Running DeepSeek-V4-Flash-0731 on dual NVIDIA RTX PRO 6000 Blackwell GPUs
Recently I tested DeepSeek-V4-Flash-0731 on a workstation equipped with two NVIDIA RTX PRO 6000 Blackwell GPUs (96 GB each) using SGLang. The model runs smoothly with tensor parallelism across both GPUs and delivers excellent coding performance.
Launch the inference server using the official SGLang Docker image:
docker run --gpus all \
  --shm-size 32g \
  -p 30000:30000 \
  -v ~/.cache/huggingface:/root/.cache/huggingface \
  --env "HF_TOKEN=<your-hf-token>" \
  --ipc=host \
  lmsysorg/sglang:dev \
  sglang serve \
    --trust-remote-code \
    --model-path deepseek-ai/DeepSeek-V4-Flash-0731 \
    --tp 2 \
    --moe-runner-backend flashinfer_mxfp4 \
    --reasoning-parser deepseek-v4 \
    --tool-call-parser deepseekv4 \
    --mem-fraction-static 0.92 \
    --cuda-graph-max-bs-decode 32 \
    --host 0.0.0.0 \
    --port 30000
Testing with Kimi Code
To evaluate coding capabilities, I connected the server to Kimi Code.
Install Kimi Code with:
curl -fsSL https://code.kimi.com/kimi-code/install.sh | bash
As a quick functional test, I asked DeepSeek-V4-Flash to generate an HTML racing game.
Output:
What are your tok/s? I’m using this repo rtx6kpro/models/ds4-flash-v4.md at master · local-inference-lab/rtx6kpro · GitHub but still working out the kinks. But it outputs 280 tok/s.
