Running DeepStream 3d depth camera using D455 realsense camera
I am using DeepStream SDK 6.2, D455 Realsense Camera, Jetson Orin Nano with 5.1.3 Jetpack.
I successfully connected one camera and got output after running the DeepStream_3d_depth_camera sample application (c++).
Then I modified the code for two cameras created 2 data loader, 2 data render, and 2 DepthCameraApp instances in application code (in main).
Then I modified the ds_3d_realsense_depth_capture.yaml file and included configurations for 2 data loader and data render, in this case I am getting the error “multiple data render found keep only one”.
However, when I keep 1 data render in yaml file then only one camera output is visible.
My YAML Code :
type or paste code here
# Configuration for Camera 1
- name: realsense_dataloader_cam1
  type: ds3d::dataloader
  out_caps: ds3d/datamap
  custom_lib_path: libnvds_3d_dataloader_realsense.so
  custom_create_function: createRealsenseDataloader
  config_body:
    streams: ["color", "depth"]
    framerate: 0
- name: depth-render_cam1
  type: ds3d::datarender
  in_caps: ds3d/datamap
  custom_lib_path: libnvds_3d_gl_datarender.so
  custom_create_function: createDepthStreamDataRender
  gst_properties:
    sync: false
    async: false
    drop: false
  config_body:
    streams: ["depth", "color"]
    width: 1920
    height: 544
    title: "ds3d-camera-app-cam1"
    block: true
    min_depth: 0.3 # in meters
    max_depth: 2.0 # in meters
    min_depth_color: [255, 128, 0] # RGB color value for minimum depth
    max_depth_color: [0, 128, 255] # RGB color value for maximum depth
# Configuration for Camera 2
- name: realsense_dataloader_cam2
  config_body:
    framerate: 0
- name: depth-render_cam2
  gst_properties:
    sync: false
    async: false
    drop: false
  config_body:
    width: 1920
    height: 544
    title: "ds3d-camera-app-cam2"
    block: true
# User application
- name: debugdump
  type: ds3d::userapp
My Main Code:
int main(int argc, char* argv[])
    std::vector<gst::DataLoaderSrc> loaderSrcs(2);
    std::vector<gst::DataRenderSink> renderSinks(2);
    std::vector<std::shared_ptr<DepthCameraApp>> appCtxs(2);
    std::vector<ConfigList> componentConfigs(2);
    std::string configPath;
    std::string configContent;
    /* Standard GStreamer initialization */
    gst_init(&argc, &argv);
    /* setup signal handler */
    _intr_setup();
    /* Parse program arguments */
    opterr = 0;
    int c = -1;
    while ((c = getopt(argc, argv, "hc:")) != -1) {
        switch (c) {
        case 'c':  // get config file path
            configPath = optarg;
            break;
        case 'h':
            help(argv[0]);
            return 0;
        case '?':
        default:
            help(argv[0]);
            return -1;
    if (configPath.empty()) {
        LOG_ERROR("config file is not set!");
        help(argv[0]);
        return -1;
    CHECK_ERROR(readFile(configPath, configContent), "read file: %s failed", configPath.c_str());
    // Parse configuration for both cameras
    for (int i = 0; i < 2; ++i) {
        // parse all components in config file
        ErrCode code = CatchConfigCall(config::parseFullConfig, configContent, configPath, componentConfigs[i]);
        CHECK_ERROR(isGood(code), "parse config failed for camera %d", i);
        // Order all parsed component configs into config table
        std::map<config::ComponentType, ConfigList> configTable;
        for (const auto& c : componentConfigs[i]) {
            configTable[c.type].emplace_back(c);
        appCtxs[i] = std::make_shared<DepthCameraApp>();
        // update userapp configuration
        if (configTable.count(config::ComponentType::kUserApp)) {
            CHECK_ERROR(
                isGood(appCtxs[i]->initUserAppProfiling(configTable[config::ComponentType::kUserApp][0])),
                "parse userapp data failed");
        // Initialize app context with main loop and pipelines
        appCtxs[i]->setMainloop(g_main_loop_new(NULL, FALSE));
        CHECK_ERROR(appCtxs[i]->mainLoop(), "set main loop failed");
        CHECK_ERROR(isGood(appCtxs[i]->init("deepstream-depth-camera-pipeline")), "init pipeline failed");
        bool startLoaderDirectly = true;
        bool startRenderDirectly = true;
        // Ensure separate configurations for each camera instance
        CHECK_ERROR(
            isGood(CreateLoaderSourceForMultiple(configTable[config::ComponentType::kDataLoader], loaderSrcs[i], startLoaderDirectly)),
            "create dataloader source failed for camera %d", i);
        CHECK_ERROR(
            isGood(CreateRenderSinkForMultiple(configTable[config::ComponentType::kDataRender], renderSinks[i], startRenderDirectly)),
            "create datarender sink failed for camera %d", i);
        appCtxs[i]->setDataloaderSrc(loaderSrcs[i]);
        appCtxs[i]->setDataRenderSink(renderSinks[i]);
        DS_ASSERT(loaderSrcs[i].gstElement);
        DS_ASSERT(renderSinks[i].gstElement);
        /* create and add all filters */
        bool hasFilters = configTable.count(config::ComponentType::kDataFilter);
        /* link all pad/elements together */
        code = CatchVoidCall([&loaderSrcs, &renderSinks, hasFilters, &configTable, i, appCtxs]() {
            gst::ElePtr lastEle = loaderSrcs[i].gstElement;
            if (hasFilters) {
                auto& filterConfigs = configTable[config::ComponentType::kDataFilter];
                DS_ASSERT(filterConfigs.size());
                for (size_t j = 0; j < filterConfigs.size(); ++j) {
                    auto queue = gst::elementMake("queue", ("filterQueue" + std::to_string(j) + "_cam" + std::to_string(i)).c_str());
                    DS_ASSERT(queue);
                    auto filter =
                        gst::elementMake(kDs3dFilterPluginName, ("filter" + std::to_string(j) + "_cam" + std::to_string(i)).c_str());
                    DS3D_THROW_ERROR_FMT(
                        filter, ErrCode::kGst, "gst-plugin: %s is not found", kDs3dFilterPluginName);
                    g_object_set(
                        G_OBJECT(filter.get()), "config-content", filterConfigs[j].rawContent.c_str(),
                        nullptr);
                    appCtxs[i]->add(queue).add(filter);
                    lastEle.link(queue).link(filter);
                    lastEle = filter;
            lastEle.link(renderSinks[i].gstElement);
        CHECK_ERROR(isGood(code), "Link pipeline elements failed for camera %d", i);
        /* Add probe to get informed of the meta data generated, we add probe to
         * gstappsrc src pad of the dataloader */
        gst::PadPtr srcPad = loaderSrcs[i].gstElement.staticPad("src");
        CHECK_ERROR(srcPad, "appsrc src pad is not detected for camera %d", i);
        srcPad.addProbe(GST_PAD_PROBE_TYPE_BUFFER, appsrcBufferProbe, appCtxs[i].get(), NULL);
        srcPad.reset();
         * gstappsink sink pad of the datrender */
        if (renderSinks[i].gstElement) {
            gst::PadPtr sinkPad = renderSinks[i].gstElement.staticPad("sink");
            CHECK_ERROR(sinkPad, "appsink sink pad is not detected for camera %d", i);
            sinkPad.addProbe(GST_PAD_PROBE_TYPE_BUFFER, appsinkBufferProbe, appCtxs[i].get(), NULL);
            sinkPad.reset();
        CHECK_ERROR(isGood(appCtxs[i]->play()), "app context play failed for camera %d", i);
        LOG_INFO("Play camera instance %d...", i);
        // get window system and set close event callback
        if (renderSinks[i].customProcessor) {
            GuardWindow win = renderSinks[i].customProcessor.getWindow();
            if (win) {
                GuardCB<abiWindow::CloseCB> windowClosedCb;
                windowClosedCb.setFn<>(WindowClosed);
                win->setCloseCallback(windowClosedCb.abiRef());
    /* Wait till pipelines encounter an error or EOS */
    for (auto& appCtx : appCtxs) {
        appCtx->runMainLoop();
        appCtx->stop();
        appCtx->deinit();
    return 0;
I am stuck here, can not figure out what the issue is, any suggestion would be appreciated.
Welcome to the NVIDIA Developer forums! Your topic will be best served in the Jetson category.
I will move this post over for visibility.
Cheers,
Tom
There is no such log in the sample code. Please check with your code.
Hello, thanks for the reply.
Actually there was a log in original sample code, which is as follows (inside create data render function):
 * Function to create dataloader source.
static ErrCode
CreateLoaderSource(
    std::map<config::ComponentType, ConfigList>& configTable, gst::DataLoaderSrc& loaderSrc,
    bool startLoader)
    // Check whether dataloader is configured
    DS3D_FAILED_RETURN(
        configTable.count(config::ComponentType::kDataLoader), ErrCode::kConfig,
        "config file doesn't have dataloader types");
    DS_ASSERT(configTable[config::ComponentType::kDataLoader].size() == 1);
    config::ComponentConfig& srcConfig = configTable[config::ComponentType::kDataLoader][0];
    // creat appsrc and dataloader
    DS3D_ERROR_RETURN(
        NvDs3D_CreateDataLoaderSrc(srcConfig, loaderSrc, startLoader),
        "Create appsrc and dataloader failed");
    DS_ASSERT(loaderSrc.gstElement);
    DS_ASSERT(loaderSrc.customProcessor);
    return ErrCode::kGood;
 * Function to create datarender sink.
static ErrCode
CreateRenderSink(
    std::map<config::ComponentType, ConfigList>& configTable, gst::DataRenderSink& renderSink,
    bool startRender)
    // Check whether datarender is configured
    if (configTable.find(config::ComponentType::kDataRender) == configTable.end()) {
        LOG_INFO("config file does not have datarender component, using fakesink instead");
        renderSink.gstElement = gst::elementMake("fakesink", "fakesink");
        DS_ASSERT(renderSink.gstElement);
    DS3D_FAILED_RETURN(
        configTable[config::ComponentType::kDataRender].size() == 1, ErrCode::kConfig,
        "multiple datarender component found, please update and keep 1 render only");
    config::ComponentConfig& sinkConfig = configTable[config::ComponentType::kDataRender][0];
    // creat appsink and datarender
    DS3D_ERROR_RETURN(
        NvDs3D_CreateDataRenderSink(sinkConfig, renderSink, startRender),
        "Create appsink and datarender failed");
    DS_ASSERT(renderSink.customProcessor);
I removed that and added my own function to create multiple instances, as follows:
static ErrCode CreateLoaderSourceForMultiple(
    const ConfigList& configs, gst::DataLoaderSrc& loaderSrc, bool startLoader)
    DS_ASSERT(configs.size() == 1);
    config::ComponentConfig& srcConfig = configs[0];
    DS3D_ERROR_RETURN(
 * Function to create datarender sink for multiple instances.
static ErrCode CreateRenderSinkForMultiple(
    const ConfigList& configs, gst::DataRenderSink& renderSink, bool startRender)
    config::ComponentConfig& sinkConfig = configs[0];
    DS3D_ERROR_RETURN(
Still, I am getting the same error, I believe that inside yaml file :
“custom_lib_path: libnvds_3d_gl_datarender.so
custom_create_function: createDepthStreamDataRender”
might be printing that log. But not sure. Let me know if I have misunderstood your question.
The code is in the CreateRenderSink() function in /opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-3d-depth-camera/deepstream_3d_depth_camera_main.cpp. There is no limitation with the render number. You can change the code according to your requirement.
