• Hardware Platform (GPU) • DeepStream Version 6.2 • TensorRT Version 8.5.2 • NVIDIA GPU Driver Version 525.85.12 • Issue Type (questions)
I am trying to run deepstream-ssd-parser (Python) after installing deepstream SDK and Python Binding. I got model as per Example nvinferserver not working . SSD model is as
File “deepstream_ssd_parser.py”, line 454, in
sys.exit(main(sys.argv))
File “deepstream_ssd_parser.py”, line 377, in main
pgie.set_property(“config-file-path”, “dstest_ssd_nopostprocess.txt”)
AttributeError: ‘NoneType’ object has no attribute ‘set_property’
Please help me on this. Do I need to install NVIDIA Triton Inference Server.
Yes, I am able to run sample apps also. I think, this error is related to nvinferserver. Do I need docker necessarily to run deepstream-ssd-parser (Python)? I am running in AWS EC2 instance with T4 GPU.
