I am planning on using a VPX3U BW5000E CX7 using NVIDIA DOCA OFED and the gpu_packet_proccessing example application. Will this work as I assume the ConnectX-7 NIC and the GPU will share the same PCIE?
Related topics
| What would be a lower cost combination of Nvidia GPU and ConnectX-7 NIC to do GPUDirect reception and processing | 1 | 71 | April 8, 2026 | |
| Communication between two GPU cards of Drive PX2 using ePCI | 2 | 757 | January 2, 2020 | |
| Problem with DOCA GPU packet processing | 2 | 271 | December 24, 2024 | |
| DOCA GPUNetIO gpu_packet_processing receives no packets | 13 | 367 | July 31, 2025 | |
| DOCA GPU Packet Processing example | 2 | 789 | May 19, 2023 | |
| DOCA gpu_packet_processing runtime error | 5 | 577 | June 18, 2024 | |
| Inline GPU Packet Processing with NVIDIA DOCA GPUNetIO | 6 | 1043 | July 23, 2025 | |
| Doca_gpu_packet_processing start failed | 0 | 73 | June 2, 2025 | |
| Entry level GPU Supporting GDA-KI ( GPU Direct Async Kernel assisted) | 0 | 65 | July 23, 2025 | |
| Can we chain multiple Xavier Jetson's together either in EP mode or via NTB? | 4 | 2357 | October 18, 2021 |
