_marker': False, 'enable_nccl_nvls': False, 'enable_symm_mem': False, 'triton_attention_reduce_in_fp32': False, 'triton_attention_num_kv_splits': 8, 'triton_attention_split_tile_size': None, 'flashinfer_mla_disable_ragged': False, 'enable_fused_qk_norm_rope': False, 'enable_precise_embedding_interpolation': False, 'enable_fused_moe_sum_all_reduce': False, 'enable_deepseek_v4_fp4_indexer': False, 'disable_custom_all_reduce': False, 'enable_mscclpp': False, 'enable_torch_symm_mem': False, 'enable_scattered_sconv': False, 'pre_warm_nccl': False, 'enable_quant_communications': False, 'enable_flashinfer_allreduce_fusion': False, 'enforce_disable_flashinfer_allreduce_fusion': False, 'flashinfer_allreduce_fusion_backend': 'auto', 'enable_aiter_allreduce_fusion': False, 'enable_torch_compile': False, 'enable_torch_compile_debug_mode': False, 'torch_compile_max_bs': 32, 'speculative_algorithm': 'DSPARK', 'uno_lora_path': None, 'speculative_draft_model_path': 'deepseek-ai/DeepSeek-V4-Flash-0731', 'speculative_draft_model_revision': None, 'speculative_draft_load_format': None, 'speculative_num_steps': 1, 'speculative_eagle_topk': 1, 'speculative_num_draft_tokens': 6, 'speculative_dflash_block_size': None, 'speculative_dspark_block_size': None, 'speculative_dspark_sps_table_path': None, 'speculative_dspark_confidence_sts_path': None, 'speculative_dspark_align_verify_tokens_to_graph_tier': False, 'speculative_accept_threshold_single': 1.0, 'speculative_accept_threshold_acc': 1.0, 'speculative_use_rejection_sampling': False, 'speculative_token_map': None, 'speculative_attention_mode': 'prefill', 'speculative_draft_attention_backend': None, 'speculative_dsa_topk_backend': 'sgl-kernel', 'speculative_draft_kv_cache_dtype': None, 'speculative_draft_window_size': None, 'speculative_moe_runner_backend': 'flashinfer_mxfp4', 'speculative_moe_a2a_backend': None, 'speculative_draft_model_quantization': None, '_speculative_draft_quantization_explicitly_set': False, 'speculative_skip_dp_mlp_sync': False, 'enable_multi_layer_eagle': False, 'speculative_adaptive': False, 'speculative_adaptive_config': None, 'decoupled_spec_bind_endpoint': None, 'decoupled_spec_connect_endpoints': None, 'decoupled_spec_rank': None, 'decoupled_spec_role': 'null', 'spec_trace_dir': None, 'speculative_ngram_min_bfs_breadth': 1, 'speculative_ngram_max_bfs_breadth': 10, 'speculative_ngram_match_type': 'BFS', 'speculative_ngram_max_trie_depth': 18, 'speculative_ngram_capacity': 10000000, 'speculative_ngram_external_corpus_path': None, 'speculative_ngram_external_sam_budget': 0, 'speculative_ngram_external_corpus_max_tokens': 10000000, 'ep_size': 1, 'moe_a2a_backend': 'none', 'enable_w4a4_mxfp4_megamoe': False, 'deepep_v2_mode': 'direct', 'moe_runner_backend': 'flashinfer_mxfp4', 'flashinfer_mxfp4_moe_precision': 'default', 'deepep_mode': 'auto', 'fuseep_mode': 2, 'deepep_dispatcher_output_dtype': 'auto', 'ep_num_redundant_experts': 0, 'ep_dispatch_algorithm': None, 'init_expert_location': 'trivial', 'enable_eplb': False, 'eplb_algorithm': 'auto', 'eplb_rebalance_num_iterations': 1000, 'eplb_rebalance_layers_per_chunk': None, 'eplb_min_rebalancing_utilization_threshold': 1.0, 'expert_distribution_recorder_mode': None, 'expert_distribution_recorder_buffer_size': 1000, 'expert_balancedness_report_mode': 'off', 'deepep_config': None, 'moe_dense_tp_size': None, 'elastic_ep_backend': None, 'enable_elastic_expert_backup': False, 'mooncake_ib_device': None, 'enable_waterfill': False, 'ep_join_mode': None, 'ep_join_rank_offset': 0, 'elastic_ep_initial_size': None, 'max_ep_size': None, 'elastic_ep_scale_timeout': 600, 'elastic_ep_rejoin': False, 'disable_flashinfer_cutlass_moe_fp4_allgather': False, 'disable_shared_experts_fusion': False, 'enforce_shared_experts_fusion': False, 'max_mamba_cache_size': None, 'mamba_ssm_dtype': None, 'mamba_max_states_per_path': -1, 'enable_mamba_cache_stochastic_rounding': False, 'mamba_cache_philox_rounds': 0, 'mamba_full_memory_ratio': 0.9, 'mamba_radix_cache_strategy': 'auto', 'uses_mamba_radix_cache': False, 'mamba_track_interval': 256, 'enable_int8_mamba_checkpoint': False, 'int8_mamba_ckpt_size': None, 'linear_attn_backend': 'triton', 'linear_attn_decode_backend': None, 'linear_attn_prefill_backend': None, 'linear_attn_verify_backend': None, 'enable_linear_replayssm': False, 'linear_replayssm_cache_len': 16, 'enable_linear_replayssm_spec': False, 'enable_hierarchical_cache': False, 'hicache_host_memory_mode': 'cache', 'hicache_ratio': 2.0, 'hicache_size': 0, 'hicache_write_policy': 'write_through', 'hicache_io_backend': 'kernel', 'hicache_mem_layout': 'page_first', 'hicache_storage_backend': None, 'hicache_storage_prefetch_policy': 'timeout', 'hicache_storage_backend_extra_config': None, 'hicache_storage_prefetch_retry_poll_interval': 8, 'hicache_storage_prefetch_retry_max_attempts': 8, 'enable_unified_cache_external_linker': False, 'unified_cache_external_linker_backend': 'mooncake', 'enable_hisparse': False, 'hisparse_config': None, 'enable_broadcast_mm_inputs_process': False, 'enable_prefix_mm_cache': False, 'mm_enable_dp_encoder': False, 'mm_process_config': {}, 'mm_processor_worker_num': 0, 'mm_io_worker_num': 0, 'allowed_media_domains': [], 'media_url_max_file_size_mb': 64, 'mm_preprocess_cache_size_mb': None, 'trust_mm_content_hashes': False, 'limit_mm_data_per_request': None, 'enable_mm_global_cache': False, 'image_processor_backend': 'auto', 'mm_global_cache_backend': 'mooncake', 'disable_fast_image_processor': False, 'mm_feature_transport': 'cpu', 'keep_mm_feature_on_device': False, 'enable_lora': None, 'enable_lora_overlap_loading': None, 'max_lora_rank': None, 'lora_target_modules': None, 'lora_paths': None, 'max_loaded_loras': None, 'max_loras_per_batch': 8, 'lora_eviction_policy': 'lru', 'lora_backend': 'csgmv', 'max_lora_chunk_size': 16, 'experts_shared_outer_loras': None, 'lora_use_virtual_experts': False, 'lora_strict_loading': False, 'lora_drain_wait_threshold': 0.0, 'enable_two_batch_overlap': False, 'enable_single_batch_overlap': False, 'tbo_token_distribution_threshold': 0.48, 'cpu_offload_gb': 0, 'offload_group_size': -1, 'offload_num_in_group': 1, 'offload_prefetch_step': 1, 'offload_mode': 'cpu', 'enable_lmcache': False, 'lmcache_config_file': None, 'enable_flexkv': False, 'flexkv_config_file': None, 'kt_weight_path': None, 'kt_method': 'AMXINT4', 'kt_cpuinfer': None, 'kt_threadpool_count': 2, 'kt_num_gpu_experts': None, 'kt_max_deferred_experts_per_token': None, 'dllm_algorithm': None, 'dllm_algorithm_config': None, 'dllm_fdfo': True, 'disaggregation_mode': 'null', 'disaggregation_transfer_backend': 'mooncake', 'disaggregation_bootstrap_port': 8998, 'disaggregation_ib_device': None, 'disaggregation_decode_enable_radix_cache': False, 'disaggregation_decode_enable_offload_kvcache': False, 'disaggregation_decode_retraction_backup': None, 'num_reserved_decode_tokens': 512, 'disaggregation_decode_extra_slots': None, 'disaggregation_decode_polling_interval': 1, 'optimistic_prefill_attempts': 0, 'encoder_only': False, 'language_only': False, 'language_model_only': False, 'encoder_transfer_backend': 'zmq_to_scheduler', 'encoder_urls': [], 'encoder_bootstrap_port': 8997, 'encoder_register_urls': [], 'enable_adaptive_dispatch_to_encoder': False, 'enable_pdmux': False, 'pdmux_config_path': None, 'sm_group_num': 8, 'startup_weight_load_mode': 'serial', 'custom_weight_loader': [], 'weight_loader_disable_mmap': False, 'weight_loader_prefetch_checkpoints': False, 'weight_loader_prefetch_num_threads': 4, 'weight_loader_drop_cache_after_load': False, 'remote_instance_weight_loader_seed_instance_ip': None, 'remote_instance_weight_loader_seed_instance_service_port': None, 'remote_instance_weight_loader_send_weights_group_ports': None, 'remote_instance_weight_loader_backend': 'nccl', 'remote_instance_weight_loader_start_seed_via_transfer_engine': False, 'engine_info_bootstrap_port': 6789, 'modelexpress_config': None, 'download_dir': None, 'model_checksum': None, 'delete_ckpt_after_loading': False, 'decrypted_config_file': None, 'decrypted_draft_config_file': None, 'checkpoint_engine_wait_weights_before_ready': False, 'enable_prefill_delayer': False, 'prefill_delayer_max_delay_passes': 30, 'prefill_delayer_token_usage_low_watermark': None, 'prefill_delayer_forward_passes_buckets': None, 'prefill_delayer_wait_seconds_buckets': None, 'prefill_delayer_queue_min_ratio': None, 'prefill_delayer_max_delay_ms': None, 'min_free_slots_delay': None, 'enable_deterministic_inference': False, 'rl_on_policy_target': None, 'kv_canary': 'none', 'kv_canary_real_data': 'none', 'kv_canary_sweep_interval': 0, 'enable_dynamic_batch_tokenizer': False, 'dynamic_batch_tokenizer_batch_size': 32, 'dynamic_batch_tokenizer_batch_timeout': 0.002, 'enable_tokenizer_batch_encode': False, 'disable_tokenizer_batch_decode': False, 'debug_tensor_dump_output_folder': None, 'debug_tensor_dump_layers': None, 'debug_tensor_dump_input_file': None, 'enable_memory_saver': False, 'enable_weights_cpu_backup': False, 'enable_draft_weights_cpu_backup': False, 'enable_custom_logit_processor': False, 'enable_return_hidden_states': False, 'return_hidden_states_mode': None, 'enable_return_routed_experts': False, 'enable_return_indexer_topk': False, 'sampling_mask_max_tokens': 4096, 'disable_outlines_disk_cache': False, 'enable_mis': False, 'weight_cache_mode': 'off', 'weight_cache_socket': None, 'weight_cache_timeout': 1800, 'forward_hooks': None, 'msprobe_dump_config': None, 'ple_offload_embedding': None, 'ple_offload_backend': 'pinned', 'ple_offload_dir': None, 'speculative_domino_candidate_pool_size': 2048, 'flashinfer_a2a_dispatch_type': None, 'dsv4_attn_backend': 'auto', '_radix_eviction_policy_explicitly_set': False, 'enable_response_store': False}
[2026-09-26 23:05:19] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:25] Tokenizer for deepseek-ai/DeepSeek-V4-Flash-0731 is still TokenizersBackend after retries with --trust-remote-code. Model-specific tokenizer attributes may be missing.
[2026-09-26 23:05:25] No HuggingFace chat template found
[2026-09-26 23:05:25] No chat template found, defaulting to 'string' content format
[2026-09-26 23:05:39 TP1] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:39 TP2] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:39 TP3] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:39 TP0] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:42] Tokenizer for deepseek-ai/DeepSeek-V4-Flash-0731 is still TokenizersBackend after retries with --trust-remote-code. Model-specific tokenizer attributes may be missing.
[2026-09-26 23:05:44 TP1] Tokenizer for deepseek-ai/DeepSeek-V4-Flash-0731 is still TokenizersBackend after retries with --trust-remote-code. Model-specific tokenizer attributes may be missing.
[2026-09-26 23:05:44 TP2] Tokenizer for deepseek-ai/DeepSeek-V4-Flash-0731 is still TokenizersBackend after retries with --trust-remote-code. Model-specific tokenizer attributes may be missing.
[2026-09-26 23:05:44 TP3] Tokenizer for deepseek-ai/DeepSeek-V4-Flash-0731 is still TokenizersBackend after retries with --trust-remote-code. Model-specific tokenizer attributes may be missing.
[2026-09-26 23:05:44 TP0] Tokenizer for deepseek-ai/DeepSeek-V4-Flash-0731 is still TokenizersBackend after retries with --trust-remote-code. Model-specific tokenizer attributes may be missing.
[2026-09-26 23:05:44 TP1] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:45 TP2] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:45 TP3] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:45 TP0] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:45 TP1] Draft checkpoint bundles a DSpark head; loading draft arch DeepseekV4ForCausalLMDSpark.
[2026-09-26 23:05:45 TP1] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:05:45 TP2] Draft checkpoint bundles a DSpark head; loading draft arch DeepseekV4ForCausalLMDSpark.
[2026-09-26 23:05:45 TP0] Draft checkpoint bundles a DSpark head; loading draft arch DeepseekV4ForCausalLMDSpark.
[2026-09-26 23:05:45 TP3] Draft checkpoint bundles a DSpark head; loading draft arch DeepseekV4ForCausalLMDSpark.
[2026-09-26 23:05:45 TP1] Init torch distributed begin.
[2026-09-26 23:05:46 TP2] Init torch distributed begin.
[2026-09-26 23:05:46 TP0] Init torch distributed begin.
[2026-09-26 23:05:46 TP3] Init torch distributed begin.
[2026-09-26 23:05:46 TP0] sglang is using nccl==2.29.7
[2026-09-26 23:05:51 TP0] All Reduce config: symmetric_memory = 23.01 MB, local_buffer = 4.00 MB, multicast = False, pull = True
[2026-09-26 23:05:51 TP3] Init torch distributed ends. elapsed=5.42 s, mem usage=1.26 GB
[2026-09-26 23:05:51 TP2] Init torch distributed ends. elapsed=5.45 s, mem usage=1.36 GB
[2026-09-26 23:05:51 TP0] Init torch distributed ends. elapsed=5.42 s, mem usage=1.26 GB
[2026-09-26 23:05:51 TP1] Init torch distributed ends. elapsed=5.80 s, mem usage=1.36 GB
[2026-09-26 23:05:54 TP2] Load weight begin. avail mem=77.27 GB
[2026-09-26 23:05:54 TP3] Load weight begin. avail mem=77.37 GB
[2026-09-26 23:05:54 TP1] Load weight begin. avail mem=77.27 GB
[2026-09-26 23:05:54 TP0] Load weight begin. avail mem=77.37 GB
[2026-09-26 23:05:54 TP0] Detected fp8 checkpoint.
[2026-09-26 23:05:54 TP0] Config does not support fused shared expert(s). Shared experts fusion optimization is disabled.
[2026-09-26 23:05:55 TP0] Found local HF snapshot for deepseek-ai/DeepSeek-V4-Flash-0731 at /shared/home/shakhizat.nurgaliyev/.cache/huggingface/hub/models--deepseek-ai--DeepSeek-V4-Flash-0731/snapshots/7872f01b1d1fe23eabc4c98b48bffcef5a386062; skipping download.
Multi-thread loading shards: 90% Completed | 43/48 [00:19<00:02, 2.41it/s][2026-09-26 23:06:15 TP3] Finished streaming dequant fp8 wo_a
[2026-09-26 23:06:15 TP3] DeepSeek V4 MHC prenorm prewarm: 20 n_splits buckets
Multi-thread loading shards: 100% Completed | 48/48 [00:20<00:00, 2.32it/s]
[2026-09-26 23:06:16 TP0] Finished streaming dequant fp8 wo_a
[2026-09-26 23:06:16 TP0] DeepSeek V4 MHC prenorm prewarm: 20 n_splits buckets
[2026-09-26 23:06:16 TP2] Finished streaming dequant fp8 wo_a
[2026-09-26 23:06:16 TP2] DeepSeek V4 MHC prenorm prewarm: 20 n_splits buckets
[2026-09-26 23:06:17 TP1] Finished streaming dequant fp8 wo_a
[2026-09-26 23:06:17 TP1] DeepSeek V4 MHC prenorm prewarm: 20 n_splits buckets
[2026-09-26 23:06:20 TP1] DeepSeek V4 MHC prewarm at load: compile 3.5s, rank sync +0.0s
[2026-09-26 23:06:20 TP2] DeepSeek V4 MHC prewarm at load: compile 3.2s, rank sync +0.7s
[2026-09-26 23:06:20 TP3] DeepSeek V4 MHC prewarm at load: compile 3.1s, rank sync +1.9s
[2026-09-26 23:06:20 TP0] DeepSeek V4 MHC prewarm at load: compile 3.5s, rank sync +0.7s
[2026-09-26 23:06:20 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.0.mlp.experts)...
[2026-09-26 23:06:21 TP2] Using FP8 KV cache but no scaling factors provided. Defaulting to scaling factors of 1.0.
[2026-09-26 23:06:21 TP2] Load weight end. elapsed=27.23 s, type=DeepseekV4ForCausalLM, quant=fp8, fmt=e4m3, avail mem=38.68 GB, mem usage=38.59 GB.
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.1.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.2.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.3.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.4.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.5.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.6.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.7.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.8.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.9.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.10.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.11.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.12.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.13.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.14.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.15.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.16.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.17.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.18.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.19.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.20.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.21.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.22.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.23.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.24.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.25.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.26.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.27.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.28.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.29.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.30.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.31.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.32.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.33.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.34.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.35.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.36.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.37.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.38.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.39.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.40.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.41.mlp.experts)...
[2026-09-26 23:06:21 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: model.layers.42.mlp.experts)...
[2026-09-26 23:06:21 TP0] Using FP8 KV cache but no scaling factors provided. Defaulting to scaling factors of 1.0.
[2026-09-26 23:06:21 TP0] Load weight end. elapsed=27.13 s, type=DeepseekV4ForCausalLM, quant=fp8, fmt=e4m3, avail mem=38.78 GB, mem usage=38.59 GB.
[2026-09-26 23:06:22 TP3] Using FP8 KV cache but no scaling factors provided. Defaulting to scaling factors of 1.0.
[2026-09-26 23:06:22 TP3] Load weight end. elapsed=27.83 s, type=DeepseekV4ForCausalLM, quant=fp8, fmt=e4m3, avail mem=38.78 GB, mem usage=38.59 GB.
[2026-09-26 23:06:22 TP1] Using FP8 KV cache but no scaling factors provided. Defaulting to scaling factors of 1.0.
[2026-09-26 23:06:22 TP1] Load weight end. elapsed=27.84 s, type=DeepseekV4ForCausalLM, quant=fp8, fmt=e4m3, avail mem=38.68 GB, mem usage=38.59 GB.
[2026-09-26 23:06:27 TP3] Tokenizer for deepseek-ai/DeepSeek-V4-Flash-0731 is still TokenizersBackend after retries with --trust-remote-code. Model-specific tokenizer attributes may be missing.
[2026-09-26 23:06:28 TP2] Tokenizer for deepseek-ai/DeepSeek-V4-Flash-0731 is still TokenizersBackend after retries with --trust-remote-code. Model-specific tokenizer attributes may be missing.
[2026-09-26 23:06:28 TP1] Tokenizer for deepseek-ai/DeepSeek-V4-Flash-0731 is still TokenizersBackend after retries with --trust-remote-code. Model-specific tokenizer attributes may be missing.
[2026-09-26 23:06:28 TP0] Tokenizer for deepseek-ai/DeepSeek-V4-Flash-0731 is still TokenizersBackend after retries with --trust-remote-code. Model-specific tokenizer attributes may be missing.
[2026-09-26 23:06:28 TP2] Draft checkpoint bundles a DSpark head; loading draft arch DeepseekV4ForCausalLMDSpark.
[2026-09-26 23:06:28 TP3] Draft checkpoint bundles a DSpark head; loading draft arch DeepseekV4ForCausalLMDSpark.
[2026-09-26 23:06:28 TP0] Draft checkpoint bundles a DSpark head; loading draft arch DeepseekV4ForCausalLMDSpark.
[2026-09-26 23:06:28 TP1] Draft checkpoint bundles a DSpark head; loading draft arch DeepseekV4ForCausalLMDSpark.
[2026-09-26 23:06:30 TP2] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:06:30 TP3] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:06:30 TP2] Init torch distributed begin.
[2026-09-26 23:06:30 TP3] Init torch distributed begin.
[2026-09-26 23:06:30 TP2] Init torch distributed ends. elapsed=0.00 s, mem usage=0.00 GB
[2026-09-26 23:06:30 TP3] Init torch distributed ends. elapsed=0.00 s, mem usage=0.00 GB
[2026-09-26 23:06:30 TP2] Load weight begin. avail mem=38.68 GB
[2026-09-26 23:06:30 TP3] Load weight begin. avail mem=38.78 GB
[2026-09-26 23:06:30 TP1] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:06:30 TP0] Auto-detected DSV4 routed-expert layout: is_fp4_experts=True
[2026-09-26 23:06:30 TP1] Init torch distributed begin.
[2026-09-26 23:06:30 TP0] Init torch distributed begin.
[2026-09-26 23:06:30 TP1] Init torch distributed ends. elapsed=0.00 s, mem usage=0.00 GB
[2026-09-26 23:06:30 TP0] Init torch distributed ends. elapsed=0.00 s, mem usage=0.00 GB
[2026-09-26 23:06:30 TP1] Load weight begin. avail mem=38.68 GB
[2026-09-26 23:06:30 TP0] Load weight begin. avail mem=38.78 GB
[2026-09-26 23:06:30 TP0] Detected fp8 checkpoint.
[2026-09-26 23:06:30 TP0] Config does not support fused shared expert(s). Shared experts fusion optimization is disabled.
[2026-09-26 23:06:31 TP0] Found local HF snapshot for deepseek-ai/DeepSeek-V4-Flash-0731 at /shared/home/shakhizat.nurgaliyev/.cache/huggingface/hub/models--deepseek-ai--DeepSeek-V4-Flash-0731/snapshots/7872f01b1d1fe23eabc4c98b48bffcef5a386062; skipping download.
Multi-thread loading shards: 90% Completed | 43/48 [00:08<00:00, 5.65it/s][2026-09-26 23:06:39 TP3] Finished streaming dequant fp8 wo_a
Multi-thread loading shards: 92% Completed | 44/48 [00:08<00:00, 5.67it/s][2026-09-26 23:06:39 TP3] Using FP8 KV cache but no scaling factors provided. Defaulting to scaling factors of 1.0.
[2026-09-26 23:06:39 TP3] Load weight end. elapsed=9.50 s, type=DeepseekV4ForCausalLMDSpark, quant=fp8, fmt=e4m3, avail mem=36.08 GB, mem usage=2.69 GB.
[2026-09-26 23:06:39 TP2] Finished streaming dequant fp8 wo_a
[2026-09-26 23:06:40 TP2] Using FP8 KV cache but no scaling factors provided. Defaulting to scaling factors of 1.0.
[2026-09-26 23:06:40 TP2] Load weight end. elapsed=9.59 s, type=DeepseekV4ForCausalLMDSpark, quant=fp8, fmt=e4m3, avail mem=35.98 GB, mem usage=2.69 GB.
Multi-thread loading shards: 100% Completed | 48/48 [00:09<00:00, 4.87it/s]
[2026-09-26 23:06:41 TP0] Finished streaming dequant fp8 wo_a
[2026-09-26 23:06:41 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: stages.0.mlp.experts)...
[2026-09-26 23:06:41 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: stages.1.mlp.experts)...
[2026-09-26 23:06:41 TP0] Preparing DSv4 MXFP4 experts for FlashInfer SM90 CUTLASS W4A16 (layer: stages.2.mlp.experts)...
[2026-09-26 23:06:41 TP0] Using FP8 KV cache but no scaling factors provided. Defaulting to scaling factors of 1.0.
[2026-09-26 23:06:41 TP0] Load weight end. elapsed=11.14 s, type=DeepseekV4ForCausalLMDSpark, quant=fp8, fmt=e4m3, avail mem=36.08 GB, mem usage=2.69 GB.
[2026-09-26 23:06:41 TP1] Finished streaming dequant fp8 wo_a
[2026-09-26 23:06:41 TP1] Using FP8 KV cache but no scaling factors provided. Defaulting to scaling factors of 1.0.
[2026-09-26 23:06:41 TP1] Load weight end. elapsed=11.52 s, type=DeepseekV4ForCausalLMDSpark, quant=fp8, fmt=e4m3, avail mem=35.98 GB, mem usage=2.69 GB.
[2026-09-26 23:06:41 TP0] Initialized DSpark draft runner. attention_backend=dsv4, model=DeepseekV4ForCausalLMDSpark, gamma=5, verify_num_draft_tokens=6, query_token_num=5, sample_from_anchor=True, mask_token_id=128799, markov_head=DSparkV4MarkovHead
[2026-09-26 23:06:42 TP0] DSV4 memory calculation: unified=False, unified_fp8=False, bytes_per_full_token=9259.90, available_bytes=23.62 GB, c128_state_fixed=5.05 GB, swa_ring_fixed=0.00 GB, c4_state_fixed=0.00 GB, full_token=2152960
[2026-09-26 23:06:42 TP0] DSV4 pool sizes: full=2152960, swa=215296, c4=538240, c128=16820, c4_state=26912, c128_state=0
[2026-09-26 23:06:42 TP3] DSV4 memory calculation: unified=False, unified_fp8=False, bytes_per_full_token=9259.90, available_bytes=23.62 GB, c128_state_fixed=5.05 GB, swa_ring_fixed=0.00 GB, c4_state_fixed=0.00 GB, full_token=2152960
[2026-09-26 23:06:42 TP2] DSV4 memory calculation: unified=False, unified_fp8=False, bytes_per_full_token=9259.90, available_bytes=23.62 GB, c128_state_fixed=5.05 GB, swa_ring_fixed=0.00 GB, c4_state_fixed=0.00 GB, full_token=2152960
[2026-09-26 23:06:42 TP3] DSV4 pool sizes: full=2152960, swa=215296, c4=538240, c128=16820, c4_state=26912, c128_state=0
[2026-09-26 23:06:42 TP1] DSV4 memory calculation: unified=False, unified_fp8=False, bytes_per_full_token=9259.90, available_bytes=23.62 GB, c128_state_fixed=5.05 GB, swa_ring_fixed=0.00 GB, c4_state_fixed=0.00 GB, full_token=2152960
[2026-09-26 23:06:42 TP2] DSV4 pool sizes: full=2152960, swa=215296, c4=538240, c128=16820, c4_state=26912, c128_state=0
[2026-09-26 23:06:42 TP1] DSV4 pool sizes: full=2152960, swa=215296, c4=538240, c128=16820, c4_state=26912, c128_state=0
[2026-09-26 23:06:42 TP0] Initialize DeepSeekV4TokenToKVPool with max_num_reqs=256 swa_size=215296 c4_size=538240 c4_logical_size=538240 c128_size=16820 c4_state_pool_size=26912 c128_state_pool_size=65792
[2026-09-26 23:06:42 TP2] Initialize DeepSeekV4TokenToKVPool with max_num_reqs=256 swa_size=215296 c4_size=538240 c4_logical_size=538240 c128_size=16820 c4_state_pool_size=26912 c128_state_pool_size=65792
[2026-09-26 23:06:42 TP3] Initialize DeepSeekV4TokenToKVPool with max_num_reqs=256 swa_size=215296 c4_size=538240 c4_logical_size=538240 c128_size=16820 c4_state_pool_size=26912 c128_state_pool_size=65792
[2026-09-26 23:06:42 TP1] Initialize DeepSeekV4TokenToKVPool with max_num_reqs=256 swa_size=215296 c4_size=538240 c4_logical_size=538240 c128_size=16820 c4_state_pool_size=26912 c128_state_pool_size=65792
[2026-09-26 23:06:42 TP3] Memory pool end. avail mem=11.54 GB
[2026-09-26 23:06:42 TP3] Initialize DeepSeekV4TokenToKVPool with max_num_reqs=256 swa_size=215296 c4_size=0 c4_logical_size=0 c128_size=0 c4_state_pool_size=0 c128_state_pool_size=0
[2026-09-26 23:06:42 TP3] Memory pool end. avail mem=11.19 GB
[2026-09-26 23:06:42 TP2] Memory pool end. avail mem=11.44 GB
[2026-09-26 23:06:42 TP2] Initialize DeepSeekV4TokenToKVPool with max_num_reqs=256 swa_size=215296 c4_size=0 c4_logical_size=0 c128_size=0 c4_state_pool_size=0 c128_state_pool_size=0
[2026-09-26 23:06:42 TP1] Memory pool end. avail mem=11.44 GB
[2026-09-26 23:06:42 TP1] Initialize DeepSeekV4TokenToKVPool with max_num_reqs=256 swa_size=215296 c4_size=0 c4_logical_size=0 c128_size=0 c4_state_pool_size=0 c128_state_pool_size=0
[2026-09-26 23:06:42 TP2] Memory pool end. avail mem=11.08 GB
[2026-09-26 23:06:42 TP0] Memory pool end. avail mem=11.54 GB
[2026-09-26 23:06:42 TP0] Initialize DeepSeekV4TokenToKVPool with max_num_reqs=256 swa_size=215296 c4_size=0 c4_logical_size=0 c128_size=0 c4_state_pool_size=0 c128_state_pool_size=0
[2026-09-26 23:06:42 TP1] Memory pool end. avail mem=11.08 GB
[2026-09-26 23:06:42 TP0] Memory pool end. avail mem=11.19 GB
[2026-09-26 23:06:42 TP3] Using DeepseekV4AttnBackend for dsv4 attention backend (CUDA).
[2026-09-26 23:06:42 TP3] Overriding draft attention backend to dsv4.
[2026-09-26 23:06:42 TP2] Using DeepseekV4AttnBackend for dsv4 attention backend (CUDA).
[2026-09-26 23:06:42 TP2] Overriding draft attention backend to dsv4.
[2026-09-26 23:06:42 TP3] FlashInfer workspace preflight probe failed (cuMulticastGetGranularity failed for FlashInfer workspace preflight: <CUresult.CUDA_ERROR_NOT_SUPPORTED: 801>). Skipping allreduce fusion.
[2026-09-26 23:06:42 TP2] FlashInfer workspace preflight probe failed (cuMulticastGetGranularity failed for FlashInfer workspace preflight: <CUresult.CUDA_ERROR_NOT_SUPPORTED: 801>). Skipping allreduce fusion.
[2026-09-26 23:06:42 TP1] Using DeepseekV4AttnBackend for dsv4 attention backend (CUDA).
[2026-09-26 23:06:42 TP1] Overriding draft attention backend to dsv4.
[2026-09-26 23:06:42 TP0] Using DeepseekV4AttnBackend for dsv4 attention backend (CUDA).
[2026-09-26 23:06:42 TP0] Overriding draft attention backend to dsv4.
[2026-09-26 23:06:42 TP1] FlashInfer workspace preflight probe failed (cuMulticastGetGranularity failed for FlashInfer workspace preflight: <CUresult.CUDA_ERROR_NOT_SUPPORTED: 801>). Skipping allreduce fusion.
[2026-09-26 23:06:42 TP0] FlashInfer workspace preflight probe failed (cuMulticastGetGranularity failed for FlashInfer workspace preflight: <CUresult.CUDA_ERROR_NOT_SUPPORTED: 801>). Skipping allreduce fusion.
[2026-09-26 23:06:42 TP0] FlashInfer workspace preflight: cuMemCreate probe failed on at least one rank. Skipping allreduce fusion to avoid cross-rank desync inside the flashinfer collective.
[2026-09-26 23:06:42 TP3] FlashInfer workspace preflight: cuMemCreate probe failed on at least one rank. Skipping allreduce fusion to avoid cross-rank desync inside the flashinfer collective.
[2026-09-26 23:06:42 TP2] FlashInfer workspace preflight: cuMemCreate probe failed on at least one rank. Skipping allreduce fusion to avoid cross-rank desync inside the flashinfer collective.
[2026-09-26 23:06:42 TP1] FlashInfer workspace preflight: cuMemCreate probe failed on at least one rank. Skipping allreduce fusion to avoid cross-rank desync inside the flashinfer collective.
[2026-09-26 23:06:42 TP0] FlashInfer autotune: per-rank caches disagree, discarding them and tuning from scratch so all ranks agree on the tactics.
[2026-09-26 23:06:42 TP3] Running FlashInfer autotune with cache: /shared/home/shakhizat.nurgaliyev/.cache/sglang/flashinfer/autotune/0.6.18/sm90/e46ffdb3e1de4f67/rank_tp3_pp0_dp0.json
[2026-09-26 23:06:42 TP2] Running FlashInfer autotune with cache: /shared/home/shakhizat.nurgaliyev/.cache/sglang/flashinfer/autotune/0.6.18/sm90/e46ffdb3e1de4f67/rank_tp2_pp0_dp0.json
[2026-09-26 23:06:42 TP1] Running FlashInfer autotune with cache: /shared/home/shakhizat.nurgaliyev/.cache/sglang/flashinfer/autotune/0.6.18/sm90/e46ffdb3e1de4f67/rank_tp1_pp0_dp0.json
[2026-09-26 23:06:42 TP0] Running FlashInfer autotune with cache: /shared/home/shakhizat.nurgaliyev/.cache/sglang/flashinfer/autotune/0.6.18/sm90/e46ffdb3e1de4f67/rank_tp0_pp0_dp0.json
[2026-09-26 23:06:44 TP0] Entering DeepGEMM JIT Pre-Compile session. It may take a long time (typically 10-20 mins) if you have not run `sglang.compile_deep_gemm`. It is recommended to run `sglang.compile_deep_gemm` with same args as `sglang.launch_server` for pre-compilation to reduce the overhead if you have not run it before. For example: `python3 -m sglang.compile_deep_gemm --model deepseek-ai/DeepSeek-V3 --tp 8 --trust-remote-code`
[2026-09-26 23:06:44 TP0] Try DeepGEMM JIT Compiling for <GEMM_NT_F8F8BF16> N=1536, K=4096, num_groups=1 with all Ms. It only takes a little time (typically 1 sec) if you have run `python3 -m sglang.compile_deep_gemm`.
[2026-09-26 23:06:44 TP0] Required memory for warmup: 0.115234375GB, Available memory: 9.97247314453125GB
DeepGEMM warmup: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 16384/16384 [00:01<00:00, 12396.54it/s]
[2026-09-26 23:06:45 TP0] Entering DeepGEMM JIT Pre-Compile session. It may take a long time (typically 10-20 mins) if you have not run `sglang.compile_deep_gemm`. It is recommended to run `sglang.compile_deep_gemm` with same args as `sglang.launch_server` for pre-compilation to reduce the overhead if you have not run it before. For example: `python3 -m sglang.compile_deep_gemm --model deepseek-ai/DeepSeek-V3 --tp 8 --trust-remote-code`
[2026-09-26 23:06:45 TP0] Try DeepGEMM JIT Compiling for <GEMM_NT_F8F8BF16> N=8192, K=1024, num_groups=1 with all Ms. It only takes a little time (typically 1 sec) if you have run `python3 -m sglang.compile_deep_gemm`.
[2026-09-26 23:06:45 TP0] Required memory for warmup: 0.2734375GB, Available memory: 9.94708251953125GB
DeepGEMM warmup: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 16384/16384 [00:01<00:00, 8840.88it/s]
[2026-09-26 23:06:47 TP0] Entering DeepGEMM JIT Pre-Compile session. It may take a long time (typically 10-20 mins) if you have not run `sglang.compile_deep_gemm`. It is recommended to run `sglang.compile_deep_gemm` with same args as `sglang.launch_server` for pre-compilation to reduce the overhead if you have not run it before. For example: `python3 -m sglang.compile_deep_gemm --model deepseek-ai/DeepSeek-V3 --tp 8 --trust-remote-code`
[2026-09-26 23:06:47 TP0] Try DeepGEMM JIT Compiling for <GEMM_NT_F8F8BF16> N=4096, K=2048, num_groups=1 with all Ms. It only takes a little time (typically 1 sec) if you have run `python3 -m sglang.compile_deep_gemm`.
[2026-09-26 23:06:47 TP0] Required memory for warmup: 0.1640625GB, Available memory: 9.94708251953125GB
DeepGEMM warmup: 100%|████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 16384/16384 [00:01<00:00, 9979.95it/s]
[2026-09-26 23:06:49 TP0] Entering DeepGEMM JIT Pre-Compile session. It may take a long time (typically 10-20 mins) if you have not run `sglang.compile_deep_gemm`. It is recommended to run `sglang.compile_deep_gemm` with same args as `sglang.launch_server` for pre-compilation to reduce the overhead if you have not run it before. For example: `python3 -m sglang.compile_deep_gemm --model deepseek-ai/DeepSeek-V3 --tp 8 --trust-remote-code`
[2026-09-26 23:06:49 TP0] Try DeepGEMM JIT Compiling for <GEMM_NT_F8F8BF16> N=1024, K=4096, num_groups=1 with all Ms. It only takes a little time (typically 1 sec) if you have run `python3 -m sglang.compile_deep_gemm`.
[2026-09-26 23:06:49 TP0] Required memory for warmup: 0.09765625GB, Available memory: 9.95880126953125GB
[AutoTuner]: Tuning trtllm::fused_moe::gemm1: 0%| | 0/16 [00:00<?, ?profile/s][TensorRT-LLM][INFO] Set logger level to INFO
DeepGEMM warmup: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 16384/16384 [00:01<00:00, 15986.07it/s]
[2026-09-26 23:06:50 TP0] Entering DeepGEMM JIT Pre-Compile session. It may take a long time (typically 10-20 mins) if you have not run `sglang.compile_deep_gemm`. It is recommended to run `sglang.compile_deep_gemm` with same args as `sglang.launch_server` for pre-compilation to reduce the overhead if you have not run it before. For example: `python3 -m sglang.compile_deep_gemm --model deepseek-ai/DeepSeek-V3 --tp 8 --trust-remote-code`
[2026-09-26 23:06:50 TP0] Try DeepGEMM JIT Compiling for <GEMM_NT_F8F8BF16> N=4096, K=512, num_groups=1 with all Ms. It only takes a little time (typically 1 sec) if you have run `python3 -m sglang.compile_deep_gemm`.
[2026-09-26 23:06:50 TP0] Required memory for warmup: 0.134765625GB, Available memory: 9.95684814453125GB
DeepGEMM warmup: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 16384/16384 [00:00<00:00, 21921.12it/s]
[AutoTuner]: Tuning trtllm::fused_moe::gemm1: 100%|██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 16/16 [01:35<00:00, 5.97s/profile]
[AutoTuner]: Tuning trtllm::fused_moe::gemm1: 100%|██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 16/16 [01:33<00:00, 5.85s/profile]
[AutoTuner]: Tuning trtllm::fused_moe::gemm2: 100%|██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 16/16 [00:43<00:00, 2.75s/profile]
[2026-09-26 23:09:10 TP2] FlashInfer autotune completed.
[2026-09-26 23:09:10 TP2] Disable prefill CUDA graph because cuda_graph_config resolved prefill.backend='disabled' (e.g. via --cuda-graph-backend-prefill=disabled or auto-disable rules).
[2026-09-26 23:09:10 TP3] FlashInfer autotune completed.
[2026-09-26 23:09:10 TP3] Disable prefill CUDA graph because cuda_graph_config resolved prefill.backend='disabled' (e.g. via --cuda-graph-backend-prefill=disabled or auto-disable rules).
[2026-09-26 23:09:10 TP2] Capture target verify CUDA graph begin. backend=full, num_tokens_per_req=6, bs=[1, 2, 3, 4, 5, 6, 7, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 40, 44, 48, 52, 56, 60, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256], avail mem=9.03 GB
[2026-09-26 23:09:10 TP3] Capture target verify CUDA graph begin. backend=full, num_tokens_per_req=6, bs=[1, 2, 3, 4, 5, 6, 7, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 40, 44, 48, 52, 56, 60, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256], avail mem=9.13 GB
[2026-09-26 23:09:10 TP0] FlashInfer autotune completed.
[2026-09-26 23:09:10 TP0] Disable prefill CUDA graph because cuda_graph_config resolved prefill.backend='disabled' (e.g. via --cuda-graph-backend-prefill=disabled or auto-disable rules).
[2026-09-26 23:09:10 TP1] FlashInfer autotune completed.
[2026-09-26 23:09:10 TP1] Disable prefill CUDA graph because cuda_graph_config resolved prefill.backend='disabled' (e.g. via --cuda-graph-backend-prefill=disabled or auto-disable rules).
[2026-09-26 23:09:10 TP0] Capture target verify CUDA graph begin. backend=full, num_tokens_per_req=6, bs=[1, 2, 3, 4, 5, 6, 7, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 40, 44, 48, 52, 56, 60, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256], avail mem=9.12 GB
[2026-09-26 23:09:10 TP1] Capture target verify CUDA graph begin. backend=full, num_tokens_per_req=6, bs=[1, 2, 3, 4, 5, 6, 7, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 40, 44, 48, 52, 56, 60, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256], avail mem=9.03 GB
Capturing batches (bs=256 avail_mem=8.36 GB): 0%| | 0/51 [00:00<?, ?it/s][2026-09-26 23:09:11 TP2] multimem all-gather disabled (no multicast for world_size=4)
[2026-09-26 23:09:11 TP3] multimem all-gather disabled (no multicast for world_size=4)
[2026-09-26 23:09:11 TP0] multimem all-gather disabled (no multicast for world_size=4)
[2026-09-26 23:09:11 TP1] multimem all-gather disabled (no multicast for world_size=4)
Capturing batches (bs=1 avail_mem=5.48 GB): 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 51/51 [00:21<00:00, 2.35it/s]
[2026-09-26 23:09:33 TP3] Capture target verify CUDA graph end. elapsed=22.87 s, mem usage=3.65 GB, avail mem=5.49 GB.
[2026-09-26 23:09:33 TP2] Capture target verify CUDA graph end. elapsed=22.89 s, mem usage=3.65 GB, avail mem=5.39 GB.
[2026-09-26 23:09:33 TP1] Capture target verify CUDA graph end. elapsed=22.87 s, mem usage=3.65 GB, avail mem=5.39 GB.
[2026-09-26 23:09:33 TP0] Capture target verify CUDA graph end. elapsed=22.94 s, mem usage=3.65 GB, avail mem=5.47 GB.
[2026-09-26 23:09:33 TP0] DSpark draft proposal (greedy + sampling) folded into the draft cuda graph.
[2026-09-26 23:09:33 TP0] Disable prefill CUDA graph because cuda_graph_config resolved prefill.backend='disabled' (e.g. via --cuda-graph-backend-prefill=disabled or auto-disable rules).
[2026-09-26 23:09:33 TP3] Disable prefill CUDA graph because cuda_graph_config resolved prefill.backend='disabled' (e.g. via --cuda-graph-backend-prefill=disabled or auto-disable rules).
[2026-09-26 23:09:33 TP2] Disable prefill CUDA graph because cuda_graph_config resolved prefill.backend='disabled' (e.g. via --cuda-graph-backend-prefill=disabled or auto-disable rules).
[2026-09-26 23:09:33 TP1] Disable prefill CUDA graph because cuda_graph_config resolved prefill.backend='disabled' (e.g. via --cuda-graph-backend-prefill=disabled or auto-disable rules).
[2026-09-26 23:09:33 TP0] Capture draft verify CUDA graph begin. backend=full, num_tokens_per_req=5, bs=[1, 2, 3, 4, 5, 6, 7, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 40, 44, 48, 52, 56, 60, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256], avail mem=4.60 GB
[2026-09-26 23:09:33 TP3] Capture draft verify CUDA graph begin. backend=full, num_tokens_per_req=5, bs=[1, 2, 3, 4, 5, 6, 7, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 40, 44, 48, 52, 56, 60, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256], avail mem=4.62 GB
[2026-09-26 23:09:33 TP2] Capture draft verify CUDA graph begin. backend=full, num_tokens_per_req=5, bs=[1, 2, 3, 4, 5, 6, 7, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 40, 44, 48, 52, 56, 60, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256], avail mem=4.52 GB
[2026-09-26 23:09:33 TP1] Capture draft verify CUDA graph begin. backend=full, num_tokens_per_req=5, bs=[1, 2, 3, 4, 5, 6, 7, 8, 10, 12, 14, 16, 18, 20, 22, 24, 26, 28, 30, 32, 40, 44, 48, 52, 56, 60, 64, 72, 80, 88, 96, 104, 112, 120, 128, 136, 144, 152, 160, 168, 176, 184, 192, 200, 208, 216, 224, 232, 240, 248, 256], avail mem=4.52 GB
Capturing batches (bs=256 avail_mem=4.59 GB): 0%| | 0/51 [00:00<?, ?it/s][2026-09-26 23:09:35 TP2] Running FlashInfer autotune with cache: /shared/home/shakhizat.nurgaliyev/.cache/sglang/flashinfer/autotune/0.6.18/sm90/59ab4d664b92e4c1/rank_tp2_pp0_dp0.json
[2026-09-26 23:09:35 TP1] Running FlashInfer autotune with cache: /shared/home/shakhizat.nurgaliyev/.cache/sglang/flashinfer/autotune/0.6.18/sm90/59ab4d664b92e4c1/rank_tp1_pp0_dp0.json
[2026-09-26 23:09:35 TP3] Running FlashInfer autotune with cache: /shared/home/shakhizat.nurgaliyev/.cache/sglang/flashinfer/autotune/0.6.18/sm90/59ab4d664b92e4c1/rank_tp3_pp0_dp0.json
[2026-09-26 23:09:35 TP0] Running FlashInfer autotune with cache: /shared/home/shakhizat.nurgaliyev/.cache/sglang/flashinfer/autotune/0.6.18/sm90/59ab4d664b92e4c1/rank_tp0_pp0_dp0.json
[2026-09-26 23:09:35 TP0] Entering DeepGEMM JIT Pre-Compile session. It may take a long time (typically 10-20 mins) if you have not run `sglang.compile_deep_gemm`. It is recommended to run `sglang.compile_deep_gemm` with same args as `sglang.launch_server` for pre-compilation to reduce the overhead if you have not run it before. For example: `python3 -m sglang.compile_deep_gemm --model deepseek-ai/DeepSeek-V3 --tp 8 --trust-remote-code`
[2026-09-26 23:09:35 TP0] Try DeepGEMM JIT Compiling for <GEMM_NT_F8F8BF16> N=512, K=4096, num_groups=1 with all Ms. It only takes a little time (typically 1 sec) if you have run `python3 -m sglang.compile_deep_gemm`.
[2026-09-26 23:09:35 TP0] Required memory for warmup: 0.080078125GB, Available memory: 4.43341064453125GB
DeepGEMM warmup: 100%|███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 16384/16384 [00:00<00:00, 23194.44it/s]
[2026-09-26 23:09:37 TP2] FlashInfer autotune completed.███████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████▉ | 14621/16384 [00:00<00:00, 21607.07it/s]
[2026-09-26 23:09:37 TP3] FlashInfer autotune completed.
[2026-09-26 23:09:37 TP0] FlashInfer autotune completed.
[2026-09-26 23:09:37 TP1] FlashInfer autotune completed.
[rank2]:[W926 23:09:37.365619858 CUDACachingAllocator.cpp:3933] memory allocation failed with OOM on device 2 while trying to allocate 662700032 bytes (free: 469565440, total: 85009367040).
[rank1]:[W926 23:09:37.368970611 CUDACachingAllocator.cpp:3933] memory allocation failed with OOM on device 1 while trying to allocate 662700032 bytes (free: 469565440, total: 85009367040).
Capturing batches (bs=1 avail_mem=3.21 GB): 100%|█████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 51/51 [00:13<00:00, 3.69it/s]
[2026-09-26 23:09:48 TP2] Capture draft verify CUDA graph end. elapsed=14.66 s, mem usage=1.50 GB, avail mem=3.02 GB.
[2026-09-26 23:09:48 TP3] Capture draft verify CUDA graph end. elapsed=14.66 s, mem usage=1.40 GB, avail mem=3.23 GB.
[2026-09-26 23:09:48 TP3] Init Unified Radix Cache. Components: (<ComponentType.FULL: 0>, <ComponentType.SWA: 1>). Tree Core: UnifiedTreeCore
[2026-09-26 23:09:48 TP2] Init Unified Radix Cache. Components: (<ComponentType.FULL: 0>, <ComponentType.SWA: 1>). Tree Core: UnifiedTreeCore
[2026-09-26 23:09:48 TP3] Tree cache initialized: source=default impl=UnifiedRadixCache hybrid_swa=True hybrid_ssm=False hicache_attached=False streaming_wrapped=False
[2026-09-26 23:09:48 TP2] Tree cache initialized: source=default impl=UnifiedRadixCache hybrid_swa=True hybrid_ssm=False hicache_attached=False streaming_wrapped=False
[2026-09-26 23:09:48 TP0] Capture draft verify CUDA graph end. elapsed=14.74 s, mem usage=1.40 GB, avail mem=3.21 GB.
[2026-09-26 23:09:48 TP0] max_total_num_tokens=2152960, chunked_prefill_size=4096, max_prefill_tokens=16384, max_running_requests=256, context_len=1048576, available_gpu_mem=3.21 GB
[2026-09-26 23:09:48 TP0] Init Unified Radix Cache. Components: (<ComponentType.FULL: 0>, <ComponentType.SWA: 1>). Tree Core: UnifiedTreeCore
[2026-09-26 23:09:48 TP0] Tree cache initialized: source=default impl=UnifiedRadixCache hybrid_swa=True hybrid_ssm=False hicache_attached=False streaming_wrapped=False
[2026-09-26 23:09:48 TP1] Capture draft verify CUDA graph end. elapsed=14.81 s, mem usage=1.50 GB, avail mem=3.02 GB.
[2026-09-26 23:09:48 TP1] Init Unified Radix Cache. Components: (<ComponentType.FULL: 0>, <ComponentType.SWA: 1>). Tree Core: UnifiedTreeCore
[2026-09-26 23:09:48 TP1] Tree cache initialized: source=default impl=UnifiedRadixCache hybrid_swa=True hybrid_ssm=False hicache_attached=False streaming_wrapped=False
[2026-09-26 23:09:48] Engine startup timings (s): load_weight=39.36, kv_cache_allocation=0.61, scheduler_e2e=251.11, cuda_graph={prefill=0.00, decode=0.00, target_verify=22.94, draft_prefill=0.00, draft_decode=14.81, draft_extend=0.00}, tokenizer_e2e=269.32
[2026-09-26 23:09:48] INFO: Started server process [3900453]
[2026-09-26 23:09:48] INFO: Waiting for application startup.
[2026-09-26 23:09:48] Using default chat sampling params from model generation config: {'temperature': 1.0, 'top_p': 1.0}
encoding_dsv4.py: 100%|██████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████████| 29.0k/29.0k [00:00<00:00, 86.8MB/s]
[2026-09-26 23:09:50] INFO: Application startup complete.
[2026-09-26 23:09:50] INFO: Uvicorn running on http://127.0.0.1:30000 (Press CTRL+C to quit)
[2026-09-26 23:09:51] INFO: 127.0.0.1:36892 - "GET /model_info HTTP/1.1" 200 OK
/shared/home/shakhizat.nurgaliyev/.sglang/lib/python3.12/site-packages/torch/distribut
The four H100 GPUs were essentially full after initialization.
nvidia-smi
| NVIDIA-SMI 610.57.04 KMD Version: 610.57.04 CUDA UMD Version: 13.3 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA H100 80GB HBM3 Off | 00000000:04:00.0 Off | 0 |
| N/A 31C P0 117W / 699W | 80866MiB / 81559MiB | 0% Default |
| | | Disabled |
| 1 NVIDIA H100 80GB HBM3 Off | 00000000:64:00.0 Off | 0 |
| N/A 31C P0 117W / 699W | 80932MiB / 81559MiB | 0% Default |
| | | Disabled |
| 2 NVIDIA H100 80GB HBM3 Off | 00000000:84:00.0 Off | 0 |
| N/A 32C P0 121W / 699W | 80932MiB / 81559MiB | 0% Default |
| | | Disabled |
| 3 NVIDIA H100 80GB HBM3 Off | 00000000:E4:00.0 Off | 0 |
| N/A 31C P0 120W / 699W | 80872MiB / 81559MiB | 0% Default |
| | | Disabled |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 3920395 C sglang::scheduler_TP0 80854MiB |
| 1 N/A N/A 3920396 C sglang::scheduler_TP1 80920MiB |
| 2 N/A N/A 3920398 C sglang::scheduler_TP2 80920MiB |
| 3 N/A N/A 3920400 C sglang::scheduler_TP3 80860MiB |
Once the Kimi CLI is configured and the sglangendpoint is working, you can start the Kimi web interface with:
Overall, this was a successful DeepSeek-V4-Flash-0731 deployment on a single 4XH100 node using SGLang**.
