Running deepstream app as a service - g_object_get: assertion 'G_IS_OBJECT (object)' failed
I have written a basic systemd service file to run a customised version of the deepstream app as service. Everything works fine till I run it manually. But when I try to run it as a service - (sink - fakesink, source -rtsp), I keep on getting these warning/error msgs - g_object_get: assertion ‘G_IS_OBJECT (object)’ failed. But, the app seems to work fine.
• DeepStream Version
• TensorRT Version
Hardware - Jetson
Deeostream 5.0
Tensorrt - 7.1
Issue type - question
Your description is confusing. How do you run your systemd service of deepstream app and in what stage? Has the OS boot up finished and file system been ready?
The error looks like the gstreamer libraries has not been initialized correctly.
