• Hardware Platform (Jetson / GPU) Jetson Nano • DeepStream Version Deepstream6.1 • JetPack Version (valid for Jetson only) 4.6 • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
I am trying to run sample app deepstream-image-meta-test through putty terminal but every time I runs the application it gives me the following error:
ERROR from element primary-nvinference-engine: Internal data stream error.
Error details: /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvinfer/gstnvinfer.cpp(2288): gst_nvinfer_output_loop (): /GstPipeline:ds-image-meta-test-pipeline/GstNvInfer:primary-nvinference-engine:
streaming stopped, reason error (-5)
dlopen: Failed to load jTegra library for Tegra Acceleration
I don’t think this is necessarily gstreamer or Deepstream related. If you are running code that requires a graphical display (such as a pipeline with an nvoverlaysink) and there is not one available, it is not going to work. That’s why switching to the fakesink which doesn’t output to a display works fine. If this is a serious need for your development process I would recommend researching how to forward graphical displays through an SSH session.
it worked by putting ./ in front of the command… sudo ./deepstream-image-meta-testfile:///filepath
this worked for me…
and sudo deepstream-image-meta-testfile:filepath , this was giving me issue
just by adding “./” in front it worked…still wondering the reason behind this…
