Running DOCA gRPC server with NVIDIA Bluefield-3
I need to use doca_grpc for a project. I therefore need doca_grpc.service, doca_grpc_infra and all the corresponding executables and config files. I recently updated a Bluefield-3 DPU with a new BFB firmware:
I ran the bfb-install tool per the instructions:
host# sudo bfb-install --rshim rshim0 --bfb bf-bundle-3.1.0-76_25.07_ubuntu-22.04_prod.bfb.
I saved the log file in bf-info.log. Doca-grpc was not installed even though this is a production bfb. How can I update my DPU with DOCA grpc.
bf-info.log (4.6 KB)
At this point, I believe I need to install the missing doca_grpc packages using the SDK Manager to collect the required *.deb files and install them manually on the DPU.
The issue is that when I run SDK Manager it only gives me option to download Jetson or Data Science packages. No DOCA!
Any help to get DOCA debian packages is welcome.
I found the reason why it does not work. NVIDIA has simply deprecated the doca_grpc server from version 2.9.0 forward. So, it cannot work to begin with.
