I recently ran the Face-Recognition(https://github.com/AastaNV/Face-Recognition) on my TX2 using a USB camera, while it came out the following error:
Building and running a GPU inference engine for /home/nvidia/Face-Recognition/data/deploy.prototxt, N=1...
[gstreamer] initialized gstreamer, version 1.8.3.0
[gstreamer] gstreamer decoder pipeline string:
v4l2src device=/dev/video0 ! video/x-raw, width=(int)1280, height=(int)720, format=RGB ! videoconvert ! video/x-raw, format=RGB ! videoconvert !appsink name=mysink
successfully initialized video device
width: 1280
height: 720
depth: 24 (bpp)
Bindings after deserializing:
Binding 0 (data): Input.
Binding 1 (coverage_fd): Output.
Binding 2 (bboxes_fd): Output.
Binding 3 (count_fd): Output.
Binding 4 (bbox_fr): Output.
Binding 5 (bbox_id): Output.
Binding 6 (softmax_fr): Output.
Binding 7 (label): Output.
loaded image /home/nvidia/Face-Recognition/data/fontmapA.png (256 x 512) 2097152 bytes
[cuda] cudaAllocMapped 2097152 bytes, CPU 0x102a00000 GPU 0x102a00000
[cuda] cudaAllocMapped 8192 bytes, CPU 0x102c00000 GPU 0x102c00000
default X screen 0: 1920 x 1080
[OpenGL] glDisplay display window initialized
[OpenGL] creating 1280x720 texture
[gstreamer] gstreamer transitioning pipeline to GST_STATE_PLAYING
[gstreamer] gstreamer changed state from NULL to READY ==> mysink
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert1
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter1
[gstreamer] gstreamer changed state from NULL to READY ==> videoconvert0
[gstreamer] gstreamer changed state from NULL to READY ==> capsfilter0
[gstreamer] gstreamer changed state from NULL to READY ==> v4l2src0
[gstreamer] gstreamer changed state from NULL to READY ==> pipeline0
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert1
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter1
[gstreamer] gstreamer changed state from READY to PAUSED ==> videoconvert0
[gstreamer] gstreamer changed state from READY to PAUSED ==> capsfilter0
[gstreamer] gstreamer stream status CREATE ==> src
[gstreamer] gstreamer changed state from READY to PAUSED ==> v4l2src0
[gstreamer] gstreamer changed state from READY to PAUSED ==> pipeline0
[gstreamer] gstreamer msg new-clock ==> pipeline0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter1
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> videoconvert0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> capsfilter0
[gstreamer] gstreamer changed state from PAUSED to PLAYING ==> v4l2src0
[gstreamer] gstreamer decoder onEOS
[gstreamer] gstreamer stream status ENTER ==> src
[gstreamer] gstreamer msg stream-start ==> pipeline0
[gstreamer] gstreamer v4l2src0 ERROR Internal data flow error.
[gstreamer] gstreamer Debugging info: gstbasesrc.c(2948): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming task paused, reason not-negotiated (-4)
[gstreamer] gstreamer changed state from READY to PAUSED ==> mysink
Allocate memory: input blob
Allocate memory: coverage
Allocate memory: box
Allocate memory: count
Allocate memory: selected bbox
Allocate memory: selected index
Allocate memory: softmax
Allocate memory: label
failed to capture frame
failed to convert from NV12 to RGBA
[cuda] cudaPreImageNetMean((float4*)imgRGBA, camera->GetWidth(), camera->GetHeight(), data, dimsData.w(), dimsData.h(), make_float3(127.0f, 127.0f, 127.0f))
[cuda] invalid device pointer (error 17) (hex 0x11)
[cuda] /home/nvidia/Face-Recognition/face-recognition/face-recognition.cpp:223
cudaPreImageNetMean failed
Could someone give me some suggestions? Thank you in advance!
