I already used ESS DNN Stereo Disparity
with Isaac ROS2 docker environment and now want to create a simple C++ example for stand alone inference of two example images (left & right). I followed the TensorRT documentation to convert the .etlt file to an .engine file but now I got stuck on how to continue.
I got this from the documentations:
nvinfer1::IRuntime* runtime(nvinfer1::createInferRuntime(logger));
nvinfer1::ICudaEngine* engine(runtime->deserializeCudaEngine(engineData.data(), engineData.size()));
nvinfer1::IExecutionContext* context = engine->createExecutionContext();
but how to continue?
after reading the images do I need to copy them to GPU memory?
how to perform inference using both images?
how to get the output images for disparity and confidence?
Is there an example somewhere around for EES in C++? Unfortunately I couldn’t find what I am looking for in the ROS2 node.
Thanks in advance
Environment
TensorRT Version : 10.2.0.19
GPU Type : RTX A4500
CUDA Version : 12.2.2
Operating System + Version : Windows 10 Enterprise
I will answer my question myself. Feels like level up TensorRT Dev to get this thing run :)
External plugin:
ESS uses an external plugin, that needs to be added before deserializing the engine.
In cmake make sure to add libnvinfer_plugin.so:
target_link_libraries(${PROJECT_NAME}
libnvinfer.so
libnvinfer_plugin.so)
Load external plugin:
#include <NvInferPlugin.h>
#include <NvInferPluginUtils.h>
initLibNvInferPlugins(&logger, "");
getPluginRegistry()->loadLibrary("path/to/ess_plugin.so");
Create execution context:
auto runtime = std::shared_ptr<nvinfer1::IRuntime>{ nvinfer1::createInferRuntime(logger) };
auto engine = std::shared_ptr<nvinfer1::ICudaEngine>(runtime->deserializeCudaEngine(engineData.data(), engineData.size()));
auto context = std::shared_ptr<nvinfer1::IExecutionContext>(engine->createExecutionContext());
Normalize input data
for left and right images apply transformation
pixel_new = (float(pixel) / 255.0 - 0.5) / 0.5
run inference
void* bindings[] = { input_left_mem, input_right_mem, confidence_mem , disparity_mem};
std::cout << "async: enqueue inference" << std::endl;
bool status = context->enqueueV2(bindings, stream, nullptr);
input_left_mem, input_right_mem, disparity_mem, confidence_mem is device memory of needed size. (sizeof(float) * net_dimensions)
After inference copy memory from device to host
Result:
system
Closed
August 21, 2024, 8:34am
3
