Running ds-triton pipeline with DeepStream and Triton C Api, triton model inference is stuck and the frame rate of deepstream drops to 0
Tesla T4 GPU
• DeepStream Version
NGC: nvcr.io/nvidia/deepstream:6.1-triton
• TensorRT Version
8.2.5
Driver Version: 515.48.07
bugs
My Deepstream pipeline uses Triton C Api(not the Gst-nvinferserver plugin) to call the secondary model inference asynchronously. When the entire pipeline is running, sometimes the frame rate of deepstream drops to 0 and the triton model inference is stuck meanwhile, which won’t recover again. I don’t know why, maybe there is a competition for GPU resources between ds and triton? Could somebody help me with this problem? Thank you!
• TensorRT Version
please refer to tritonserver sample server/simple.cc at main · triton-inference-server/server · GitHub
please refer to nvinfersever if needed: deepstream-infer-tensor-meta-test
Thanks for your reply! My Triton C Api has referred to server/simple.cc at main · triton-inference-server/server · GitHub . And I want to know how I shoud do next to debug this problem, but I have no idea now. Could you make some suggestions?
  1. dose model work ok by third part tool? is it stuck at beginning or after a while?
  2. please enable verbose log by TRITONSERVER_ServerOptionsSetLogVerbose, then analyze the logs and opensource Trtion code.
Yes, two models both work well in two separated processes with tensorrt engine,and it is stuck occasionally, sometimes at beginning, sometimes still work well after processing ten thousands of frames.
I enable verbose log, and find that tritonserver mostly stuck in two positions of tensorrt_backend(cudaEventSynchronize(), cudaStreamSynchronize()) . I wonder if deadlock occurs between ds(trt engine) and tritonserver(trt engine).
did triton native samples have this issue on your machine? as you know, triton is opensource, you can use gdb to analyze the stack.
Thank you! I’ll do it next.
Sorry for the late reply, Is this still an issue to support? Thanks
