• Hardware Platform (Jetson / GPU) | Jetson
• DeepStream Version | 6.0.1
• JetPack Version (valid for Jetson only) | Jetpack 4.6.3 (L4T 32.7.3)
• TensorRT Version | 8.2.1.8
• NVIDIA GPU Driver Version (valid for GPU only) -
After installing DeepStream SDK 6.0.1 as per this guide, and after successfully building deepstream-occupancy-analytics
, I try running the following command:
./deepstream-test5-analytics -c config/test5_config_file_src_infer_tlt.txt
I get this warning and these errors:
(deepstream-test5-analytics:27294): GStreamer-WARNING **: 13:31:00.621: Failed to load plugin '/usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_msgconv.so': /usr/lib/aarch64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_msgconv.so: undefined symbol: nvds_msg2p_generate_multiple_new
** ERROR: <create_msg_conv_broker_bin:234>: Failed to create 'sink_sub_bin_transform2'
** ERROR: <create_msg_conv_broker_bin:278>: create_msg_conv_broker_bin failed
** ERROR: <create_sink_bin:781>: create_sink_bin failed
** ERROR: <create_processing_instance:815>: create_processing_instance failed
** ERROR: <create_pipeline:1326>: create_pipeline failed
** ERROR: <main:1041>: Failed to create pipeline
Quitting
I traced the issue to a non-existent GStreamer plugin by first of all running rm ${HOME}/.cache/gstreamer-1.0/registry.aarch64.bin
Running gst-inspect-1.0 nvmsgbroker
prints a quite long output (what matters is that it’s available).
However, running gst-inspect-1.0 nvmsgconv
gives the following error message:
No such element or plugin 'nvmsgconv'
Could someone please help me in getting this plugin? I’ve looked everywhere but couldn’t find anything.
